Home » Modeling » EMF » [EMF] UUID of EObject
[EMF] UUID of EObject [message #686816] |
Fri, 20 May 2011 03:56  |
I have a model with enabled containment proxies. Object objectA is added
into contents of resourceA and object objectB is added into contents of
resourceB. objectA contains objectB. Both resources use UUIDs. After
unload of resourceB all contained objects are attached to resourceA. ID
of objectB in resourceB before resourceB unload and ID of objectB in
resourceA after resourceB unload are different.
Is this normal and why ?
Thanks in advance,
Rimvydas
Re: [EMF] UUID of EObject [message #686822 is a reply to message #686821] |
Fri, 20 May 2011 10:49   |
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl is used.
After unload the object will be attached to the resource of container
and after that detached from it's old resource. At the attaching time
DETACHED_EOBJECT_TO_ID_MAP will not have the object so the new ID will
generated.
On 5/20/2011 5:24 PM, Ed Merks wrote:
> Rimvydas,
> I'm just taking your word on the behavior you're describing. In general
> when an object is removed from a resource that assigns UUIDs I'd expect
> this code in XMLResourceImpl to kick in:
> protected void detachedHelper(EObject eObject)
> if (useIDs())
> if (useUUIDs())
> *DETACHED_EOBJECT_TO_ID_MAP.put(eObject, getID(eObject));*
> if (idToEObjectMap != null && eObjectToIDMap != null)
> setID(eObject, null);
> super.detachedHelper(eObject);
> Similarly, when an object is attached, this kicks in:
> protected void attachedHelper(EObject eObject)
> super.attachedHelper(eObject);
> if (useIDs())
> String id = getID(eObject);
> if (useUUIDs() && id == null)
> if (assignIDsWhileLoading() || !isLoading())
> *id = DETACHED_EOBJECT_TO_ID_MAP.remove(eObject);*
> if (id == null)
> id = EcoreUtil.generateUUID();
> setID(eObject, id);
> else if (id != null)
> getIDToEObjectMap().put(id, eObject);
> I.e., generally the UUID is preserved when you move objects from one
> resource to another.
> I'm not sure if this is applicable for the case you have. You've not
> said anything about which resource implementation you're using...
> Rimvydas Vaidelis wrote:
>>> If you asked objectB.eResource() it would be resourceA so it's
>>> reasonable that resourceA would assign an ID for an object it contains.
>> [Rimvydas]: Is it OK that the object has another ID ?
Re: [EMF] UUID of EObject [message #686823 is a reply to message #686822] |
Fri, 20 May 2011 11:24   |
Rimvydas,
Comments below.
You mean during?
So it would be better to do these in the opposite order?
// If we're not setting a new resource, attach it to the old
container's resource.
if (resource == null)
oldContainerResource.attached(this);
// If we didn't detach it from an old resource already, detach
it from the old container's resource.
else if (oldResource == null)
oldContainerResource.detached(this);
We do generate do removes before adds:
notifications = eBasicRemoveFromContainer(notifications);
notifications = eBasicSetContainer(null, -1, notifications);
I wonder if changing it would be bad for anyone...
> generated.
>> Rimvydas,
>> if (useIDs())
>> if (useUUIDs())
>> if (useIDs())
>> if (id == null)
>> setID(eObject, id);
>>>> contains.
Re: [EMF] UUID of EObject [message #686824 is a reply to message #686823] |
Fri, 20 May 2011 11:46   |
Maybe you could save me some time and make a small test case showing the
problem so I can look in more detail? Likely you can use
EPackage.eClassifiers for the model instance as it supports proxy
resolving containment...
Ed Merks wrote:
> Rimvydas,
> Comments below.
> You mean during?
> detach it from the old container's resource.
>> will generated.
>>> Rimvydas,
>>> if (useIDs())
>>> if (useUUIDs())
>>> if (useIDs())
>>> if (id == null)
>>> setID(eObject, id);
>>>>> contains.
Re: [EMF] UUID of EObject [message #686826 is a reply to message #686823] |
Fri, 20 May 2011 12:33   |
Yes. I mean during the unload.
I have investigated the code in more detail. The object will be attached
to the resource of container but it will not be detached
from old resource. I think that it should be detached from old resource
before attaching it to the new resource.
On 5/20/2011 6:24 PM, Ed Merks wrote:
> Rimvydas,
> Comments below.
> You mean during?
> // If we're not setting a new resource, attach it to the old container's
> resource.
> // If we didn't detach it from an old resource already, detach it from
>> generated.
>>> Rimvydas,
>>> if (useIDs())
>>> if (useUUIDs())
>>> if (useIDs())
>>> if (id == null)
>>> setID(eObject, id);
>>>>> contains.
Re: [EMF] UUID of EObject [message #686827 is a reply to message #686824] |
Fri, 20 May 2011 12:39   |
I already have the unit test. Where can I place the zip ?
> Ed Merks wrote:
>> Rimvydas,
>> Comments below.
>> You mean during?
>>> will generated.
