Home » Modeling » OCL » Problem with OCL forall primitive
Problem with OCL forall primitive [message #68629] Thu, 12 March 2009 09:36 Go to next message
Hi all,
After some days spent in the newsgroups, I could finally make the example
presented in the paper "Implementing Model Integrity in EMF with MDT OCL"
work with Eclipse 3.4.
I extented the example with very simple classes A,B,C just to try to
better understand OCL (I'm new in both OCL & Eclipse):
B,C inherit from A
B has an association "c_list" with C (no containment)
C has attribute
- isOK
- isNotOK, derived as an OCL expression "not isOK" // indeed !
If in the OCL console (very helpful !), I execute:
self.c_list->exists(c | c.isOK)
or self.c_list->exists(c: C | c.isOK)
I get a correct result (i.e. if at least one C object in c_list is Ok, I
get "true").
The problem is with the forall primitive. I copy/paste the previous
command (with exists) and replace "exists" by "forall". I get:
=> self.c_list->forall(c: C | c.isOK)
I get the error message:
": self.c_list->forall(" misplaced construct(s)
If I use the alternative
=> self.c_list->forall(c | c.isOK)
1:25:1:25 "::" expected instead of "|"
Could someone tell me what is wrong ?
-- Olivier
Re: Problem with OCL forall primitive [message #68770 is a reply to message #68629] Sat, 14 March 2009 14:19 Go to previous messageGo to next message
Originally posted by: give.a.damus.gmail.com
Hi, Olivier,
It looks like you have simply misspelled the forAll iterator: it has a
capital "A."
The confusing error message is caused by the construction of the OCL
grammar: only iterator expressions have vertical bars ("|"), and the
set of iterators is fixed and know at the grammar level. So, "forall"
was assumed to be an operation, which would not have a bar in it.
HTH,
Christian
Olivier BERNARD wrote:
> Hi all,
> example presented in the paper "Implementing Model Integrity in EMF with
> MDT OCL" work with Eclipse 3.4.
> B,C inherit from A
> C has attribute - isOK
> get "true").
> -- Olivier
Re: Problem with OCL forall primitive [message #68924 is a reply to message #68770] Mon, 16 March 2009 04:24 Go to previous message
Ooops ! Shame on me !
-- Olivier
Previous Topic:OCL in Profile
Next Topic:[Announce] MDT OCL 1.3.0M6 is available
Current Time: Wed Oct 08 06:03:03 EDT 2025
Powered by FUDForum. Page generated in 0.04143 seconds
