Home » Modeling » EMF » [CDO] logging of session/user activity.
[CDO] logging of session/user activity. [message #687035] |
Tue, 24 May 2011 03:25  |
Hi, We have a requirement to log activity per user. So this could be an
object being created, modified or deleted. It could also be a reference
being created, modified or deleted. Is there a capability in CDO to do
this (Server side), perhaps linking a CDOSession and CDOView ?
Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687037 is a reply to message #687036] |
Tue, 24 May 2011 03:49   |
Hi Eike,
That's just great, thanks!
Christophe
On 24-05-11 09:39, Eike Stepper wrote:
> Hi Christophe,
> Please have a look at
> IRepository.addCommitInfoHandler(CDOCommitInfoHandler) and these default
> handlers:
> org.eclipse.emf.cdo.common.commit.handler.AsyncCommitInfoHandler
> org.eclipse.emf.cdo.common.commit.handler.BinaryCommitInfoLog
> org.eclipse.emf.cdo.common.commit.handler.TextCommitInfoLog
> They've been added with:
> 333460: Would like to have all commit sets in a log file
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=333460
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 24.05.2011 09:25, schrieb Christophe Bouhier:
>> an object being created, modified or deleted. It could also be a
>> reference being created, modified or deleted. Is there a capability in
>> CDO to do this (Server side), perhaps linking a CDOSession and CDOView ?
>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687055 is a reply to message #687037] |
Thu, 26 May 2011 03:53   |
Hi Eike,
The commit info needs to be added to the repository programmatically. What is a good place to do this? I mean the
repository should already be running so it can't be done in some Activator. Is there a logical place for these
repository configuration code?
gr. Martin
On 05/24/2011 09:49 AM, Christophe Bouhier wrote:
> Hi Eike,
> Christophe
>> Hi Christophe,
>> handlers:
>> Cheers
>> /Eike
>>> Thanks Christophe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] logging of session/user activity. [message #687056 is a reply to message #687055] |
Thu, 26 May 2011 04:18   |
Am 26.05.2011 09:53, schrieb Martin Taal:
> Hi Eike,
> The commit info
commit info handler ;-)
> needs to be added to the repository programmatically. What is a good place to do this? I mean the repository should already be running
No, these handlers can be added/removed at any time.
> so it can't be done in some Activator. Is there a logical place for these repository configuration code?
If you submit a bugzilla we could try to enhance the RepositoryConfigurator that interprets the cdo-server.xml
Cheers
/Eike
> gr. Martin
>> Hi Eike,
>> Christophe
>>> Hi Christophe,
>>> handlers:
>>> Cheers
>>> /Eike
>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687057 is a reply to message #687056] |
Thu, 26 May 2011 04:57   |
Yeah the commit info handler :-)
I have this in my activator:
final IManagedContainer container = IPluginContainer.INSTANCE;
final IRepository repo = CDOServerUtil.getRepository(container,
REPO_NAME);
final OutputStream os = new FileOutputStream(
"/home/mtaal/mytmp/test.commitinfo");
repo.addCommitInfoHandler(new TextCommitInfoLog(os));
but then I get this:
!ENTRY org.eclipse.equinox.app 4 0 2011-05-26 09:50:34.903
!MESSAGE org.eclipse.core.runtime.CoreException: Plug-in com.netxforge.netxstudio.server was unable to load class
com.netxforge.netxstudio.server.NetxForgeUserManager$Factory.
!STACK 0
org.eclipse.net4j.util.factory.FactoryCreationException: org.eclipse.core.runtime.CoreException: Plug-in
com.netxforge.netxstudio.server was unable to load class com.netxforge.netxstudio.server.NetxForgeUserManager$Factory.
at org.eclipse.net4j.util.factory.FactoryDescriptor.createFactory(FactoryDescriptor.java:49)
at org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry.get(PluginFactoryRegistry.java:41)
at org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry.get(PluginFactoryRegistry.java:1)
at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:190)
at org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:490)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:281)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:265)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getUserManager(RepositoryConfigurator.java:223)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getUserManager(RepositoryConfigurator.java:218)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getRepository(RepositoryConfigurator.java:173)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:105)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:679)
Caused by: org.eclipse.core.runtime.CoreException: Plug-in com.netxforge.netxstudio.server was unable to load class
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.net4j.util.factory.FactoryDescriptor.createFactory(FactoryDescriptor.java:45)
... 15 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error
occurred while automatically activating bundle com.netxforge.netxstudio.server (27).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:460)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
... 19 more
Caused by: org.osgi.framework.BundleException: Exception in com.netxforge.netxstudio.server.Activator.start() of bundle
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 31 more
Caused by: org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found:
org.eclipse.emf.cdo.server.repositories[default]
at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:193)
at org.eclipse.emf.cdo.spi.server.RepositoryFactory.get(RepositoryFactory.java:43)
at org.eclipse.emf.cdo.server.CDOServerUtil.getRepository(CDOServerUtil.java:206)
at com.netxforge.netxstudio.server.ServerUtils.addCommitInfoHandler(ServerUtils.java:86)
at com.netxforge.netxstudio.server.Activator.start(Activator.java:39)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 37 more
>> Hi Eike,
>> The commit info
>> already be running
> Cheers
> /Eike
>> gr. Martin
>>> Hi Eike,
>>> Christophe
>>>> Hi Christophe,
>>>> handlers:
>>>> Cheers
>>>> /Eike
>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687059 is a reply to message #687057] |
Thu, 26 May 2011 05:22   |
I can't see how the exception is related to the addition of the TextCommitInfoLog. To me it seems as if, at the time you call CDOServerUtil.getRepository() there is neither a repository with that name in the container nor has the container a factory to create one. Can you post an executable example?
