Home » Modeling » OCL » What is wrong in this expression with enumeration values?
What is wrong in this expression with enumeration values? [message #683379] Mon, 13 June 2011 12:19 Go to next message
I am newbie in OCL. I am working with GMF, and Ecore models, and I am trying to add an Audit Rule with an OCL constraint. This is my constraint:
connector->forAll(r1 | r1.toInPort.logicType = #NO_WAIT implies r1.fromOutPort.logicType = #AND)'
I am getting the follwing error:
Cause: 2:46 "#" unexpected character ignored
logicType attributes are enumerations, what is wrong?
Thank you in advance, regards
Aintzane
(no subject) [message #683405 is a reply to message #683379] Mon, 13 June 2011 12:54 Go to previous messageGo to next message
Although # was used in some UML 1.x examples, # was never part of OCL.
You should qualify your enumeration literal with its enumeration e.g.
LogicType::AND.
Where did you find an example suggesting #AND?
Ed Willink
On 13/06/2011 17:19, Aintzane wrote:
> constraint:
> Aintzane
Re: (no subject) [message #683743 is a reply to message #683405] Tue, 14 June 2011 06:49 Go to previous messageGo to next message
Thank you very much, Edward. Your help has been very useful.
I donwloaded a document called "Object Constraint Language
Specification", but perhaps it is a bit old, from March 2000, I've attached it.
Aintzane
Re: (no subject) [message #683922 is a reply to message #683743] Tue, 14 June 2011 12:16 Go to previous messageGo to next message
That is a UML 1.3 chapter, so correspomdingly OCL 1.3. Seriously out of
date. Burn it.
The latest specification is at http://www.omg.org/spec/OCL/
Thanks fior the reference,
http://wiki.eclipse.org/MDT/OCL/FAQ#How_do_I_solve:_.22.23.22_unexpected_character_ignored
updated.
Ed Willink
On 14/06/2011 11:49, Aintzane wrote:
> Best regards,
> Aintzane
Re: (no subject) [message #1456159 is a reply to message #683922] Thu, 30 October 2014 00:32 Go to previous messageGo to next message
Sorry for asking this simple question.
I tried to access an Enumeration literal by "EnumerationName::EnumerationLiteralName". Therefore, I have an stereotype ST1, with attribute of Attribute1 which its type is "Enumeration1". I wrote an ocl Like: self.Attribute1=Enumeration1::EnumerationLiteral1.
It gives me java.lang.UnsupportedOperationException.
I am using the nightly version of papyrus. Am I missing something here?
Mahin
Re: (no subject) [message #1456255 is a reply to message #1456159] Thu, 30 October 2014 02:56 Go to previous messageGo to next message
This is https://bugs.eclipse.org/bugs/show_bug.cgi?id=448470 for which I
have just developed an interim fix for; just struggling to make the
JUnit test work in conjunction with other plugin tests.
Ed Willink
On 30/10/2014 05:32, Mahin Abbasipour wrote:
> Mahin
Re: (no subject) [message #1457604 is a reply to message #1456255] Fri, 31 October 2014 09:57 Go to previous message
Should be fixed in the latest maintenance or nightly version of Eclipse OCL.
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/5.0.3/M201410310813/mdt-ocl-Update-M201410310813.zip
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/5.1.0/N201410310856/mdt-ocl-Update-N201410310856.zip
Ed Willink
On 30/10/2014 06:56, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hi,
>> Thanks,
>> Mahin
Previous Topic:Enabling direct OCL-to-Java code generation in Indigo / eclipse 3.7.2
Next Topic:org.eclipse.jdt.annotation version in RCP product configurations
Current Time: Sat Jul 26 10:54:08 EDT 2025
Powered by FUDForum. Page generated in 0.08983 seconds
