Home » Archived » BIRT » Drill-Through
Drill-Through [message #677758] Thu, 09 June 2011 06:20 Go to next message
Hi All,
Now I am trying to use Drill-Through option in Hyperlink.
i have two reports. i am trying to connect one report using drill-through.
Its working fine in BIRT.
When i deployed the report i am getting error when i click the hyperlink saying that "Keys Manipulated"
i.e. First report is working fine. it displays correct records. in that records, one column is having hyperlink to connect another report.
here is the problem.
Can you help me on this.
when i click the hyperlink, the below url is coming,
"http://192.168.1.30/birt/run?__report=D%3A\jboss_51\server\digite\deploy\birt.war\Reports\12201_12140_new_report_jdbc.rptdesign&__format=html&SearchParam=JEYINUL+SECURITY+SAMPLE+TESTING&__locale=en_US&__svg=false&__designer=false&__pageoverflow=0&__masterpage=true&__bookmark=JEYINUL+SECURITY+SAMPLE+TESTING&__istoc=true"
Jeyinul.
[Updated on: Thu, 09 June 2011 06:38] by Moderator
Re: Drill-Through [message #680746 is a reply to message #677758] Thu, 09 June 2011 12:00 Go to previous messageGo to next message
Jeyinul,
I did not see any issues with the master report. Any chance you could
build the master and detail report using the sampledb and produce the
problem. That way I can run and debug the report.
Jason
On 6/9/2011 6:20 AM, jeyinul wrote:
> Hi All,
> Jeyinul.
Re: Drill-Through [message #681952 is a reply to message #680746] Fri, 10 June 2011 02:10 Go to previous messageGo to next message
Hi Jason,
I have tried using Sample database.
But I am getting same error. when i click the hyperlink.
Here i attached the report. Please check and let me know.
Thanks.
Jeynul.
[Updated on: Fri, 10 June 2011 02:21] by Moderator
Re: Drill-Through [message #682188 is a reply to message #681952] Fri, 10 June 2011 11:00 Go to previous messageGo to next message
Can you attach the detail report as well?
Jason
On 6/10/2011 2:10 AM, jeyinul wrote:
> Hi Jason,
> Thanks.
> Jeynul.
Re: Drill-Through [message #683154 is a reply to message #682188] Mon, 13 June 2011 01:47 Go to previous messageGo to next message
Hi Jason,
Please find the attachment foe detail report.
Jeyinul.
  • Attachment: RPT File.txt
    (Size: 10.05KB, Downloaded 400 times)
Re: Drill-Through [message #683308 is a reply to message #683154] Mon, 13 June 2011 09:36 Go to previous messageGo to next message
Jeyinul
Do you have the detail report that uses the sample db? If so please
post it. I want to be able to produce the issue. Where are you
deploying the reports?
Jason
On 6/13/2011 1:47 AM, jeyinul wrote:
> Hi Jason,
> Jeyinul.
Re: Drill-Through [message #683627 is a reply to message #683308] Tue, 14 June 2011 02:15 Go to previous messageGo to next message
Hi Jason,
We are using a tool which is called "DIGITE"
Generally we need RPT file and reg.jsp file to generate a report.
RPT FILE IS POSTED ABOVE.
The below code, i am using.
1.IN reg.jsp,
<!-- 1. Include com.tufan.digite.utils.webappsecurityutils.* in your JSP -->
<%@ page import ="com.tufan.digite.utils.webappsecurityutils.*"%>
<%@ page import ="com.tufan.digite.web.beans.*"%>
<%@ page import ="com.tufan.digite.dataobjects.*"%>
WebSecHelper.checkIfSubmitIsGenuine(request, response,application);
<html>
<title> Table </title>
<body>
<form name = "j">
<TABLE width ="350" align = "center" BORDER="1" BGCOLOR="#F9A89F" height="60">
<tr>
<td> Project Name: <input type="text" name="SearchParam" /> </td>
</tr>
</table>
</form>
</body>
</html>
Plz check and let me know.
Jeyinul
Re: Drill-Through [message #683840 is a reply to message #683627] Tue, 14 June 2011 09:40 Go to previous messageGo to next message
Jeyinul,
I am not familiar with that tool. Have you posted the question on their
forums?
Jason
On 6/14/2011 2:15 AM, jeyinul wrote:
> Hi Jason,
> 1.IN reg.jsp,
> <html>
> <body>
> <form name = "j">
> height="60">
> <tr>
> </tr>
> </table>
> </form>
> </body>
> </html>
> Jeyinul
Re: Drill-Through [message #685230 is a reply to message #683840] Fri, 17 June 2011 00:32 Go to previous messageGo to next message
Hi Jason,
I am getting following message in console while running the report.
Can you please try to solve my problems,
ignoring unsupported operation exception thrown by ODA driver (org.eclipse.birt.report.data.oda.jdbc) cannot set query specification before prepare.
EXCEPTION IN WEBSECHELPER.validatekeyparametersForURL() java.lang.exception:Keys Manipulated
Jeyinul.
Re: Drill-Through [message #685428 is a reply to message #685230] Fri, 17 June 2011 09:47 Go to previous message
Jeyinul,
I would like to help, but I do not know how the DIGITE package is
integrating BIRT.
Jason
On 6/17/2011 12:32 AM, jeyinul wrote:
> Hi Jason,
> before prepare.
> Regards,
> Jeyinul.
Previous Topic:dynamic data set from different table different feilds, according to parameter
Next Topic:SQL Query changes take long
Current Time: Sat Jul 26 16:54:30 EDT 2025
Powered by FUDForum. Page generated in 0.22029 seconds
