Home » Archived » M2M (model-to-model transformation) » [ATL] Model Formalisms
[ATL] Model Formalisms [message #68408] |
Mon, 10 December 2007 01:38  |
Originally posted by: irbull.cs.uvic.ca
Hi everyone,
Does anyone know of any good references around model transformation
formalisms and in particular the formalisms of model transformed using
languages ``like'' ATL?
What I mean is, given a Model a and Model b (with MMa and MMb) and a
transformation T (from MMa to MMb), is there anything we can say about
MMb with respect to MMa. (Is it some sort of subset, etc...). I am
trying to understand if there is any way of determining formally if a
transformation is possible or impossible.
i.e. If MMb is a subset of MMa is it always possible? etc...
any tips or pointers would be great.
Ian
Re: [ATL] Model Formalisms [message #68441 is a reply to message #68408] |
Mon, 10 December 2007 04:35   |
Originally posted by: mikael.barbero.gmail.com
Hi Ian,
AFAIK, we can consider a transformation T as a partial function (total
or not) defined by the mapping written in ATL for instance. MMa and MMb
only are domain and codomain of this function. I don't think we can
consider more properties between MMb and MMa in the general case.
Hope this helps.
Mikael
Ian Bull wrote:
> Hi everyone,
> Ian
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Model Formalisms [message #68594 is a reply to message #68441] |
Mon, 10 December 2007 20:16   |
Thanks Mikaël,
Does it necessarily have to be a partial function (i.e. does each
element map to *at most* one element in the codomain). If we use the
impartive part of ATL, can this be broken (because we can always add a
body to a rule that calls other rules to create more than 1 new element)?
Sorry if this doesn't make sense, I have been doing these
transformations for a few years now, but haven't really thought about
them formally until recently.
thanks,
ian
Mikaël Barbero wrote:
> Hi Ian,
> Hope this helps.
> Best regards,
> Mikael
> Ian Bull wrote:
>> Hi everyone,
>> Thanks,
>> Ian
Re: [ATL] Model Formalisms [message #68602 is a reply to message #68516] |
Thanks Miguel,
These links are great!
cheers,
ian
Miguel Garcia wrote:
> Ian,
> Perhaps the following workshop (around verification and validation for MDSD)
> is a one-stop-show on current work in the field. Proceedings at
> http://www.modeva.org/2007/modevva07.pdf
> The charter of that workshop states:
> "... Major questions that cross-cut V&V and MDE include: Is the result of a
> transformation really what the user intended? Is the model correct with
> respect to the expected security, time, and structural constraints? What
> models can be used for validation or for verification? Does the
> implementation, generated after several model transformations, conform to
> the initial requirements? ..."
> If I have to choose one paper, my pick is:
> Analysis of Model Transformations via Alloy
> Kyriakos Anastasakis, Behzad Bordbarand and Jochen M. Küster
> (pp. 47--56)
> Miguel
> "Ian Bull" <irbull@cs.uvic.ca> wrote in message
> news:fjimsk$8mm$1@build.eclipse.org...
>> Hi everyone,
>> transformation T (from MMa to MMb), is there anything we can say about MMb
>> with respect to MMa. (Is it some sort of subset, etc...). I am trying to
>> understand if there is any way of determining formally if a transformation
>> Thanks,
>> Ian
Re: [ATL] Model Formalisms [message #68721 is a reply to message #68594] |
Tue, 11 December 2007 05:12   |
Ian,
In fact, I was a bit simplifying the problem. First of all, I only
consider *declarative* part of ATL (imperative part only is for some
very specific issues that can not be deal with declarative part and is
not very interesting for reasoning on transformations).
I was also simplifying the case where a rule match only 1 model element
(despite ATL can match more than one) and create one element. I agree
this is over simplification.
If we consider declarative ATL in the large (n,n), we are facing a n-ary
relation. This property may not be very interesting by itself and may
not allow to extract derived properties from the transformation.
I hope this will be helpful to you.
Mikael
Ps: It makes sense ;) but i'm not very formally thinking on model
transformations neither.
Ian Bull wrote:
> Thanks Mikaël,
> thanks,
> ian
>> Hi Ian,
>> MMb only are domain and codomain of this function. I don't think we
>> can consider more properties between MMb and MMa in the general case.
