Home » Archived » BIRT » td.valign=top everytime. Howto set to bottom?(ReportDesigner (2.5.2) shows bottom but Preview not.)
td.valign=top everytime. Howto set to bottom? [message #684911] Thu, 16 June 2011 09:16 Go to next message
I format a text-element within a grid and I want to set a valign=bottom.
If I do that (via birt-styple xor css-style) than:
* looks the ReportDesigner very well (@see reportdesinger-screenshot)
* but if I preview my report into browser (firefox/chrome/safari) than all valign=top (@see preview-screenshot)
* and if I export my report to pdf than I got the same problem.
I want to configure this via css-file. What must I do? ( @see my.css what not worked at runtime)
* I added valign and vertical-align on many selectors.
I use birt-2.5.2(gallileo) on macosx (leopard) with java-1.6
Many THANKS for each reply.
[Updated on: Thu, 16 June 2011 09:27] by Moderator
(no subject) [message #684956 is a reply to message #684911] Thu, 16 June 2011 09:51 Go to previous messageGo to next message
This looks like a bug. Can you please log a bugzilla entry for this?
Jason
> Before, many THANKS for each reply.
(no subject) [message #684959 is a reply to message #684911] Thu, 16 June 2011 09:51 Go to previous messageGo to next message
Jason
Re: (no subject) [message #684970 is a reply to message #684956] Thu, 16 June 2011 10:39 Go to previous messageGo to next message
Thanks for this quick reply.
I've looked to birt-bug-repo and found this: bugs.eclipse.org/bugs/show_bug.cgi?id=344938
* Its looks like same problem.
Re: (no subject) [message #684983 is a reply to message #684970] Thu, 16 June 2011 10:50 Go to previous messageGo to next message
In 2.6.2 I got this to work in pdf just not html. It may be good to add
a sample report for the devs on that bugzilla entry.
Jason
Re: (no subject) [message #685305 is a reply to message #684983] Fri, 17 June 2011 04:36 Go to previous messageGo to next message
Jason Weathersby wrote on Thu, 16 June 2011 10:50
Many thanks to Jason
* I will upgrade my birt-runtime-dependency to 2.6.2 and test it.
* And I will try to seperate the problem to a single report for bugzilla-ticket.
Re: (no subject) [message #685429 is a reply to message #685305] Fri, 17 June 2011 09:48 Go to previous messageGo to next message
Thanks for doing this.
Jason
>> add a sample report for the devs on that bugzilla entry.
> bugzilla-ticket.
Re: (no subject) [message #685845 is a reply to message #685429] Mon, 20 June 2011 07:04 Go to previous messageGo to next message
I added a sample report to birt-bug-report(ID=344938). (same files I attached here)
Re: css-quickfix [message #685853 is a reply to message #685845] Mon, 20 June 2011 07:28 Go to previous messageGo to next message
A quickfix for the failor:
* define css-selector: text-notop
.text-notoyp{padding-top: 20px}
* import/reload css-file
* apply 'text-notop' style to related element
Re: css-quickfix [message #686085 is a reply to message #685853] Tue, 21 June 2011 12:02 Go to previous message
Jason
Previous Topic:chart engine API questions
Next Topic:Passing oracel funtions to BIRT report
Current Time: Wed Jul 23 11:59:12 EDT 2025
Powered by FUDForum. Page generated in 0.94582 seconds
