Home » Modeling » TMF (Xtext) » [Xtext 2.0 / Xtend2] Missing methods in API
[Xtext 2.0 / Xtend2] Missing methods in API [message #684527] Wed, 15 June 2011 14:33 Go to next message
I am using the generated Xtend generator class (implements IGenerator). This uses an JavaIOFileSystemAccess class for actual generation of files. The JavaIOFileSystemAccess has a method to set the output path, that I use.
Later in the generation I want to retrieve the output path from the JavaIOFileSystemAccess object, but there is no getter for the output path. I need this to find out whether files already exist and add special handling for that.
Is there a way to get the output path from the JavaIOFileSystemAccess, or do I need to put an enhancement request in?
Jos
Re: [Xtext 2.0 / Xtend2] Missing methods in API [message #684802 is a reply to message #684527] Thu, 16 June 2011 05:00 Go to previous messageGo to next message
On 06/15/2011 08:33 PM, Jos Warmer wrote:
> that I use.
> Jos
Concerning this issue: how can you modify the default behavior of the
generator so that it uses a different target folder? I mean the
behavior of the generation that is triggered automatically when you save
a file of your DSL (and it uses the src-gen by default).
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: [Xtext 2.0 / Xtend2] Missing methods in API [message #684804 is a reply to message #684527] Thu, 16 June 2011 05:24 Go to previous messageGo to next message
Am 6/15/11 8:33 PM, schrieb Jos Warmer:
> that I use.
> Jos
You can either add an enhancement request or you could add a binding to
IFileSystemAccess, i.e. use your own implementation.
Note that within Eclipse a different implmentation is used, which uses
Eclipse's file system API.
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: [Xtext 2.0 / Xtend2] Missing methods in API [message #684806 is a reply to message #684802] Thu, 16 June 2011 05:24 Go to previous message
Am 6/16/11 11:00 AM, schrieb Lorenzo Bettini:
>> Hi,
>> that I use.
>> Jos
> thanks in advance
> Lorenzo
You'll have ot override
org.eclipse.xtext.builder.JavaProjectBasedBuilderParticipant or use your
own builder participant.
Sven
Previous Topic:Duplicate Names Across Files
Next Topic:tree structure traversal
Current Time: Fri Jul 18 17:38:29 EDT 2025
Powered by FUDForum. Page generated in 1.07932 seconds