Cheers
/Eike
Am 26.05.2011 10:57, schrieb Martin Taal:
> REPO_NAME);
> !MESSAGE org.eclipse.core.runtime.CoreException: Plug-in com.netxforge.netxstudio.server was unable to load class com.netxforge.netxstudio.server.NetxForgeUserManager$Factory.
> !STACK 0
> org.eclipse.net4j.util.factory.FactoryCreationException: org.eclipse.core.runtime.CoreException: Plug-in com.netxforge.netxstudio.server was unable to load class com.netxforge.netxstudio.server.NetxForgeUserManager$Factory.
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> Caused by: org.eclipse.core.runtime.CoreException: Plug-in com.netxforge.netxstudio.server was unable to load class com.netxforge.netxstudio.server.NetxForgeUserManager$Factory.
> at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
> ... 15 more
> Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.netxforge.netxstudio.server (27).
> ... 19 more
> Caused by: org.osgi.framework.BundleException: Exception in com.netxforge.netxstudio.server.Activator.start() of bundle com.netxforge.netxstudio.server.
> ... 31 more
> Caused by: org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.emf.cdo.server.repositories[default]
> at java.security.AccessController.doPrivileged(Native Method)
> ... 37 more
>>> Hi Eike,
>>> The commit info
>>> already be running
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Hi Eike,
>>>> Christophe
>>>>> Hi Christophe,
>>>>> handlers:
>>>>> Cheers
>>>>> /Eike
>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687060 is a reply to message #687059] |
Thu, 26 May 2011 06:15   |
It is kind of difficult to create an executable example, I put this code in the Activator of a plugin. I can imagine
that this activator is called before the cdo repository is up and running. Can I add a listener somehow which gets a
ping when a repository is up and running?
gr. Martin
> Cheers
> /Eike
>> REPO_NAME);
>> !STACK 0
>> at
>> ... 15 more
>> ... 19 more
>> ... 31 more
>> ... 37 more
>>>> Hi Eike,
>>>> The commit info
>>>> already be running
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Hi Eike,
>>>>> Christophe
>>>>>> Hi Christophe,
>>>>>> handlers:
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687064 is a reply to message #687060] |
Thu, 26 May 2011 11:52   |
Am 26.05.2011 12:15, schrieb Martin Taal:
> It is kind of difficult to create an executable example, I put this code in the Activator of a plugin. I can imagine that this activator is called before the cdo repository is up and running. Can I add a listener somehow which gets a ping when a repository is up and running?
What about IPluginContainer.INSTANCE.addPostProcessor(logConfigurer)? You can also do it declaratively like:
<extension point="org.eclipse.net4j.util.elementProcessors">
<elementProcessor class="org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer"/>
<elementProcessor class="org.eclipse.emf.cdo.spi.server.RepositoryUserManager$RepositoryInjector"/>
</extension>
IPluginContainer.INSTANCE.addListener(logConfigurer) should also work because you don't need an early lifecycle phase.
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
>>> REPO_NAME);
>>> !STACK 0
>>> at
>>> ... 15 more
>>> ... 19 more
>>> ... 31 more
>>> ... 37 more
>>>>> Hi Eike,
>>>>> The commit info
>>>>> already be running
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> Hi Eike,
>>>>>> Christophe
>>>>>>> Hi Christophe,
>>>>>>> handlers:
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687065 is a reply to message #687064] |
Thu, 26 May 2011 12:07   |
If I use the element processor I get the same error, there is no repository when the elements gets parsed. For what
event should the listener be configured? Something like the repository-up-and-running event, is there something like that?
gr. Martin
> </extension>
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> REPO_NAME);
>>>> !STACK 0
>>>> at
>>>> at
>>>> ... 15 more
>>>> at
>>>> ... 19 more
>>>> ... 31 more
>>>> ... 37 more
>>>>>> Hi Eike,
>>>>>> The commit info
>>>>>> already be running
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> Hi Eike,
>>>>>>> Christophe
>>>>>>>> Hi Christophe,
>>>>>>>> handlers:
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687066 is a reply to message #687065] |
Thu, 26 May 2011 12:11   |
Am 26.05.2011 18:07, schrieb Martin Taal:
Can I see your process() method?
> For what event should the listener be configured?
