Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.1 URL Test Execution hangs at 93%, CPU is tapped
TPTP 4.1 URL Test Execution hangs at 93%, CPU is tapped [message #68035] |
Tue, 25 April 2006 13:26  |
Good Morning,
I have generated a URL test from a recording. Whenever I run the test
(right click run as->test) the progress hangs at 93% consistently. The
test log is created as "inconclusive" - the events that were
successfully created are not consistent (i.e., I get different event
sets for different runs). Also, a java process stays alive, tapping the
CPU (only at 50%, but I believe this is b/c java isn't making use of
hyperthreading).
I'm using:
Eclipse 3.1.2
TPTP 4.1.0
On windows server 2003r2 x64 edition
I'm going to try installing the latest stable build of 4.2 and try my
tests there...is anyone aware of a workaround? What other information
can I provide?
Re: TPTP 4.1 URL Test Execution hangs at 93%, CPU is tapped [message #68083 is a reply to message #68035] |
Tue, 25 April 2006 22:11   |
--------------010003090708000105060702
Content-Type: text/plain; charset=ISO-8859-1
I still have the same problem with 4.2.0-200604131758 - this is perhaps
a symptom of bug 129337. Note that if I try to run the generated test
using eclipse's integrated Junit test runner, I get successes, but there
are stack traces in the error log.
Please find attached the test suite, the generated junit test, the
exception in the error log when running the test with eclipse's test
runner, and my eclipse configuration.
Any help or suggestions on where to look would be much appreciated.
Thanks in advance,
-DJH
Content-Type: application/octet-stream;
name="ListTest.testsuite"
filename="ListTest.testsuite"
UEsDBBQACAAIAOqCmTQAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c92dXXPbSLKm
7zdi/wNDEbMxc2IkEd+Au70dVQDY3bPubp+2Zs7ulYKSaJluStSSlO2eX3+Q ECWRKqhQWcgs
QJoLj+WG8CbIAqqeysSb3//w7Wox+jJbrefL67cH3tH4YDS7Pl9ezK8v3x78 82RymB788L//
5//4Pl9eXS2vT09m683Navlxvpi9OXk/gR8/3M43s9G3q/mbh9P4cJrqxNfr N9W/vz34tNnc
