Web Service creation error with apche cxf [message #683830] |
Tue, 14 June 2011 09:32  |
Hello!I have succeded to create my web services using Apache cxf 2.3.4,Eclipse and Tomcat v7.0.
Unfortunately I have a problem. As I said I realized some services that worked fine at that time. But at some point, at the call of a web service the server crashed. The error is printed below. And at this point the creation of another web service in the same project is impossible because I obtain the error: "The selection must be a WSDL."
Then I have created another project with another services (which were doing the same think) that worked.And of course after some time the server crashed again and the services from this project didn't work. An annoying think is that I always get the same error after a certain period.
I would be very happy if you told me what can I do when this think happen. What is the cause of this error?
Thank you in advanced!
The error:
log4j:WARN No appenders could be found for logger (org.apache.cxf.bus.spring.BusApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Exception in thread "main" javax.xml.ws.WebServiceException: org.apache.cxf.service.factory.ServiceConstructionException: Failed to create service.
at org.apache.cxf.jaxws.ServiceImpl.<init>(ServiceImpl.java:149)
at org.apache.cxf.jaxws.spi.ProviderImpl.createServiceDelegate(ProviderImpl.java:90)
at javax.xml.ws.Service.<init>(Unknown Source)
at readavalue.ReadVariableNodeService1Service.<init>(ReadVariableNodeService1Service.java:50)
at readavalue.SeiGetval_ReadVariableNodeService1Port_Client.main(SeiGetval_ReadVariableNodeService1Port_Client.java:49)
Caused by: org.apache.cxf.service.factory.ServiceConstructionException: Failed to create service.
at org.apache.cxf.wsdl11.WSDLServiceFactory.<init>(WSDLServiceFactory.java:93)
at org.apache.cxf.jaxws.ServiceImpl.initializePorts(ServiceImpl.java:203)
at org.apache.cxf.jaxws.ServiceImpl.<init>(ServiceImpl.java:147)
... 4 more
Caused by: javax.wsdl.WSDLException: WSDLException: faultCode=PARSER_ERROR: Problem parsing a link to my web service/ReadVariableNodeService1Port?wsdl'.: java.io.FileNotFoundException: a link to my we b service/services/ReadVariableNodeService1Port?wsdl
at com.ibm.wsdl.xml.WSDLReaderImpl.getDocument(Unknown Source)
at com.ibm.wsdl.xml.WSDLReaderImpl.readWSDL(Unknown Source)
at org.apache.cxf.wsdl11.WSDLManagerImpl.loadDefinition(WSDLManagerImpl.java:239)
at org.apache.cxf.wsdl11.WSDLManagerImpl.getDefinition(WSDLManagerImpl.java:186)
at org.apache.cxf.wsdl11.WSDLServiceFactory.<init>(WSDLServiceFactory.java:91)
... 6 more
Caused by: java.io.FileNotFoundException: a link to my web service/Prosys_newSituationS/services/ReadVariableNodeService1Port?wsdl
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
... 12 more
FUDForum. Page generated in 0.06742 seconds