IContainerEvent. You can also extend org.eclipse.net4j.util.container.ContainerEventAdapter<E>.
Yes, the repo fires ILifecycleEvents but you'd need to hold on the repo before you can even register a LifecycleEventAdapter.
Cheers
/Eike
> gr. Martin
>> </extension>
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
>>>>> REPO_NAME);
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> ... 15 more
>>>>> at
>>>>> ... 19 more
>>>>> ... 31 more
>>>>> ... 37 more
>>>>>>> Hi Eike,
>>>>>>> The commit info
>>>>>>> already be running
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>> Hi Eike,
>>>>>>>> Christophe
>>>>>>>>> Hi Christophe,
>>>>>>>>> handlers:
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687067 is a reply to message #687066] |
Thu, 26 May 2011 12:50   |
For the element processor, I should wait for a specific element type?
I tried the listener, it fails the first time it gets called but after a few calls the repository seems to be there. So
I should probably wait for a specific container event, which one?
IPluginContainer.INSTANCE.addListener(new IListener() {
public void notifyEvent(IEvent event) {
if (event instanceof IContainerEvent) {
final IContainer<?> container = ((IContainerEvent<?>)event).getSource();
final IRepository repo = CDOServerUtil.getRepository((IManagedContainer)container,
REPO_NAME);
final AsyncCommitInfoHandler asyncCommitInfoHandler = new AsyncCommitInfoHandler(new NetxForgeCommitInfoHandler());
asyncCommitInfoHandler.activate();
repo.addCommitInfoHandler(asyncCommitInfoHandler);
> Cheers
> /Eike
>> gr. Martin
>>> </extension>
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> time you
>>>>> container a
>>>>> Cheers
>>>>> /Eike
>>>>>> REPO_NAME);
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> ... 15 more
>>>>>> at
>>>>>> ... 19 more
>>>>>> ... 31 more
>>>>>> ... 37 more
>>>>>>>> Hi Eike,
>>>>>>>> The commit info
>>>>>>>> already be running
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>> Hi Eike,
>>>>>>>>> Christophe
>>>>>>>>>> Hi Christophe,
>>>>>>>>>> handlers:
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687069 is a reply to message #687067] |
Thu, 26 May 2011 13:20   |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
Am 26.05.2011 18:50, schrieb Martin Taal:
<blockquote cite="mid:irlvsc$2h2$1@news.eclipse.org" type="cite">For
<br>
</blockquote>
IRepository? :P<br>
<br>
I've tried to create an example for you:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html;
charset=ISO-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = -->
<!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3"
cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td nowrap="nowrap" align="left"
valign="top"> <code>
<font color="#ffffff"> </font><font color="#7f0055"><b>class </b></font><font
color="#000000">RepositoryCommitLogConfigurer </font><font
color="#7f0055"><b>implements </b></font><font
color="#000000">IElementProcessor</font><br>
<font color="#ffffff"> </font><font color="#000000">{</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>public </b></font><font
color="#000000">Object process</font><font
color="#000000">(</font><font color="#000000">IManagedContainer container, String productGroup, String factoryType, String description,</font><br>
color="#000000">Object element</font><font
color="#000000">)</font><br>
color="#7f0055"><b>if </b></font><font color="#000000">(</font><font
color="#000000">element </font><font color="#7f0055"><b>instanceof </b></font><font
color="#000000">IRepository</font><font
color="#7f0055"><b>try</b></font><br>
color="#000000">processRepository</font><font
color="#000000">((</font><font color="#000000">IRepository</font><font
color="#000000">)</font><font color="#000000">element</font><font
color="#000000">)</font><font color="#000000">;</font><br>
color="#000000">}</font><br>
color="#7f0055"><b>catch </b></font><font
color="#000000">(</font><font color="#000000">Exception ex</font><font
color="#000000">OM.LOG.warn</font><font
color="#000000">(</font><font color="#2a00ff">"Problem with commit log setup"</font><font
color="#000000">, ex</font><font color="#000000">)</font><font
<font color="#ffffff"></font><br>
color="#7f0055"><b>return </b></font><font
color="#000000">element;</font><br>
<font color="#ffffff"> </font><font color="#000000">}</font><br>
<font color="#ffffff"> </font><font color="#7f0055"><b>private </b></font><font
color="#7f0055"><b>void </b></font><font
color="#000000">(</font><font color="#000000">IRepository repository</font><font
color="#000000">) </font><font color="#7f0055"><b>throws </b></font><font
color="#000000">FileNotFoundException</font><br>
color="#7f0055"><b>final </b></font><font
color="#000000">OutputStream os = </font><font
color="#7f0055"><b>new </b></font><font
color="#000000">FileOutputStream</font><font
color="#000000">(</font><font color="#2a00ff">"/home/mtaal/mytmp/test.commitinfo"</font><font
color="#000000">repository.addCommitInfoHandler</font><font
color="#000000">(</font><font color="#7f0055"><b>new </b></font><font
color="#000000">TextCommitInfoLog</font><font
color="#000000">(</font><font color="#000000">os</font><font
color="#000000">))</font><font color="#000000">;</font><br>
color="#000000">repository.addListener</font><font
color="#000000">LifecycleEventAdapter</font><font
color="#000000">()</font><br>
color="#646464">@Override</font><br>
color="#7f0055"><b>protected </b></font><font
color="#000000">onDeactivated</font><font
color="#000000">(</font><font color="#000000">ILifecycle lifecycle</font><font
color="#000000">IOUtil.close</font><font
color="#000000">})</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">IPluginContainer.INSTANCE.addPostProcessor</font><font
color="#000000">RepositoryCommitLogConfigurer</font><font
color="#000000">())</font><font color="#000000">;</font></code>
</td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<br>
The last line can also be replaced with some markup in the
plugin.xml (see previous post).<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
<br>
after a few calls the repository seems to be there. So I should
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
REPO_NAME);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Am 26.05.2011 18:07, schrieb Martin Taal:
<br>
<blockquote type="cite">If I use the element processor I get the
parsed.