vDk+/vr169Hy6vJoubo8/r+//PxwyHr/kK9BfYQ/HnvVYe8+nH+aXU0P59fr zfT6fHb/W9uA
5OzT9Mt8uTqdrKaXV7PrzXrvXLPzxfxmPatP+OnP6cVsfXy1vJgt1sfn9e8f n21///jj/e8f
VSE/J/Lz9Wa2mp5vqqu01ZnvnKJBaucDxglsHn/x7rTzi7cHZT6RZVRM8rCI /ayUY5GItAjG
RZgKzyvEweh6elUJvZuvN6Bc/Vb9MW/m0+01qmeQRSBT7/4MI/WAvCiKKNIc UIzDMg5bDkgK
3QG+nES6GOCAWLQckAYtB2STlgPythgK2XLARPs5+Pl4rP8c8rEftxwQ6K8i H0ep7oBonIV+
ywGR9jKrAxLtZVYHpNrLrA4Q2susDsjbgtR/F9UB+u8iGgv9d1EdoP8uqgP0 30V1QNt3IRLt
kKsOSLXDvjpAaId9dYDMdQckiQiTlgPiccsBSdZyQKb9NqsDhPbbrA7Itd9m dUCh/TarAyYt
QUqvJUjptwQpw5YgZdQSpEy0Q646INUOueoAoR1y1QGPT7mD0ebPm2q+qGah hxnpbjY6gvnn
CCaso8+31/NN/XO9NDgY3cC6YL2p1hWzn6tJ6af6FybT8+r/fp+tl7eralav 1hij0ffL6tC7
meeZ6QtmhkiZvn4sTw6OEWeIk65nSLvFANNX2PUMcdH1DGnc9QzCf3qG9799 wJ0i7/xBFGXX
M0y6DYhqDvU6DohqHs+6niFUvgzsGR7ncaszwFIh6nqGqNu3CYuNbt9mdYas 27cJy5Vu3yas
Zzp/kh3vC1gRdf0kRcf7AtZUXT9J0fG+gFVZ1/tCJN2ecrCu6/a4h4Vft8c9 rAwnnc4AS0fR
9Qxx0PUMSd71DFm3exOWr93uTVjfdrs3qzOU3e5NWCF3/SSl1/WTlH7XT1KG XT9JGXf9JGXS
7SlXnSHr9pQDEOj2lANS0D3l7nfwnjvB/sbSwWgx/zhbzK9nzx67c8FX02/5 8vZ68/bAOxid
L6br9UkNKq0bYIax7e9p6WOrj9151DKEs7+Dpg+nPjZiDycpzMNJSt5w9nYH W8KBY332cGJh
Hk4s2cNJA/Nw0pA9nGxiHo4Ys4eTI8ZOzj92CmkeTpGzhzMxfe7AsczPnb39 8bZwqmO5nzu7
u/Ht4fgJeziB8Z2Vj0PuO2s309AeTpTxhrOX12gJB44N2MOJTG90OJb5Rt/L 2bSHkzDf6HsZ
ovZwUuYbfS8f1R6OYL7R97Jf7eHk/EPZeM6CY/mHsvGcBceyD2VhPGfBsexD WRjPWXAs+1AW
xnMWbO0xz1l7Gdn2cPjnrJ38b3s4CfPidC/b3B5Oygw2e7nt9nAEM9jsZdLb w5EFbzh7efuW
cODYlD2c3V2ztnBijz2c3S24tnASwR5OZjqjw7HMM/pevUV7OIJ5Rt+r7mgP J2ee0fdqSdrD
KZhn9L3KlfZwJuxDeadOpjUc6bEP5Z2qnPZwfPahvFMD1B5OyD6UdyqO2sOJ 2IfyTn1TezgJ
8+J0r5qqPZyMeXG6V7vVHo5gXpw+qRRrC6fjzul9QbUumfRsnfPp/W8fjFbb CrS3B3UF22I2
Xc+OHuuhF8vzOuv19uD47PwQDjncrG6v/zher86PP0+/TO8q1+rP56Gwe/tP 1T/efwjanJeS
uDtdzxYf321/FWqyH868U+Xe8KlCcZy2PBRSQdpqPyhta6tp1td2QwKjbDkg 1daPwiZ/W2V2
3hZD0Va6PdF+DlDRpf8c8rGvry/Px6H+KvJxpC20hU3HtqLnqKWeOEvaaruz lnriTLTUE2d5
W5D67wK2XNqKnvXfBWxLtBU9678LQPeW70Ik2iEHeKsd9gCc2mFfHZC3lU2H bUXP+tcqAFza
ip6zlnpiIVrqiUXeUk8sSu23CUvStqJnr63o2W8reg7bip7jliBloh1yMP1r hxxMyC119nIX
XB6m32enkce59/hxAmqaO0bf1vM3d4Xcz75F9Ub+6/fqP55VE9DF/T8+905R 9bzOG+ba5fJm
