Home » Archived » BIRT » Automated execution of reports
Automated execution of reports [message #683747] Tue, 14 June 2011 07:00 Go to next message
hello
we have to generate a report once it has designed will have to run an automated process. That is, you have to invoke the execution of using BIRT command line, running reports on a scheduled basis. Can you send me an example of how to set this invocation?
thanks
Re: Automated execution of reports [message #683842 is a reply to message #683747] Tue, 14 June 2011 09:51 Go to previous messageGo to next message
Are you going to use the genReport bat/shell script file to run your
report? What os are you using?
Jason
On 6/14/2011 7:00 AM, gin1975 wrote:
> hello
> thanks
Re: Automated execution of reports [message #683874 is a reply to message #683842] Tue, 14 June 2011 11:13 Go to previous messageGo to next message
Yes, i am going to use that.
Re: Automated execution of reports [message #684022 is a reply to message #683874] Tue, 14 June 2011 17:15 Go to previous message
Here is a blog post John Ward wrote on doing this in Windows. It is
older but same procedure should work:
http://digiassn.blogspot.com/2006/07/birt-birt-report-scheduling-without.html
Jason
Previous Topic:(no subject)
Next Topic:converting F1 xml to BIRT xml
Current Time: Sat Jul 26 02:36:48 EDT 2025
Powered by FUDForum. Page generated in 0.04672 seconds