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">For what event should the listener be
configured?
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">Something like the
<br>
</blockquote>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">Am 26.05.2011 12:15, schrieb Martin
Taal:
<br>
<blockquote type="cite">It is kind of difficult to create an
<br>
<br>
<br>
</blockquote>
What about
<br>
<br>
<extension
<br>
<elementProcessor
class="org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer"/><br>
<elementProcessor
class="org.eclipse.emf.cdo.spi.server.RepositoryUserManager$RepositoryInjector"/><br>
</extension>
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">I can't see how the exception is
<br>
time you
<br>
<br>
container a
<br>
example?
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Yeah the commit info handler :-)
<br>
<br>
<br>
<br>
<br>
REPO_NAME);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
09:50:34.903
<br>
load class
<br>
<br>
!STACK 0
<br>
<br>
class
<br>
<br>
at
org.eclipse.net4j.util.factory.FactoryDescriptor.createFactory(FactoryDescriptor.java:49)<br>
at
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry.get(PluginFactoryRegistry.java:41)<br>
at
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry.get(PluginFactoryRegistry.java:1)<br>
at
org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:190)<br>
at
org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:490)<br>
at
org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:281)<br>
at
org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:265)<br>
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getUserManager(RepositoryConfigurator.java:223)<br>
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getUserManager(RepositoryConfigurator.java:218)<br>
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getRepository(RepositoryConfigurator.java:173)<br>
at
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:105)<br>
at
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)<br>
at
<br>
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)<br>
at
org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)<br>
<br>
load class
<br>
<br>
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)<br>
at
<br>
<br>
at
org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)<br>
at
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)<br>
at
<br>
<br>
<br>
<br>
<br>
at
org.eclipse.net4j.util.factory.FactoryDescriptor.createFactory(FactoryDescriptor.java:45)<br>
... 15 more
<br>
Caused by:
An error
<br>
<br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)<br>
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:460)<br>
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)<br>
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)<br>
at
<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)<br>
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)<br>
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)<br>
at
<br>
<br>
... 19 more
<br>
Exception in
<br>
<br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)<br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)<br>
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)<br>
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)<br>
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)<br>
at
org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)<br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)<br>
... 31 more
<br>
Caused by:
Factory not found:
<br>
<br>
at
org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:193)<br>
at
at
at
at
org.eclipse.emf.cdo.spi.server.RepositoryFactory.get(RepositoryFactory.java:43)<br>
at
org.eclipse.emf.cdo.server.CDOServerUtil.getRepository(CDOServerUtil.java:206)<br>
at
com.netxforge.netxstudio.server.ServerUtils.addCommitInfoHandler(ServerUtils.java:86)<br>
at
<br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)<br>
Method)
<br>
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)<br>
... 37 more
<br>
<br>
<br>
<br>
<blockquote type="cite">Am 26.05.2011 09:53, schrieb
Martin Taal:
<br>
<blockquote type="cite">Hi Eike,
<br>
The commit info
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">needs to be added to the
<br>
already be running
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">so it can't be done in some
<br>
</blockquote>
cdo-server.xml
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<br>
<br>
<br>
Christophe
<br>
<br>
<br>
<blockquote type="cite">Hi Christophe,
<br>
<br>
<br>
and these default
<br>
handlers:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
a log file
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=333460">https://bugs.eclipse.org/bugs/show_bug.cgi?id=333460</a>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bouhier:
<br>
<blockquote type="cite">Hi, We have a
this could be
<br>
<br>
<br>
<br>
<br>
Thanks Christophe
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
Re: [CDO] logging of session/user activity. [message #687071 is a reply to message #687069] |
Thu, 26 May 2011 15:57   |
Thanks Eike, I tried it but afaics the element is never a IRepository. I defined this through an extension.
