Home » Archived » BIRT » Use output of a dataset into another dataset(How to use output of a dataset into another dataset)
icon5.gif  Use output of a dataset into another dataset [message #684386] Wed, 15 June 2011 10:10 Go to next message
I have to create a report using output of 2 separate databases.
I have
Database A at system One
Database B at system Two
Table "Details" in database B having relationship with table "User" in database A
Table Details may have lakhs of records.
Schema of table "User"
Id
EncryptedId
UserName
etc.
Schema of table "Details"
EncryptedId
Address
EncryptedId is the only field showing relationship between both tables.
I have to show the following in my report, user will give his Id
Information from table User of Database A
Information from table "Details" of Database B
My problem is to fetch EncryptedId first from table "User" then use that in query fetching data from table "Details".
Please suggest the solution or let me know if my question is not clear.
Krishan Babbar
Re: Use output of a dataset into another dataset [message #684439 is a reply to message #684386] Wed, 15 June 2011 10:47 Go to previous messageGo to next message
Can you use a joint dataset?
Jason
> I have
> database A
> Id EncryptedId
> UserName
> etc.
> EncryptedId
> Address
> Information from table User of Database A +
> Thanks
> Krishan Babbar
Re: Use output of a dataset into another dataset [message #684735 is a reply to message #684439] Thu, 16 June 2011 02:25 Go to previous messageGo to next message
Yes Jason,
I can use Joint Dataset, but as per my understanding with Joint Dataset, I need to create total 3 datasets as given below.
1. First Dataset fetch data from table User for given Id
2. Second Dataset will fetch all the data from table Details.
3. Third would be Joint Dataset, which will fetch the required data
Now problem is second dataset. In this dataset it will first fetch all the records which can be in lakhs or more, which ultimately decrease the performance. So i want to avoid this performance degradation.
Am I right?
what you suggest as an alternative?
Krishan Babbar
Re: Use output of a dataset into another dataset [message #684925 is a reply to message #684735] Thu, 16 June 2011 09:35 Go to previous message
If you are trying to display user/details, you could make two datasets
one for users and one for details. The details dataset can be
parameterized like select * from details where userid = ?. Then add a
table to the report for users. Then nest the details table in the users
table. You can then select binding table for nested table and set the
value of the parameter for the query to the details. Does this make
sense. This will perform more queries though.
Jaosn
On 6/16/2011 2:25 AM, Krishan Babbar wrote:
> Yes Jason,
> Am I right?
> Thanks
> Krishan Babbar
Previous Topic:SLF4J Support
Next Topic:use jndi with connection profile ?
Current Time: Wed Jul 23 11:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.48053 seconds
