How to run the code generator from another eclipse instance [message #685871] |
Mon, 20 June 2011 09:13  |
I was able to follow a great tutorial for building out an Xtext grammar, as well
as defining code generation templates. I was able to test this all out and it worked
perfect.
Now in Eclipse, when I right click on my grammar project and select 'Run As' -> 'Eclipse Application', another instance of eclipse starts. From there I can create an instance of my grammar and I can see the syntax hightlight, outline etc.. No problems here. However, I was wondering how I could get the code generator workflow to run from this spawned Eclipse instance? All of the code generation material is back in the other eclipse instance, where the grammar was defined.
Does my question make sense?
Thank you
FUDForum. Page generated in 0.05702 seconds