gr. Martin
> IRepository? :P
> |*class *RepositoryCommitLogConfigurer *implements *IElementProcessor
> *public *Object process(IManagedContainer container, String productGroup, String factoryType, String description,
> Object element)
> *if *(element *instanceof *IRepository)
> *try*
> processRepository((IRepository)element);
> *catch *(Exception ex)
> OM.LOG.warn("Problem with commit log setup", ex);
> *return *element;
> *private **void *processRepository(IRepository repository) *throws *FileNotFoundException
> *final *OutputStream os = *new *FileOutputStream("/home/mtaal/mytmp/test.commitinfo");
> repository.addCommitInfoHandler(*new *TextCommitInfoLog(os));
> repository.addListener(*new *LifecycleEventAdapter()
> @Override
> *protected **void *onDeactivated(ILifecycle lifecycle)
> IOUtil.close(os);
> IPluginContainer.INSTANCE.addPostProcessor(*new *RepositoryCommitLogConfigurer());|
> The last line can also be replaced with some markup in the plugin.xml (see previous post).
> Cheers
> /Eike
>> So I should probably wait for a specific container event, which one?
>> @Override
>> REPO_NAME);
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> </extension>
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> time you
>>>>>>> container a
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> REPO_NAME);
>>>>>>>> !STACK 0
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 15 more
>>>>>>>> at
>>>>>>>> ... 19 more
>>>>>>>> ... 31 more
>>>>>>>> ... 37 more
>>>>>>>>>> Hi Eike,
>>>>>>>>>> The commit info
>>>>>>>>>> should
>>>>>>>>>> already be running
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>> Hi Eike,
>>>>>>>>>>> Christophe
>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>> handlers:
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687072 is a reply to message #687071] |
Thu, 26 May 2011 16:50   |
Am 26.05.2011 21:57, schrieb Martin Taal:
If I can't try it I run out of ideas ;-(
Cheers
/Eike
> gr. Martin
>> IRepository? :P
>> Object element)
>> *try*
>> *return *element;
>> @Override
>> IOUtil.close(os);
>> Cheers
>> /Eike
>>> @Override
>>> REPO_NAME);
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> </extension>
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>> time you
>>>>>>>> container a
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> REPO_NAME);
>>>>>>>>> !STACK 0
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> ... 15 more
>>>>>>>>> at
>>>>>>>>> ... 19 more
>>>>>>>>> ... 31 more
>>>>>>>>> ... 37 more
>>>>>>>>>>> Hi Eike,
>>>>>>>>>>> The commit info
>>>>>>>>>>> should
>>>>>>>>>>> already be running
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>> Christophe
>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687073 is a reply to message #687072] |
Thu, 26 May 2011 16:55   |
Hi Eike,
You mean that in your case this element processor gets a Repository instance?
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> IRepository? :P
>>> Object element)
>>> *try*
>>> *return *element;
>>> @Override
>>> IOUtil.close(os);
>>> Cheers
>>> /Eike
>>>> @Override
>>>> REPO_NAME);
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>>> imagine
>>>>>>>> gets a
>>>>>>> </extension>
>>>>>>> phase.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>> time you
>>>>>>>>> container a
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> REPO_NAME);
>>>>>>>>>> !STACK 0
>>>>>>>>>> class
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> ... 15 more
>>>>>>>>>> error
>>>>>>>>>> at
>>>>>>>>>> ... 19 more
>>>>>>>>>> ... 31 more
>>>>>>>>>> ... 37 more
>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>> The commit info
>>>>>>>>>>>> should
>>>>>>>>>>>> already be running
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687075 is a reply to message #687073] |
Fri, 27 May 2011 02:13   |
Am 26.05.2011 22:55, schrieb Martin Taal:
> Hi Eike,
No, that means that I did not run my code. It all depends on if/how/when the repository is created and if/how/when it is made available in the container. There are thousand ways possible.
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
>>> gr. Martin
>>>> IRepository? :P
>>>> Object element)
>>>> *try*
>>>> *return *element;
>>>> @Override
>>>> IOUtil.close(os);
>>>> Cheers
>>>> /Eike
>>>>> @Override
>>>>> REPO_NAME);
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>>> imagine
>>>>>>>>> gets a
>>>>>>>> </extension>
>>>>>>>> phase.
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> gr. Martin
>>>>>>>>>> time you
>>>>>>>>>> container a
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>> !STACK 0
>>>>>>>>>>> class
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> ... 15 more
>>>>>>>>>>> error
>>>>>>>>>>> at
>>>>>>>>>>> ... 19 more
>>>>>>>>>>> ... 31 more
>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>> should
>>>>>>>>>>>>> already be running
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687079 is a reply to message #687075] |
Fri, 27 May 2011 05:16   |
Hi Eike,
I use the cdo-server.xml which I attached. Does this help?
gr. Martin
>> Hi Eike,
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> IRepository? :P
>>>>> Object element)
>>>>> *try*
>>>>> *return *element;
>>>>> @Override
>>>>> IOUtil.close(os);
>>>>> Cheers
>>>>> /Eike
>>>>>> @Override
>>>>>> REPO_NAME);
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>>> imagine
>>>>>>>>>> gets a
>>>>>>>>> </extension>
>>>>>>>>> phase.