>>>> Rimvydas,
>>>> if (useIDs())
>>>> if (useUUIDs())
>>>> if (useIDs())
>>>> if (id == null)
>>>> setID(eObject, id);
>>>>>> contains.
Re: [EMF] UUID of EObject [message #686830 is a reply to message #686828] |
Sat, 21 May 2011 11:42  |
Rimvydas,
All other issues aside, detached not being called seems wrong. Please
open a bugzilla with this test case. (It has an unnecessary dependency
on CDO.)
> See the attached zip.
Re: [EMF] UUID of EObject [message #686996 is a reply to message #686816] |
Fri, 20 May 2011 09:16  |
Rimvydas,
Comments below.
> added into contents of resourceA and object objectB is added into
> contents of resourceB. objectA contains objectB. Both resources use
> UUIDs. After unload of resourceB all contained objects are attached to
> resourceA.
Yes, B will be a proxy.
> ID of objectB in resourceB before resourceB unload and ID of objectB
> in resourceA after resourceB unload are different.
I'm not sure it matters given that objectB is a proxy.
> Thanks in advance,
> Rimvydas
Re: [EMF] UUID of EObject [message #687000 is a reply to message #686817] |
Fri, 20 May 2011 10:10  |
Re: [EMF] UUID of EObject [message #687001 is a reply to message #686820] |
Fri, 20 May 2011 10:24  |
<html>
<head>
</head>
Rimvydas,<br>
<br>
general when an object is removed from a resource that assigns UUIDs
I'd expect this code in XMLResourceImpl to kick in:<br>
<blockquote><small> protected void detachedHelper(EObject eObject)</small><br>
<small> {</small><br>
<small> if (useIDs())</small><br>
<small> if (useUUIDs())</small><br>
<small> <b>DETACHED_EOBJECT_TO_ID_MAP.put(eObject,
getID(eObject));</b></small><br>
<small> }</small><br>
<br>
<small> if (idToEObjectMap != null && eObjectToIDMap !=
null)</small><br>
<small> setID(eObject, null);</small><br>
<small> </small><br>
<small> super.detachedHelper(eObject);</small><br>
</blockquote>
Similarly, when an object is attached, this kicks in:<br>
<blockquote><small> protected void attachedHelper(EObject eObject)</small><br>
<small> super.attachedHelper(eObject);</small><br>
<small> String id = getID(eObject);</small><br>
<small> if (useUUIDs() && id == null)</small><br>
<small> if (assignIDsWhileLoading() || !isLoading())</small><br>
<b><small> id = DETACHED_EOBJECT_TO_ID_MAP.remove(eObject);</small></b><br>
<small> if (id == null)</small><br>
<small> id = EcoreUtil.generateUUID();</small><br>
<small> setID(eObject, id);</small><br>
<small> else if (id != null)</small><br>
<small> getIDToEObjectMap().put(id, eObject);</small><br>
</blockquote>
resource to another.<br>
<br>
said anything about which resource implementation you're using...<br>
<br>
<br>
<blockquote cite="mid:ir5s8b$d0v$1@news.eclipse.org" type="cite">
<blockquote type="cite">If you asked objectB.eResource() it would be
resourceA so it's
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: [EMF] UUID of EObject [message #687002 is a reply to message #686821] |
generated.
> Rimvydas,
> if (useIDs())
> if (useUUIDs())
> if (useIDs())
> if (id == null)
> setID(eObject, id);
Re: [EMF] UUID of EObject [message #687003 is a reply to message #686822] |
Rimvydas,
Comments below.
You mean during?
> generated.
>> Rimvydas,
>> if (useIDs())
>> if (useUUIDs())
>> if (useIDs())
>> if (id == null)
>> setID(eObject, id);
>>>> contains.
Re: [EMF] UUID of EObject [message #687005 is a reply to message #686823] |
Ed Merks wrote:
> Rimvydas,
> Comments below.
> You mean during?
>> will generated.
>>> Rimvydas,
>>> if (useIDs())
>>> if (useUUIDs())
>>> if (useIDs())
>>> if (id == null)
>>> setID(eObject, id);
>>>>> contains.
Re: [EMF] UUID of EObject [message #687007 is a reply to message #686823] |
> Rimvydas,
> Comments below.
> You mean during?
> resource.
>> generated.
>>> Rimvydas,
>>> if (useIDs())
>>> if (useUUIDs())
>>> if (useIDs())
>>> if (id == null)
>>> setID(eObject, id);
>>>>> contains.
Re: [EMF] UUID of EObject [message #687008 is a reply to message #686824] |
> Ed Merks wrote:
>> Rimvydas,
>> Comments below.
>> You mean during?
>>> will generated.
>>>> Rimvydas,
>>>> if (useIDs())
>>>> if (useUUIDs())
>>>> if (useIDs())
>>>> if (id == null)
>>>> setID(eObject, id);
>>>>>> contains.
Re: [EMF] UUID of EObject [message #687013 is a reply to message #686828] |
Rimvydas,
on CDO.)
Current Time: Sun Jul 20 21:11:50 EDT 2025
Powered by FUDForum. Page generated in 0.08622 seconds
