Home » Eclipse Projects » Rich Client Platform (RCP) » EditorPart MenuContribution(Adding a Toolbar to a FormPage with the Menu Extension)
EditorPart MenuContribution [message #681749] Thu, 09 June 2011 14:51 Go to next message
I´m new to rcp and i have a lot of problems understanding it.
I wanted to use the org.eclipse.ui.menus extension point to add toolbar items to my application. I successfully added some toolbar items to the toplevel-toolbar and also to the toolbar of a view.
However, I also want to configure the toolbar of a FormPage in a FormEditor declaratively. So I have the following settings in my plugin.xml
<extension
point="org.eclipse.ui.editors">
<editor
<!--this is my EditorPart extending FormPage. I create it programmatically and add it to my FormEditor, so it doesn´t seem to make sense to declare it here. I set the same Id in my code-->
class="org.ssprenger.agenato.editors.ConnectorEditor"
default="false"
id="org.ssprenger.agenato.editors.connector"
name="Connector Editor">
</editor>
</extension>
<extension
point="org.eclipse.ui.menus">
<!-- that´s the way i tried to set the menu contribution-->
<menuContribution
locationURI="toolbar:org.ssprenger.agenato.editors.connector">
<!-- the command worked for another toolbar-->
<command
commandId="org.ssprenger.agenato.addAdapter"
icon="icons/add_adapter.png"
style="push"
tooltip="Create a new Adapter">
</command>
</menuContribution>
</extension>
That doesn´t work. Please help, thank you
Re: EditorPart MenuContribution [message #681777 is a reply to message #681749] Thu, 09 June 2011 16:42 Go to previous messageGo to next message
I have found a solution. In my editorPart (a formPage) I had to create a MenuService and populate a ContributionManager like this
ToolbarManager manager = ....;
IMenuService menuService = (IMenuService) getSite().getService(
IMenuService.class);
menuService.populateContributionManager(manager, "toolbar:someId");
now I can add menuContributions
<extension
<menuContribution
locationURI="toolbar:someId">
<command
style="push"
</command>
</menuContribution>
</extension>
Re: EditorPart MenuContribution [message #682123 is a reply to message #681777] Fri, 10 June 2011 09:09 Go to previous message
That's the correct API to do it. Also remember when your down with that toolbar or form, use IMenuService.releaseContributions(ContributionManager) in your cleanup.
PW
Previous Topic:JasperWave - completely new Eclipse-based designer for JasperReports
Next Topic:How to capture key press event over multiple views
Current Time: Fri Jul 25 22:58:35 EDT 2025
Powered by FUDForum. Page generated in 0.45459 seconds