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>> time you
>>>>>>>>>>> container a
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>> class
>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>> class
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>> error
>>>>>>>>>>>> at
>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>> should
>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687080 is a reply to message #687079] |
Fri, 27 May 2011 06:02   |
Hi Martin,
Sorry, I realized a little late that there's an issue with ManagedContainer.putElement() in that does not call element processors. I've fixed that in bugzilla:
347427: ManagedContainer.putElement() does not call element processors
https://bugs.eclipse.org/bugs/show_bug.cgi?id=347427
Cheers
/Eike
Am 27.05.2011 11:16, schrieb Martin Taal:
> Hi Eike,
> gr. Martin
>>> Hi Eike,
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> IRepository? :P
>>>>>> Object element)
>>>>>> *try*
>>>>>> *return *element;
>>>>>> @Override
>>>>>> IOUtil.close(os);
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> @Override
>>>>>>> REPO_NAME);
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> gr. Martin
>>>>>>>>>>> imagine
>>>>>>>>>>> gets a
>>>>>>>>>> </extension>
>>>>>>>>>> phase.
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> time you
>>>>>>>>>>>> container a
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>>> class
>>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>>> class
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>>> error
>>>>>>>>>>>>> at
>>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687081 is a reply to message #687080] |
Fri, 27 May 2011 06:41  |
Thanks Eike, I will pick up the build which contains this and try it out.
gr. Martin
On 05/27/2011 12:02 PM, Eike Stepper wrote:
> Hi Martin,
> Cheers
> /Eike
>> Hi Eike,
>> gr. Martin
>>>> Hi Eike,
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> IRepository? :P
>>>>>>> Object element)
>>>>>>> *try*
>>>>>>> *return *element;
>>>>>>> @Override
>>>>>>> IOUtil.close(os);
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> there.
>>>>>>>> @Override
>>>>>>>> REPO_NAME);
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>>> imagine
>>>>>>>>>>>> gets a
>>>>>>>>>>> </extension>
>>>>>>>>>>> phase.
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> the
>>>>>>>>>>>>> time you
>>>>>>>>>>>>> container a
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>>>> class
>>>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>>>> class
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>>>> error
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>>>> repository
>>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>>>> cdo-server.xml
>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687234 is a reply to message #687036] |
Hi Eike,
Christophe
> Hi Christophe,
> handlers:
> Cheers
> /Eike
>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687260 is a reply to message #687037] |
Hi Eike,
gr. Martin
> Hi Eike,
> Christophe
>> Hi Christophe,
>> handlers:
>> Cheers
>> /Eike
>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687261 is a reply to message #687055] |
> Hi Eike,
> The commit info
Cheers
/Eike
> gr. Martin
>> Hi Eike,
>> Christophe
>>> Hi Christophe,
>>> handlers:
>>> Cheers
>>> /Eike
>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687262 is a reply to message #687056] |
REPO_NAME);
!STACK 0
at
... 15 more
... 19 more
... 31 more
... 37 more
>> Hi Eike,
>> The commit info
>> already be running
> Cheers
> /Eike
>> gr. Martin
>>> Hi Eike,
>>> Christophe
>>>> Hi Christophe,
>>>> handlers:
>>>> Cheers
>>>> /Eike
>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687264 is a reply to message #687057] |
Cheers
/Eike
> REPO_NAME);
> !STACK 0
> ... 15 more
> ... 19 more
> ... 31 more
> ... 37 more
>>> Hi Eike,
>>> The commit info
>>> already be running
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Hi Eike,
>>>> Christophe
>>>>> Hi Christophe,
>>>>> handlers:
>>>>> Cheers
>>>>> /Eike
>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687265 is a reply to message #687059] |
gr. Martin
> Cheers
> /Eike
>> REPO_NAME);
>> !STACK 0
>> at
>> ... 15 more
>> ... 19 more
>> ... 31 more
>> ... 37 more
>>>> Hi Eike,
>>>> The commit info
>>>> already be running
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Hi Eike,
>>>>> Christophe
>>>>>> Hi Christophe,
>>>>>> handlers:
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687272 is a reply to message #687060] |
</extension>
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
>>> REPO_NAME);
>>> !STACK 0
>>> at
>>> ... 15 more
>>> ... 19 more
>>> ... 31 more
>>> ... 37 more
>>>>> Hi Eike,
>>>>> The commit info
>>>>> already be running
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> Hi Eike,
>>>>>> Christophe
>>>>>>> Hi Christophe,
>>>>>>> handlers:
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687273 is a reply to message #687064] |
gr. Martin
> </extension>
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> REPO_NAME);
>>>> !STACK 0
>>>> at
>>>> at
>>>> ... 15 more
>>>> at
>>>> ... 19 more
>>>> ... 31 more
>>>> ... 37 more
>>>>>> Hi Eike,
>>>>>> The commit info
>>>>>> already be running
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> Hi Eike,
>>>>>>> Christophe
>>>>>>>> Hi Christophe,
>>>>>>>> handlers:
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687274 is a reply to message #687065] |
Cheers
/Eike
> gr. Martin
>> </extension>
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
>>>>> REPO_NAME);
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> ... 15 more
>>>>> at
>>>>> ... 19 more
>>>>> ... 31 more
>>>>> ... 37 more
>>>>>>> Hi Eike,
>>>>>>> The commit info
