Home » Language IDEs » Java Development Tools (JDT) » Cairo problem in Eclipse 3.6.2 under Linux(An exception occurs while trying to use advanced graphics with Cairo in Eclipse 3.6.2 under Linux)
Cairo problem in Eclipse 3.6.2 under Linux [message #685973] Tue, 21 June 2011 04:16 Go to next message
Hi, I couldn't find any appropriate topic for the issue being described bellow, so I added a new topic for this.
I was using eclipse 3.2.2 and JDK 1.5 for my SWT project which contained advanced graphics and was working under Linux. Cairo library is responsible for advanced graphics and X Windows under Linux and libcairo-swt.so library is required to have so SWT project could work with advanced graphics. The eclipse 3.2.2 had been extracted from eclipse-SDK-3.2.2-linux-gtk.tar.gz file and my project had been working fine regarding to advanced graphics part and cairo.
Recently, I have updated Eclipse to version 3.6.2 which has been extracted from eclipse-modeling-helios-SR2-incubation-linux-gtk.tar.gz file and updated JDK to 1.6.0_18. After doing so, the project couldn't been loaded and an exception is thrown:
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Unable to load graphics library [Cairo is required] (java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
no swt-cairo-gtk-3659 in java.library.path
no swt-cairo-gtk in java.library.path
/tmp/swtlib-32/libswt-cairo-gtk-3659.so: libcairo.so.2: cannot open shared object file: No such file or directory
Can't load library: /tmp/swtlib-32/libswt-cairo-gtk.so))
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
The jar version for supporting swt in extracted Eclipse 3.6.2 is org.eclipse.swt_3.6.2.v3659c.jar for Widows and org.eclipse.swt.gtk.linux.x86_3.6.2.v3659b.jar for Linux. libcairo-swt.so library also exists in extracted eclipse v.3.6.2. So it seems that everything should be ok, and the project should be run.
Any help with this is highly appreciated. Maybe some environment variable should be set, or something like that? Or maybe the dependency of libcairo-swt.so should be explicitly set up somewhere?
Thanks a lot,
Armine
Re: Cairo problem in Eclipse 3.6.2 under Linux [message #686016 is a reply to message #685973] Tue, 21 June 2011 07:43 Go to previous messageGo to next message
You want the SWT forum.
PW
Re: Cairo problem in Eclipse 3.6.2 under Linux [message #686067 is a reply to message #686016] Tue, 21 June 2011 11:05 Go to previous messageGo to next message
This means that I should place this topic in SWT forum?
Re: Cairo problem in Eclipse 3.6.2 under Linux [message #686094 is a reply to message #686067] Tue, 21 June 2011 13:03 Go to previous message
yes.
PW
Previous Topic:auto-code completion key-board shortcut
Next Topic:delete perspective
Current Time: Thu Jul 24 20:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.02837 seconds