5O3NXr/VNSTL1duDRfUfDx6i3I+zPur64tkpE9Qer3XnJI4ut67vUC8XFg4j WDiM/np7Pb3d
fKpOMa8WD7OLvxl+CPUV3Kyg0mYz15eiKEuGn05O3r8XP5YHoy/TxS2sZla3 s52BgP6Ya5ln
Pmabj3r31Tn4tMtvs/PbOo7z89vVala/2qcJRanR8kY/liejs/OL2ZfpzY03 Oqw+5C/b1drB
aFl9/qt78WdPGjbcMj1cYL0uU4oz/W4XWJ80GM4FJkrtaND9AndKOfu9QFgX K4WpYccLhJM+
BZ8eLzBWqj2j7hcYZ8O5wFQpRo27X+AO3ukvMK+C3qym1b+Mzh/+CgWNylP8 uOExvj8PHjd9
cO6nyrq4S6n4fre8nF+P/vpxtbyq8Ptivpqdb2jnyFpXGa3kc2QtIwcxR9bU 7D294mQEr2N1
G79ZOfjxa6SsV9Uq7v3Hu+2nhxf6736EjaG8WgBqV1PK/DCZr6rl4nSzmV3d bEb11tNo8cwK
EvXiJYTysDHVslP2ZCHUvLpq3DD7COGLu+jr5S+sfk+fhH560Agju19M2ybZ 04LqZzbJNHz0
pHz7+BnysLlHf5mt19PLWXl9oVv8NJUjP09y/jN0c3WntR49FOM/q/fcssHg 2Qm/vsMX1Rg7
X81v7tSK8kN+Kk5O7r+ET0vYJN0+Th9Gi51mYKh5s1w9aqbjcWInFxrKTc/W pzfTzacHyeP6
Rj1+GPHvltOLo4vlD6vNW288Dv/X9Ormu9v50fXs69uGCcYwusgwuq3nykNw 3pHlpx/rBH8q
RVH+fq8pzs9nN49fwfyqGpPHl/OPfx/d/fXb4bez+eZqenP/D59vZpf3f7+5 ++E/jv/DLs4E
G+fhu+n15W0l/RDw7Prwdm2nnpqr/1Mc5u//+SD6LY3tJDP0BZdbA58H7ct/ z6vv4mL2cVE9
ke2iEIgLX89Wh+KyXhZuA/hl+e/5YjE9Do/Go7+eL6+q+2l+tph9N/rlw8/l KD4afzf6r/n1
xfLrevTrySg68quff/uvOPxu9OFf3nejo1+ruSh/9/vIPxofRePET/5mdxXS /Cp+anyyvbF/
3uTm2tV65np2vtm9r//PbHZzKBbzL5bfX2H6cK1ulNPr26vHB4qdXonRW64u ZquuihNDxWqF
eH06v+got1u7pJWbr0/X68WD2sfpYm33Fe5WQGkVN5/m13+cbuZXj0+88fMr YXV1ra52lfVu
azrYi0Uh00TZJYWv+7e7b3teLVbn08W/7iIELjv9cCJ+P3kItUWieiJlQVwv dCSTRJoXQX4n
kVNJpBN4bbac+JVMHnpSesU4qSUKJgmvyKLUqytlJ0wSgZeKMvNIJSZlnkZl GFdDyQ9iGU+q
W66Akorq26aRKGRWiklSRNUkm05EloikFBKScNK3k/j++AEEzbiwvrGVzfzP 6+OL2c1qVgMU
I/o92SJu3nduRL/P69OdCDsT3tN3VPGE9+SNWPeEFzdU4nAS3o6HkdVsol1W 8hBerF1EkhNe
rF3taQlv7wY8+mwHC7F2xcfAcLF2kadlOFsci7XrvH3J32cfZ6uddd7W3XJ/ be0CrmPtUpGb
IRPtypGFIRPt0tEVQybaTaWXwpCJdpuKlyET7Z4VN0Mm2j2pp+rLP+aPd8s/ PpQfPvz8268/
F2+rM5f/kO/Fb+9//YddGNqdKnqUTbQ7TnqU9e0UtbtM5CibmC4FyFA2MV0I DAhlldyangp+
+blAgqyHA1mEwBZjPRzG6gSaIdbDQSxCYIuwHo4vEQJbgCUUaMZXD4evGoFn 4NXDweujgBW6
Jopj1Pl6fXxe3YOr6YIZXFUXt8AAXKv4Tu/jI8HWRLEfw2LrjnOSe2xtMtzi xNa0W2Iy7SEx
mbpNTKb2icmdm++o+rudvOvMY2qfebSl1hSRRBwMtaaI3CM9taaINCQRtaaI nCMftaaInOFw
