Home » Eclipse Projects » JavaServer Faces » Accessing Bean Functions and Names from xhtml page
Accessing Bean Functions and Names from xhtml page [message #682267] Fri, 10 June 2011 14:15 Go to next message
Hello everyone,
I am kind of new with jsf, and I also got this working before, but now its not working anymore. I tried to search here inside the forum but I am not sure about the exact wording or name of the function.
If I have a bean (TestBean.java) and if I am inside an xhtml page and I type something like
<h:outputText value="#{TestBean.
I want all available methods to display (after ctrl+space), but this isn't working anymore.
What is the name of this function? Is that called tab-completion or code-completion?
Many greetings,
Hauke
PS: Using JSF 2.0 and the latest eclipse version
Re: Accessing Bean Functions and Names from xhtml page [message #682275 is a reply to message #682267] Fri, 10 June 2011 14:32 Go to previous messageGo to next message
On 10-Jun-11 12:15, Hauke wrote:
> Hello everyone,
> type something like
> code-completion?
> Many greetings,
> Hauke
In Eclipse it's called "Content Assist". You're on the right track.
Re: Accessing Bean Functions and Names from xhtml page [message #682470 is a reply to message #682275] Sat, 11 June 2011 03:01 Go to previous messageGo to next message
thanks for the information. But I think that content assist is if you enter
<h:
And you get all possible tags starting with <h:
That is working fine, but the accessing of the beans isn't working. Does anyone has
an idea?
Thanks and many greetings,
Hauke
Re: Accessing Bean Functions and Names from xhtml page [message #684508 is a reply to message #682470] Wed, 15 June 2011 13:24 Go to previous messageGo to next message
Both forms are known as content assist, but let's not dwell on that. Have you declared the Java class as a Managed Bean named "TestBean"?
Re: Accessing Bean Functions and Names from xhtml page [message #684599 is a reply to message #684508] Wed, 15 June 2011 18:07 Go to previous messageGo to next message
May or may not be the issue here: Content assist only works with managed beans defined in the faces-config.xml file; JSF 2.0 managed beans declared by the @ManagedBean annotation are not recognized as such by the eclipse JSF tooling (hence content assist fails) - see bugs [306428, 323709, ...].
I've been hoping that the new Indigo release would fix this, but it appears these bugs are "deferred for future" resolution.
Re: Accessing Bean Functions and Names from xhtml page [message #684601 is a reply to message #684599] Wed, 15 June 2011 18:18 Go to previous messageGo to next message
Sorry, I missed the JSF 2.0 connection - Richard is, of course, absolutely correct. We didn't have the resources available to make the necessary enhancements in the Indigo timeframe. We do welcome contributions to the project, though.
Re: Accessing Bean Functions and Names from xhtml page [message #684639 is a reply to message #684601] Wed, 15 June 2011 20:51 Go to previous messageGo to next message
Ian Trimble wrote on Wed, 15 June 2011 18:18
.... We do welcome contributions to the project, though.
If you or anyone would take the time to get me up to speed on:
a) how to setup eclipse dev env for eclipse/JSF
b) generally where to start
I'd be happy to take a look at the code & see if I can come up with a solution to contribute when/if/as my schedule opens up a bit. Busy busy busy Smile
Just FYI, while it's been a while, I do have some history with Apache open source projects (axis, commons-logging & commons-discovery).
<ras>
Re: Accessing Bean Functions and Names from xhtml page [message #686680 is a reply to message #684639] Wed, 22 June 2011 13:36 Go to previous messageGo to next message
Since JSF Tools is a sub-project of WTP, a good place to start would be http://www.eclipse.org/webtools/development/. The way I approach development is to grab a recent version of WTP and pre-reqs, setup a CVS connection (until you're a committer, you can get read-only anonymous access - see links from the WTP dev page, above), and get JSF plug-ins that you are interested in developing. Then, you can contribute any work by logging a bug or enhancement request against JSF Tools and attaching a patch; we do our best to try to find time to look at contributed patches.
Re: Accessing Bean Functions and Names from xhtml page [message #690173 is a reply to message #686680] Wed, 29 June 2011 02:11 Go to previous messageGo to next message
thanks for the question
i was coming here to ask this very question (find a solution)
i have added annotations to my classes as per JSF2 docs - but i find that Eclipse Indigo does not recognise my classes when trying to use "Content Assist",
the solution while developing seems to use the "faces-config.xml" to register my classes - when the "Content Assist" starts to work as expected.
has this been filled as a bug or an enhancement anywhere?
thanks a lot
Re: Accessing Bean Functions and Names from xhtml page [message #690518 is a reply to message #690173] Wed, 29 June 2011 12:12 Go to previous messageGo to next message
Yes, a number of times, in Bugzilla. Here's one that I found quite quickly: https://bugs.eclipse.org/bugs/show_bug.cgi?id=306428.
Re: Accessing Bean Functions and Names from xhtml page [message #690778 is a reply to message #690518] Thu, 30 June 2011 04:10 Go to previous messageGo to next message
thanks Ian,
lets hope support is added soon(ish)
Re: Accessing Bean Functions and Names from xhtml page [message #1784916 is a reply to message #682267] Thu, 05 April 2018 13:58 Go to previous messageGo to next message
Go: Help -> Install New Software
ADD: download.jboss.org/jbosstools/oxygen/development/updates/
Expand-> JBoss Web and Java EE Development
And select: Jboss Tools JSF
This should fix the problem...
Re: Accessing Bean Functions and Names from xhtml page [message #1869003 is a reply to message #1784916] Mon, 29 July 2024 04:15 Go to previous message
We are in 2024 and the error persists.
I work with JDF2.3 and beans annotated with @Component @Scope("request").
Eclipse 2022-03
There is no solution?
Thank you.
Previous Topic:Jsf Support for JSP
Current Time: Wed Jul 23 13:25:43 EDT 2025
Powered by FUDForum. Page generated in 0.26918 seconds
