Home » Modeling » TMF (Xtext) » [Xtext] Xtext conflits with Eclipse ANTLR IDE plugin
[Xtext] Xtext conflits with Eclipse ANTLR IDE plugin [message #684027] Tue, 14 June 2011 17:37 Go to next message
I have tried to install ANTLR IDE in my Eclipse environment
http://antlrv3ide.sourceforge.net/
since then I cannot use Xtext anymore, as all my MWE2/XTEXT generator flow end up with the folloing error :
error(10): internal error:
.../fr.irisa.cairn.gecos.s2s4hls.pragmas.xtext/src-gen/fr/irisa/cairn/gecos/s2s4hls/pragmas/parser/antlr/internal/InternalS2S4HSLPragma.g
: java.lang.SecurityException: class "org.antlr.runtime.RecognizerSharedState"'s signer information does not match
signer information of other classes in the same package.
I first uninstalled the ANTLR plugin but it did not solve the problem, then I reinstalled a fresh Eclipse distribution
without the Antlr plugin without more success, then rechecked out from my SVN an older version of my DSL project and it
would still not work.
The only solution I found was to switch to a new workspace and re-checkout my xtext project in this new workspace to
make it work.
Can someone shed some lights on this error, and how to dela with it ?
Thanks a lot,
Steven
Re: [Xtext] Xtext conflits with Eclipse ANTLR IDE plugin [message #684149 is a reply to message #684027] Wed, 15 June 2011 00:58 Go to previous messageGo to next message
Hi Steven
I think this is the same conflict that I've seen after checking out
Xtext plugins as projects with sources.
Xtext, or more likely com.google.inject, cannot co-exist as both
resource and plug-in.
I'd like to know the answer too. It makes debugging harder than it
should be.
Ed Willink
On 14/06/2011 22:37, Steven Derrien wrote:
> not match signer information of other classes in the same package.
> then I reinstalled a fresh Eclipse distribution without the Antlr
> version of my DSL project and it would still not work.
> re-checkout my xtext project in this new workspace to make it work.
> Thanks a lot,
> Steven
Re: [Xtext] Xtext conflits with Eclipse ANTLR IDE plugin [message #684773 is a reply to message #684027] Thu, 16 June 2011 04:00 Go to previous messageGo to next message
Hi Steven,
Xtext relies heavily on the internals of Antlr. That's why we require a
very specific version of the parser generator / parser runtime (3.2.0).
This bundle is shipped with Eclipse Xtext as a signed bundle. If you
have another antlr version installed and this one will be picked by
accident, chances are that the OSGi environment tries to load a class
from one bundle and another class from the other bundle, both classes
are in the same package but the second on is not signed. It is not
allowed to have signed classes and unsigned classes in the same package.
That's why you see the SecurityException.
You could try to be more explicit with the bundle dependencies. Don't
know whether that will help, though.
Sebastian
Am 14.06.11 23:37, schrieb Steven Derrien:
> then I reinstalled a fresh Eclipse distribution without the Antlr plugin
> Thanks a lot,
> Steven
Re: [Xtext] Xtext conflits with Eclipse ANTLR IDE plugin [message #685597 is a reply to message #684773] Fri, 17 June 2011 16:28 Go to previous message
Thks for the help, I will use separate Eclipse workspace/versions to deal with the issue.
Steven
On 16/06/2011 02:00, Sebastian Zarnekow wrote:
> Hi Steven,
> Xtext relies heavily on the internals of Antlr. That's why we require a very specific version of the parser generator /
> This bundle is shipped with Eclipse Xtext as a signed bundle. If you have another antlr version installed and this one
> will be picked by accident, chances are that the OSGi environment tries to load a class from one bundle and another
> class from the other bundle, both classes are in the same package but the second on is not signed. It is not allowed to
> have signed classes and unsigned classes in the same package. That's why you see the SecurityException.
> You could try to be more explicit with the bundle dependencies. Don't know whether that will help, though.
> Regards,
> Sebastian
Previous Topic:A question about Containers
Next Topic:[Xtext2] Xtend RichStrings: Where is «REM»«ENDREM»?
Current Time: Sat Jul 19 01:00:25 EDT 2025
Powered by FUDForum. Page generated in 0.05377 seconds
