[AGR] focus command generation [message #68013] |
Tue, 25 April 2006 12:28  |
Hello everybody.
I am wondering under what circumstances the focus command is generated
in a test macro. I always see it following an item-select command, but
not all item-select commands are followed by a focus one. Typically the
widgetId associated with the focus command is a Composite. Is this the
Composite underlying the widget (tree, list, etc.) in which the
selection is made?
TIA
B.
Re: [AGR] focus command generation [message #70139 is a reply to message #68635] |
Tue, 09 May 2006 10:47  |
You're right, the composite is the high level composite that contains the
underlying widget.
In the majority of cases, you actually don't need a focus command and I have
put in some code to try to avoid producing unneeded focus commands. Some
test cases, of course are dependent on a container to first be given focused
(e.g. giving the console view focus before using position based recording to
send user input). The majority of focus commands are generated when
explicitly a view/editor is given focus or an item is selected while the
view/editor is unfocused.
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:e2ngti$92q$1@utils.eclipse.org...
> Barbara Rosi-Schwartz wrote:
> > Hello everybody.
> > selection is made?
> > TIA
> > B.
> After a little playing around, I concluded that the Composite in the
> focus command is the highest level composite, f.i. in a View, it is the
> Composite that is passed into the view's createPartControl() method.
> Is this accurate?
> I still have the question about the circumstances under which the focus
> command is generated though...
> B.
FUDForum. Page generated in 0.03937 seconds