>>>>>>> already be running
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>> Hi Eike,
>>>>>>>> Christophe
>>>>>>>>> Hi Christophe,
>>>>>>>>> handlers:
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687275 is a reply to message #687066] |
REPO_NAME);
> Cheers
> /Eike
>> gr. Martin
>>> </extension>
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> time you
>>>>> container a
>>>>> Cheers
>>>>> /Eike
>>>>>> REPO_NAME);
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> ... 15 more
>>>>>> at
>>>>>> ... 19 more
>>>>>> ... 31 more
>>>>>> ... 37 more
>>>>>>>> Hi Eike,
>>>>>>>> The commit info
>>>>>>>> already be running
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>> Hi Eike,
>>>>>>>>> Christophe
>>>>>>>>>> Hi Christophe,
>>>>>>>>>> handlers:
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687278 is a reply to message #687067] |
<html>
<head>
</head>
<br>
</blockquote>
IRepository? :P<br>
<br>
<br>
<title></title>
</style>
cellspacing="0">
<tbody>
<tr>
</td>
</tbody>
</table>
</div>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
REPO_NAME);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
parsed.
<br>
</blockquote>
<br>
<br>
configured?
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
Taal:
<br>
<br>
<br>
<br>
</blockquote>
What about
<br>
<br>
<extension
<br>
<elementProcessor
<elementProcessor
</extension>
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<br>
time you
<br>
<br>
container a
<br>
example?
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
REPO_NAME);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
09:50:34.903
<br>
load class
<br>
<br>
!STACK 0
<br>
<br>
class
<br>
<br>
at
at
at
at
at
at
at
at
at
at
at
at
at
<br>
at
at
<br>
load class
<br>
<br>
at
at
<br>
<br>
at
at
at
<br>
<br>
<br>
<br>
<br>
at
... 15 more
<br>
Caused by:
An error
<br>
<br>
at
at
at
at
at
at
at
at
at
<br>
at
at
at
at
<br>
<br>
... 19 more
<br>
Exception in
<br>
<br>
at
at
at
at
at
at
at
... 31 more
<br>
Caused by:
Factory not found:
<br>
<br>
at
at
at
at
at
at
at
at
<br>
at
Method)
<br>
at
... 37 more
<br>
<br>
<br>
<br>
Martin Taal:
<br>
<br>
The commit info
<br>
</blockquote>
<br>
<br>
<br>
already be running
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
cdo-server.xml
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<br>
<br>
<br>
Christophe
<br>
<br>
<br>
<br>
<br>
<br>
and these default
<br>
handlers:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
a log file
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bouhier:
<br>
this could be
<br>
<br>
<br>
<br>
<br>
Thanks Christophe
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
Re: [CDO] logging of session/user activity. [message #687280 is a reply to message #687069] |
gr. Martin
> IRepository? :P
> Object element)
> *try*
> *return *element;
> @Override
> IOUtil.close(os);
> Cheers
> /Eike
>> @Override
>> REPO_NAME);
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> </extension>
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> time you
>>>>>>> container a
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> REPO_NAME);
>>>>>>>> !STACK 0
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 15 more
>>>>>>>> at
>>>>>>>> ... 19 more
>>>>>>>> ... 31 more
>>>>>>>> ... 37 more
>>>>>>>>>> Hi Eike,
>>>>>>>>>> The commit info
>>>>>>>>>> should
>>>>>>>>>> already be running
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>> Hi Eike,
>>>>>>>>>>> Christophe
>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>> handlers:
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687281 is a reply to message #687071] |
Cheers
/Eike
> gr. Martin
>> IRepository? :P
>> Object element)
>> *try*
>> *return *element;
>> @Override
>> IOUtil.close(os);
>> Cheers
>> /Eike
>>> @Override
>>> REPO_NAME);
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> </extension>
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>> time you
>>>>>>>> container a
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> REPO_NAME);
>>>>>>>>> !STACK 0
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> ... 15 more
>>>>>>>>> at
>>>>>>>>> ... 19 more
>>>>>>>>> ... 31 more
>>>>>>>>> ... 37 more
>>>>>>>>>>> Hi Eike,
>>>>>>>>>>> The commit info
>>>>>>>>>>> should
>>>>>>>>>>> already be running
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>> Christophe
>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687282 is a reply to message #687072] |
Hi Eike,
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> IRepository? :P
>>> Object element)
>>> *try*
>>> *return *element;
>>> @Override
>>> IOUtil.close(os);
>>> Cheers
>>> /Eike
>>>> @Override
>>>> REPO_NAME);
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>>> imagine
>>>>>>>> gets a
>>>>>>> </extension>
>>>>>>> phase.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>> time you
>>>>>>>>> container a
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> REPO_NAME);
>>>>>>>>>> !STACK 0
>>>>>>>>>> class
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> ... 15 more
>>>>>>>>>> error
>>>>>>>>>> at
>>>>>>>>>> ... 19 more
>>>>>>>>>> ... 31 more
>>>>>>>>>> ... 37 more
>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>> The commit info
>>>>>>>>>>>> should
>>>>>>>>>>>> already be running
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687285 is a reply to message #687073] |
> Hi Eike,
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
>>> gr. Martin
>>>> IRepository? :P
>>>> Object element)
>>>> *try*
>>>> *return *element;
>>>> @Override
>>>> IOUtil.close(os);
>>>> Cheers
>>>> /Eike
>>>>> @Override
>>>>> REPO_NAME);
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> gr. Martin
>>>>>>>>> imagine
>>>>>>>>> gets a
>>>>>>>> </extension>
>>>>>>>> phase.
