Home » Eclipse Projects » JFace » Problem with showing ProgressMonitorDialog from another modal dialog
Problem with showing ProgressMonitorDialog from another modal dialog [message #685418] Fri, 17 June 2011 09:27 Go to next message
I have this code called when pressing an OK button on a dialog:
IRunnableWithProgress connecting = new IRunnableWithProgress {...};
ProgressMonitorDialog progressDialog = new ProgressMonitorDialog(getShell());
progressDialog.setCancelable(true);
progressDialog.run(true, true, connecting);
The ProgressMonitorDialog does appear and shows text sent from the IRunnableWithProgress, but it doesn't have a "Cancel" button. In addition, the image on the left side appears only about half the time. What could be the reason? Initially I thought there could be a general problem with showing one modal dialog over another, but calling super.okPressed() first didn't help.
[Updated on: Fri, 17 June 2011 09:28] by Moderator
Re: Problem with showing ProgressMonitorDialog from another modal dialog [message #699484 is a reply to message #685418] Thu, 21 July 2011 12:01 Go to previous message
Hi Alexey,
try removing:
You already set cancelable=true as parameter in the run method:
public void run(boolean fork, boolean cancelable,IRunnableWithProgress runnable) throws InvocationTargetException, InterruptedException
Mark
Previous Topic:Is a fixed height view possible?
Next Topic:Problem setup databinding with TableViewer
Current Time: Fri Jul 25 23:37:55 EDT 2025
Powered by FUDForum. Page generated in 0.06951 seconds