qTVFZB+pqTVFbEvRU2uK2KFipNbUND1JRK2ZaX6SjFoz0/zkU2q1lDNdCZBR a2a6DhgQtSqp
JWpq9bmp1eemVp+bWn1uaiUUaKZWn5tafafUminVrnVp2vp4URemV38uOdl1 /62O5ldFGtn1
LsrTOsp3EGR3gH3ifmsBsPteu44Bdu9tdAcAu9+3BT2JwK+b7l5TASxoGu9g dwdYkDPdvlYB
dnsfytv5Apbx+QyGxGn9vgj8uTy6nH+0i8l0j5uEakEQDS/dqBYkEaQyDKqF oBFgQky1oI5A
EwqqBUkEjzBRLUSBSIEPlGrh3UFEKp2UakEbkVMnplpQR+TSuagWwjDeGiWg WtAz3RuloVpQ
NN0OJcjFgpzp8oCGakHRdHEwIKpVShapqTbgptqAm2oDbqoNuKmWUKCZagNu qg3cUS3cyGnf
VBsrPYwiC6r1aLA2VlLTWKzdKVd1j7W7hZUusDZuTkIbzyKm29uEWKsvpCTH Wn0RpRHWrubn
6+vZhgJo9cWUDECLqXskAlpMueNggBZTJUkPtPriSBag1ddHugJafc3kSwFa fSkmL9DqizK5
gTZBbF4xAm1i+s4GEdAmqPdyKYA2MX0zlyBNC3KmCwMyoE1NlwUDAlolIUUN tCE30IbcQBty
A23IDbSEAs1AG3IDbegUaFOl5H67jj67HF2uphfzegJnJVrVmjs2J9qzyx/v oyQh2lR5SmCJ
Nm22g3RDtGlD8xlOot2pK7WaRkyzmIREqy+yJCdafYGlCdGeXZ7e34nWJKsv sGQgWUwtJBHJ
YkogB0OymMpJepLVF0yykKy+ZtIVyerrKF8KyerLM3lJVl+oyU2yGeolXTaS zUwTl0Qkm6Fe
y90n2cBO0TRzSUOymemCgIxkM9PlwIBIVjFx0SNC+SuWZCMcySIEtiQb4UhW J9BMshGOZBEC
W5KNcKCJENiSLKFAM8lGOJLVCDxDshGOZB8FrEg2K57eFQ+ev5AJYobYTHlD 9aktdCPFbkOs
c1U0ACuUqmcswGaTHgG2qbcsJ8CK54zjzWYPYVorRQiwwnjRQQKwwnTN0eDh C8O6IqbvPle3
LmBlpdJ5zSVMVyRUKCvQ74T24NoLcSLyWoPhX4F//5SQfwUqIVY90K43h9BB 8UG6+qwW8zun
/+q7/fr16+HH5erq8Ha1mAG0zi7swkJsnhBhuUDbmnFguUDshgwXywViV4Ua yyVie+V+RL+b
XV/uPLbTzE6511ptianVnp5/mh3C1a+Wjwh5vTw8h/9gJ4/aDWHbj5CIbZEP s9WXnRngtxU8
w+qRbyeNKMkp4PlwL3xyO/v7yI9G4mY18sfjeOSlbwLvTRSNfvzlxC4Ua/My u00L2cG8LLRT
dGheBnJuzctA0TRrcra8+PNB77aaEt6enU8vrubX9erkZrpev72plzH1z/eN kN7+xZ/U/1r9
/9PlzV+CyWrzl6CAJc5f/PhugVP9DEscaG50XK0jR9V/HMEDZH5tue6RpgmZ AW07Kd1h9Dz/
26/v/p/pttBWQek/SG9lHuO2tjAXsVVIcAo2ZukxbvsMcxFbhQSnYGPHHuO2 6LQX0ayQ4BRs
DN9j3C4d5iK2CglOwcZSnvEitgqkF9G8nRnjtjO1F9GskPDb4se4LVPdRTyj kLg03oeJTulI
+m6nBZuzBmx1P3tlazQ1KDRaPDRdo265VsfU2Rgi79MYIndsDJF3M4bIezCG yN0aQ+T2xhDN
233Pbd6SbgPmrq0jcnvrCKebuvlL9JvIe/WbyN37TeSD8JvIX4XfRNGj30TR 6x5m0e8eZjGM
PcwCZT+xu3tnV+FUoGq4OnfRA0XTVQhNTVVhugAh270rTNcgA9rcUl7sp996 Svk3hlL+bZuU
f1Ml5d/y6CBhhcGFYtvweX1c3Uyb5abOJ7OCbyGeimdm7eceAySB3ULpJoCF 3UL2CLvFxC3s
FmUn2C1N39EkhN3S1L+BBnZLU4OGxu5zt5v54vEetOpABzGY2nNRoWuJSPIS vVpTIpK7XSjU
