Home » Modeling » Epsilon » [Eugenia] FixGMFGen and nullpointerexception
[Eugenia] FixGMFGen and nullpointerexception [message #677814] Thu, 09 June 2011 07:49 Go to next message
Hi all,
I have the following code in FixGMFGen.eol:
var features = GmfGen!FeatureLabelModelFacet.all.select( feat |
feat.metaFeatures.isDefined());
var featureLabel = features.selectOne( x | x.metaFeatures.exists( mf |
mf.ecoreFeature.name == "qcf"));
featureLabel.println();
And it prints the following:
org.eclipse.gmf.codegen.gmfgen.impl.FeatureLabelModelFacetImpl@410e942e
(viewPattern: name={0} qcf={1}, editorPattern: name={0} qcf={1},
editPattern: name={0} qcf={1}, viewMethod: MESSAGE_FORMAT, editMethod:
MESSAGE_FORMAT)
So hopefully the query is correct...?
but somewhere else it crashes, see stacktrace below.
(Removing the code removes the crash..)
Any clues for this?
All the best,
Ivar Refsdal
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:143)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:114)
at
org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:288)
at
org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:320)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.validateGenModel(ExecuteTemplatesOperation.java:263)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.run(ExecuteTemplatesOperation.java:106)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesAction.run(ExecuteTemplatesAction.java:47)
at
org.eclipse.epsilon.eugenia.GenerateDiagramCodeDelegate.runImpl(GenerateDiagramCodeDelegate.java:26)
at
org.eclipse.epsilon.eugenia.GenerateAllDelegate$2.run(GenerateAllDelegate.java:131)
at
org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at
org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Re: [Eugenia] FixGMFGen and nullpointerexception [message #677815 is a reply to message #677814] Thu, 09 June 2011 07:58 Go to previous messageGo to next message
PS...
This is also reproduceable on the model from
http://www.eclipse.org/gmt/epsilon/doc/eugenia/
and using the following code:
mf.ecoreFeature.name == "name"));
Best,
Ivar
Ivar Refsdal wrote, on 06/09/2011 01:49 PM:
> Hi all,
> MESSAGE_FORMAT)
> Any clues for this?
> All the best,
> Ivar Refsdal
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
> at
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: [Eugenia] FixGMFGen and nullpointerexception [message #682493 is a reply to message #677815] Sat, 11 June 2011 04:44 Go to previous messageGo to next message
Hi Ivar,
The query is correct indeed. I've tried to reproduce this problem but haven't been able to. Could you perhaps provide more details about this (i.e. in which step does it crash? does it always crash etc.) so that I can investigate?
Dimitris
Re: [Eugenia] FixGMFGen and nullpointerexception [message #682496 is a reply to message #682493] Sat, 11 June 2011 04:59 Go to previous messageGo to next message
Hi Ivar,
I've now managed to reproduce this. Could you please file a bug report so that we can keep track of any progress on this? https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT&component=Epsilon
Dimitris
Re: [Eugenia] FixGMFGen and nullpointerexception [message #683359 is a reply to message #682496] Mon, 13 June 2011 10:54 Go to previous message
Hi Dimitris,
thanks for your kind response!
I've submitted a bug report here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=349199
All the best,
Ivar
Dimitris Kolovos wrote, on 06/11/2011 10:59 AM:
> Hi Ivar,
> Cheers,
> Dimitris
Previous Topic:How to integrate EGL with diagram
Next Topic:Process in-memory EMF model
Current Time: Sat Jul 26 11:33:13 EDT 2025
Powered by FUDForum. Page generated in 1.17519 seconds
