Home » Newcomers » Newcomers » JVM_Bind error
JVM_Bind error [message #679454] Thu, 09 June 2011 11:37 Go to next message
I am trying to install additional software for eclipse but I keep getting the following error:
Unable to read repository at download.eclipse.org/releases/helios/content.xml.
Cannot assign requested address: JVM_Bind
Any ideas what the problem is?
Keith
Re: JVM_Bind error [message #681789 is a reply to message #679454] Thu, 09 June 2011 17:03 Go to previous messageGo to next message
Here is more information from the error log:
Message: Connection to http:\\download.eclipse.org/releases/helios/p2.index failed on Cannot assign requested address: JVM_Bind. Retry attempt 0 started
Stack Trace:
java.net.BindException: Cannot assign requested address: JVM_Bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:383)
at java.net.Socket.bind(Socket.java:577)
at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:41)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98)
at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342)
at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:132)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:388)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:120)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getRepository(MetadataRepositoryElement.java:109)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getQueryable(MetadataRepositoryElement.java:103)
at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:54)
at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:102)
at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:72)
at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:34)
at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Session Data:
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Re: JVM_Bind error [message #682924 is a reply to message #681789] Sun, 12 June 2011 09:47 Go to previous messageGo to next message
Any ideas anyone? Pretty much can't use it with this issue.
Re: JVM_Bind error [message #684880 is a reply to message #682924] Thu, 16 June 2011 08:17 Go to previous messageGo to next message
Still trying to figure this out.
Have tried the following:
- Disabling windows firewall
- Turning off UAC
- Running Eclipse as admin
None of them help.
Re: JVM_Bind error [message #734922 is a reply to message #684880] Mon, 10 October 2011 08:28 Go to previous messageGo to next message
I have the same problem. Any idea what it is about?
Re: JVM_Bind error [message #807056 is a reply to message #734922] Sat, 25 February 2012 18:25 Go to previous message
any luck on this issue?
Previous Topic:Eclipse Error
Next Topic:Build Manager
Current Time: Sat Jul 26 02:05:06 EDT 2025
Powered by FUDForum. Page generated in 0.92044 seconds
