Home » Eclipse Projects » Memory Analyzer » Setting up workspace directory?(how to change the Memory Analyzer workspace directory)
Setting up workspace directory? [message #685998] Tue, 21 June 2011 06:50 Go to next message
I have the following problem. I try to lauch Eclipse Memory Analyzer from Citrix, and it gives me the following error:
An error has occurred. See the log file C:\Users\%username%\org.eclipse.mat.ui.rcp.MemoryAnalyzer_1.0.1.20...\Configuration\13086... .log
There it says the following:
!SESSION 2011-06-21 13:29:59.880 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fi_FI
Command-line arguments:  -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2011-06-21 13:30:00.767
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: The platform metadata area could not be written: C:\Windows\System32\workspace\.metadata. By default the platform writes its content
under the current working directory when the platform is launched.  Use the -data parameter to specify a different content area for the platform.
I assume the problem is that Memory Analyzer tries to use C:\Windows\System32\workspace\.metadata. as a workspace and can't write there. I'd like to change the workspace directory - how can I do that? I have absolutely no experience on Eclipse.
Re: Setting up workspace directory? [message #686004 is a reply to message #685998] Tue, 21 June 2011 07:08 Go to previous messageGo to next message
Try using the -data parameter like this:
MemoryAnalyzer -data <workspace_folder>
I haven't tried out myseld, but it was mentioned as working in this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=339647#c5
Re: Setting up workspace directory? [message #686011 is a reply to message #686004] Tue, 21 June 2011 07:27 Go to previous messageGo to next message
Thank you for your quick response Krum! Should I run the command from Command Prompt on the server where the Memory Analyzer is installed, or is there a file I could modify?
Re: Setting up workspace directory? [message #686013 is a reply to message #686011] Tue, 21 June 2011 07:36 Go to previous messageGo to next message
You can edit the MemoryAnalyzer.ini file.
Then put (on two separate lines) the -data parameter and the path, e.g.
-data
./work
Add this before the vm parameters, if any. Worked for me, let me know if this also helps you.
Re: Setting up workspace directory? [message #686019 is a reply to message #686013] Tue, 21 June 2011 07:45 Go to previous message
It works, thank you so much!
Previous Topic:Accessing an element in an Array and ArrayList
Next Topic:Memory Analyzer 1.1.0 is released
Current Time: Sat Jul 26 08:00:04 EDT 2025
Powered by FUDForum. Page generated in 0.08088 seconds