yV5Die6FQEmnJcLJgYhOS3xTAwY6LTHNDQZLpyVi34iaTktctRoxnZao3ups eFhaN1m3w8Oy
Q5N1O14rHTZZr+Qmbpusg+ILbLKuLN+pzSMyHBzizSMyHBrizSMyHBjizSMy HLPhzSOsBayQ
cNLUkvx8++Rk5cGJ4u3pjc2AcBseCQ1OuvUihzP01oscxF32Ige9Dr3I4ddd 9yIHTYe9yEGu
Uy/ymgbvxrctCk6cNiMHQcfNyEHSUTNyJyg46a9JuZ+Px46blINk/03KIYqX 36QcrqKvJuWg
3V+TclAfQJNyCMO6zt8GBSs9t03KQdG2zt9SznGdf6X4ApuUK8kUahQU3Cgo uFFQcKOg4EZB
awELFKxuA8VHvVqQXtRvSTGCYKWrJOQ8zwwE6+AIMLCKoVtvbzhDb729K3HP ZW9v0OvQ2xt+
3XVvb9B02Nsb5Ox7e99jIIxuOwis5J329gZBx729QdJRb28HEFhdTH89v0Hd cc9vkOy/5zdE
8fJ7fsNV9NXzG7T76/kN6gPo+Q1hWPf8toNA323Pb1C07fltN534bnt+g+IL 7PmtLNipIVBy
Q6DkhkDJDYGSGwKtBawg0FesxwECl1fMDOgraTjPN2TAKjYSBPSV9/6xCOg3 +5C7QUBfuEVA
P+uEgL5pmowQAX3jli8kCOibFglpEHB5ZUuAvmnJEBUB+ug0VmcCDBC5q8ET YIDPihESYIDJ
htEQYIDuM8dBgAEiiTVcAgwQyTBqAgwQWz/0BBggdoEYCTAwTZIREWBg3ECE igAD0ywZTRow
MF0gkBFgYLo8GBABKqkTagLMuQkw5ybAnJsAc24CtBawIsBAsTCvVqOzzTkz AQZKBs4LzAgQ
YiMhwLCja3l1Ef25llfhO3Utr/S6uJZXv+7ctbzSdOlaXsnZu5bfE2A1uG0J MHTrUV4J2nuU
2xJg6Mhu3AkBhj3akFfqmFQYDQGGeIseBgIMMVY9gyXAEJEJoybAELH1Q0+A EcptnI0AI+O3
zmkIMDJNkZERYGSaIqPJAUamCwQyAoxMlwcDIkBltU5NgAU3ARbcBFhwE2DB TYDWAlYEGCke
20CAX7ibMFfCSgrOCw0Z8AtR8+UqCOUtWywFRmmPFBjlbikwajbDMX7kmibJ CCkwMn6bnoQC
I9PiIA0FwvC25cDYtFiIigNjdCarMwfGiPTV4DkwxifGCDkwxiTEaDgwRmSv +DgwRuSxhsuB
MSIfRs2BMWIDiJ4DY8ReECMHxsbvm9NwYGyaKCPjwNg0UUaTCYxNlwhkHBib LhAGxIFK+oSa
A0tuDiy5ObDk5sCSmwOtBfAcGI0zNR9WrUehtSQnBoKup2BgZIaBdXDdKRBi UNxpUBQIZ2hO
jzmgQBCPHVIg6EX2FAi/bpqqoqJA0DSu2OlOgSBnWrDzPAXC6LaCQJA3XZWQ QCAIItJJFBAI
koh00rAhEC4G3wuXCgJBHdMDlwACQRJvg0MNgVUUmGTSQCEQrgKxA0MKgaCN aSBBC4GgPoD+
ERCGy/4RoNehf4QFlYGiw/4RIOe2fwQovsD+EUqbO2oInHBD4IQbAifcEDjh hkBrASsIVNNh
1XJ0M60mNWYKjBSLIy82o8C76EgwMOrWLALO0FuzCBB32SwC9Do0i6h+3ThT RYiB+mQVOQbq
E1VGGFgPb1sO1OeWGDgQk04i4kBMOmnwHIjJStFzICabRMSBmCQSHwdikknD 5UB9LoqXA/V5
KW4O1OeonHGgce6KiAONM1dkHBg7bBRRySVuG0WA4strFJEqiRtiDqwXapwc WAtwcmAtwMmB
9UYiJwf61gJWHJg0NYpYb/5k58BE7RORmHHgXXQkHJh0axMBZ+itTQSIu2wT AXod2kTAr7tu
EwGaDttEgFz3NhH18LblwMRplwgQdNwlAiRfTZcIuJj+ukRU6qnjLhEg2X+X CIji5XeJgKvo
