Fonts in PDF Report [message #672062] |
Thu, 19 May 2011 14:28  |
Hello to all.
I kindly request your help and your insight on the following issue:
I am using BIRT engine to generate reports in a web application hosted on JBoss Server. All reports are generated successfully, without any error.
I needed to change the font in the generated pdf report file, so I followed your recommendations regarding the fontConfig.xml file.
-I kept all info intact, and I only changed the font-paths contents: I removed all and added only one font path, that pointed to a registered ttf file.
-I removed all other fontsConfig-xxx.xml files.
The font I wanted never appeared. Times New Roman was used instead (as I have understood by looking at the source code, this is the default font).
Why is this happening? what I am doing wrong?
If you need any more info, I'll be happy to provide further details.
Re: Fonts in PDF Report [message #740268 is a reply to message #683309] |
Tue, 18 October 2011 06:26  |
I have a similar issue with PDF fonts. We are using birt3.7. It works fine in windows, but when deployed in linux we are getting Times New roman as default.
What settings need to be done, to make the pdf use Arial.
In linux, we do not have any fonts installed.
Any help regarding this is appreciated.
Thanks.
Hari Priya
[Updated on: Tue, 18 October 2011 06:30] by Moderator
FUDForum. Page generated in 0.05282 seconds