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> gr. Martin
>>>>>>>>>> time you
>>>>>>>>>> container a
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>> !STACK 0
>>>>>>>>>>> class
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> ... 15 more
>>>>>>>>>>> error
>>>>>>>>>>> at
>>>>>>>>>>> ... 19 more
>>>>>>>>>>> ... 31 more
>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>> should
>>>>>>>>>>>>> already be running
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687290 is a reply to message #687075] |
Hi Eike,
gr. Martin
>> Hi Eike,
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> IRepository? :P
>>>>> Object element)
>>>>> *try*
>>>>> *return *element;
>>>>> @Override
>>>>> IOUtil.close(os);
>>>>> Cheers
>>>>> /Eike
>>>>>> @Override
>>>>>> REPO_NAME);
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> gr. Martin
>>>>>>>>>> imagine
>>>>>>>>>> gets a
>>>>>>>>> </extension>
>>>>>>>>> phase.
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>> time you
>>>>>>>>>>> container a
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>> class
>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>> class
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>> error
>>>>>>>>>>>> at
>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>> should
>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Re: [CDO] logging of session/user activity. [message #687292 is a reply to message #687079] |
Hi Martin,
Cheers
/Eike
> Hi Eike,
> gr. Martin
>>> Hi Eike,
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
>>>>> gr. Martin
>>>>>> IRepository? :P
>>>>>> Object element)
>>>>>> *try*
>>>>>> *return *element;
>>>>>> @Override
>>>>>> IOUtil.close(os);
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> @Override
>>>>>>> REPO_NAME);
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> gr. Martin
>>>>>>>>>>> imagine
>>>>>>>>>>> gets a
>>>>>>>>>> </extension>
>>>>>>>>>> phase.
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> time you
>>>>>>>>>>>> container a
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> /Eike
>>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>>> class
>>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>>> class
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>>> error
>>>>>>>>>>>>> at
>>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>>> Thanks Christophe
Re: [CDO] logging of session/user activity. [message #687294 is a reply to message #687080] |
gr. Martin
> Hi Martin,
> Cheers
> /Eike
>> Hi Eike,
>> gr. Martin
>>>> Hi Eike,
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Cheers
>>>>> /Eike
>>>>>> gr. Martin
>>>>>>> IRepository? :P
>>>>>>> Object element)
>>>>>>> *try*
>>>>>>> *return *element;
>>>>>>> @Override
>>>>>>> IOUtil.close(os);
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> there.
>>>>>>>> @Override
>>>>>>>> REPO_NAME);
>>>>>>>>> Cheers
>>>>>>>>> /Eike
>>>>>>>>>> gr. Martin
>>>>>>>>>>>> imagine
>>>>>>>>>>>> gets a
>>>>>>>>>>> </extension>
>>>>>>>>>>> phase.
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> the
>>>>>>>>>>>>> time you
>>>>>>>>>>>>> container a
>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>> REPO_NAME);
>>>>>>>>>>>>>> class
>>>>>>>>>>>>>> !STACK 0
>>>>>>>>>>>>>> class
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 15 more
>>>>>>>>>>>>>> error
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 19 more
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> ... 31 more
>>>>>>>>>>>>>> ... 37 more
>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>> The commit info
>>>>>>>>>>>>>>>> repository
>>>>>>>>>>>>>>>> should
>>>>>>>>>>>>>>>> already be running
>>>>>>>>>>>>>>> cdo-server.xml
>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>>>>> Hi Eike,
>>>>>>>>>>>>>>>>> Christophe
>>>>>>>>>>>>>>>>>> Hi Christophe,
>>>>>>>>>>>>>>>>>> handlers:
>>>>>>>>>>>>>>>>>> Cheers
>>>>>>>>>>>>>>>>>> /Eike
>>>>>>>>>>>>>>>>>>> Thanks Christophe
The Netherlands
Current Time: Sat Jul 26 19:17:54 EDT 2025
Powered by FUDForum. Page generated in 0.36991 seconds
