p2 prestartupdate example fails [message #683991] |
Tue, 14 June 2011 16:16  |
I am having problems with the prestartupdate example (as mentioned on the equinox p2 wiki). I am using eclipse 3.6.2
cvs -d ':pserver:anonymous@dev.eclipse.org/cvsroot/rt' co org.eclipse.equinox/p2/examples/org.eclipse.equinox.p2.examples.rcp.prestartupdate
I import the project into my workspace and run prestartupdate.product
The application starts but I get the following error log. One of the problems is nullpointer exception in UpdateOperation.getInstalledIUs.
Any help would be greatly appreciated.
Timm
!SESSION 2011-06-14 16:03:19.640 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
Framework arguments: -product org.eclipse.equinox.p2.examples.rcp.prestartupdate.product
Command-line arguments: -product org.eclipse.equinox.p2.examples.rcp.prestartupdate.product -data C:\timm\src\forma/../runtime-prestartupdate.product -dev file:C:/timm/src/forma/.metadata/.plugins/org.eclipse.pde.core/prestartupdate.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.equinox.ds 4 0 2011-06-14 16:03:20.812
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.ds_1.2.1.R36x_v20100803 [25]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1301)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!ENTRY org.eclipse.equinox.ds 4 0 2011-06-14 16:03:20.890
!MESSAGE
!STACK 0
at org.eclipse.osgi.framework.internal.core.StartLevelManager.setBundleSL(StartLevelManager.java:695)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:437)
!ENTRY org.eclipse.osgi 2 0 2011-06-14 16:03:20.906
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-06-14 16:03:20.906
!MESSAGE Bundle reference:file:/C:/tools/eclipse3.6.2/plugins/org.eclipse.equinox.ds_1.2.1.R36x_v20100803.jar was not resolved.
!SUBENTRY 2 org.eclipse.equinox.ds 2 0 2011-06-14 16:03:20.906
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.pool_1.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.threadpool_1.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.ref_1.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.event_1.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.hash_1.0.0.
!MESSAGE Missing imported package org.eclipse.equinox.internal.util.timer_1.0.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.equinox.ds_1.2.1.R36x_v20100803 [25] was not resolved.
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:477)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.equinox.p2.examples.rcp.prestartupdate.ApplicationWorkbenchWindowAdvisor.postWindowOpen(ApplicationWorkbenchWindowAdvisor.java:94)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1338)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:798)
at org.eclipse.ui.internal.Workbench$24.runWithException(Workbench.java:1235)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.equinox.p2.examples.rcp.prestartupdate.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
at org.eclipse.equinox.p2.operations.UpdateOperation.getInstalledIUs(UpdateOperation.java:296)
at org.eclipse.equinox.p2.operations.UpdateOperation.prepareToResolve(UpdateOperation.java:281)
at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:112)
at org.eclipse.equinox.p2.examples.rcp.prestartupdate.P2Util.checkForUpdates(P2Util.java:49)
at org.eclipse.equinox.p2.examples.rcp.prestartupdate.ApplicationWorkbenchWindowAdvisor$1.run(ApplicationWorkbenchWindowAdvisor.java:76)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
[Updated on: Tue, 14 June 2011 18:03] by Moderator
FUDForum. Page generated in 0.08526 seconds