>> Hope this helps.
>> Best regards,
>> Mikael
>> Ian Bull wrote:
>>> Hi everyone,
>>> using languages ``like'' ATL?
>>> about MMb with respect to MMa. (Is it some sort of subset, etc...).
>>> I am trying to understand if there is any way of determining formally
>>> if a transformation is possible or impossible.
>>> Thanks,
>>> Ian
Re: [ATL] Model Formalisms [message #68803 is a reply to message #68721] |
Tue, 11 December 2007 10:45   |
Thanks again.
I assumed you were thinking the declarative part, but I just wanted to
make sure.
The reason I was asking is because I am just finishing my dissertation
on using MDE to create interactive visualizations of information. I
have several MM for for viewers (graphs, charts, heatmaps, etc...) and
using model transformations I can specify how the visualization should
work. I know this works in practice, but I wanted to give some advice
on how well it works in theory (can this always be done, etc...). There
are some cases when I have to use operational (imperative)
transformations, and it usually is a result of needing multiple elements
in the visualizations for a single source.
Thanks for all your help. I did find some good links on this stuff as
well, I will get them organized and post them here in case others have
questions too.
ian
> Ian,
> Best regards,
> Mikael
> Ian Bull wrote:
>> Thanks Mikaël,
>> thanks,
>> ian
>>> Hi Ian,
>>> (total or not) defined by the mapping written in ATL for instance.
>>> MMa and MMb only are domain and codomain of this function. I don't
>>> think we can consider more properties between MMb and MMa in the
>>> general case.
>>> Hope this helps.
>>> Best regards,
>>> Mikael
>>> Ian Bull wrote:
>>>> Hi everyone,
>>>> etc...). I am trying to understand if there is any way of
>>>> determining formally if a transformation is possible or impossible.
>>>> Thanks,
>>>> Ian
Re: [ATL] Model Formalisms [message #68916 is a reply to message #68803] |
Tue, 11 December 2007 12:49   |
Ian,
That topic has to do with another ongoing PhD blogged at
http://visual-languages.blogspot.com/
And there's a very short (2-page) paper also touchign that topic,
"Mapping visual notations to MOF compliant models with QVT Relations"
The URL is http://portal.acm.org/citation.cfm?id=1244228
So I guess we all want to read your dissertation once it's ready :-)
Miguel
news:475EB085.8030502@cs.uvic.ca...
> Thanks again.
> make sure.
> The reason I was asking is because I am just finishing my dissertation on
> using MDE to create interactive visualizations of information. I have
> several MM for for viewers (graphs, charts, heatmaps, etc...) and using
> model transformations I can specify how the visualization should work. I
> know this works in practice, but I wanted to give some advice on how well
> it works in theory (can this always be done, etc...). There are some
> cases when I have to use operational (imperative) transformations, and it
> usually is a result of needing multiple elements in the visualizations for
> a single source.
> questions too.
> Cheers,
> ian
> Mika
Re: [ATL] Model Formalisms [message #69017 is a reply to message #68916] |
Tue, 11 December 2007 17:50  |
Thanks Miguel,
This is a great reference.
I am doing my research in a group focused more on Information
Visualization than MD(E/A/D). It has been a good battle learning all
the modeling technologies, but a lot of fun. My primary research
objective is to determine how MD(E/A/D) can be used in the creation and
customization of interactive information visualization.
For someone learning modeling on their own, newsgroups like this have
been a great resource.
cheers,
ian
> Ian,
> Miguel
>> Thanks again.
>> make sure.
>> a single source.
>> questions too.
>> Cheers,
>> ian
>>> Ian,
>>> consider *declarative* part of ATL (imperative part only is for some very
>>> specific issues that can not be deal with declarative part and is not
>>> relation. This property may not be very interesting by itself and may not
>>> Best regards,
>>> Mikael
>>> Ian Bull wrote:
>>>> Thanks Mikaël,
>>>> element)?
>>>> thanks,
>>>> ian
>>>>> Hi Ian,
>>>>> Hope this helps.
>>>>> Best regards,
>>>>> Mikael
>>>>> Ian Bull wrote:
>>>>>> Hi everyone,
>>>>>> Thanks,
>>>>>> Ian
Current Time: Sat Jul 19 01:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.04339 seconds