q0sEaPfXJQLUB9AlAsJw2SUC9Nx2iQBFh10iQM5tlwhQfHldIlKlkI6aAz1u DvS4OdDj5kCP
mwOtBaw4MG3qEvHtagELJmYSTNVGEakZCd7HR8KCabdeEXCG3npFVOKZy14R oNehVwT8uute
EaDpsFcEyHXvFbEd4LY0mDltFwGCjttFgOSraRcBF9NfuwhQd9wuAiT7bxcB Ubz8dhFwFX21
iwDt/tpFgPoA2kVAGC7bRVR6wm27CFB02C4C5Ny2iwDFl9cuIlUyONQ06HPT oM9Ngz43Dfrc
NGgtYEWDoqldxGIKky4rCgq1X0RmhoJ1cCQcKLo1jIAz9NYwAsRdNowAvQ4N I+DXXTeMAE2H
DSNArnvDCBjdthAonHaMAEHHHSMqSflqOkbAxfTXMQLUHXeMAMn+O0ZAFC+/ YwRcRV8dI0C7
v44RoD6AjhEQhsuOEaDntmMEKDrsGAFybjtGgOLL6xiRKtV0ej4of8VCYICD QITAFgIDHATq
BJohMMBBIEJgC4EBjtEQAlsItBawgsC8ySfmHgyYQTBXUtz+2AwEHwIkgcG8 s19M3qdfTO7Y
Lybv5heT9+AXk7v1i8k7+cXcfxMVC97Yybv2i8nd+8Xkr8kvJu/VLyZ37xeT D8IvpngVfjFF
j34xRa9+McUw/GIKa7+Y0E6vg1+M3fO9sPWLsZRz7hdTvDy/mFTJ3ug54cOJ +P0EiYMhDgdR
ElsgDHFAqJdoRsIQh4QoiS0UhjhmQ0lssbCDhBUYFk3eMTfLxfz8T2YsLBTz GN8zw8JteCRQ
WHR2jyn6dI8pHLvHFN3cY8oe3GNKt+4xZSf3mLuhbZseLF07x5TunWPK1+Qc U/bqHFO6d44p
B+EcU74K55iyR+eYslfnmHIYzjGltXOMHRGWzp1jSlvnGDu5iXPnmMkLdI5R 6uqoa0Qj7hrR
iLtGNOKuEY24a0StBawocNLkHDNdzTefPq//P3d+cKLk5XzfDAQfIyRhwUln B5lJnw4yE8cO
MpNuDjKTHhxkJm4dZCadHGQ+zqab29Xs7j78x4f//GCLhRPXRjIT90Yyk9dk JDPp00hGjJ0b
yYjxEIxkxPg1GMmIcX9GMmLcp5GMGA/CSEaMrY1krLBQjF0byYixUyMZMXZt JCPGL9BIRukI
To2FMTcWxtxYGHNjYcyNhdYCNlgoxoqRzP2a9Gz5jZcKxVhJzPmBARVuAzyF ACmgUIy7WsmI
cY9WMiDrEgqF18lKRnjurWSE59RKRnidrGR2bkBLHBSeYycZ4Tl3khHeK3KS EV6fTjLCc+4k
I7whOMkI7zU4yQivPycZ4fXpJCO8QTjJCM/aScYOB33XTjLCt3WSsZRz7SQj /BfoJKM4X1Dj
YMKNgwk3DibcOJhw46C1gBUO+k1OMufTBTMJ+kpazg/N8oMQGwkE+l19ZITf o4+M8N36yAi/
k4+M8N37yAjfqY+M8Dv5yNxDYDW+Z9cX05UtCfqO7WSE79xORgSvyE5GBH3a yYjAuZ2MCIZg
JyOC12AnI4L+7GRE0KedjAgGYScjAms7GTsSDFzbyYjAqZ2MCFzbyYjgBdrJ pNwkmHKTYMpN
gik3CabcJGgtYEWCQdFMgofr2eaWuceECJSMnB8Z8+DpXYQkVBgqpjpYKgwm PVJhGLilwrDZ
Pcf00Rua5s0IqTA0fgefhApD08ohIyq8uxlt2TA0rSqiYsMQneXqzIYhIrU1 eDYM8UkzQjYM
MckyGjYMEZktPjYMETmu4bJhiMiVUbNhiNgUomfDCLE/xMiGkfFb6jRsGJkm 0cjYMDJNotGw
YWS6XCBjw8h0sTAgNlTcP6jZMONmw4ybDTNuNsy42dBawIoNI6UQGbrQf1pW 60T+qtFISdT5
sWEn+ocISdgwUu4sLBtGaY9sGOVu2TBqNtExfvSaptMI2TAyfhufhA0j0zIi LRveD3JbKoxN
i4uoqDBGZ7w6U2GMSHMNngpjfAKNkApjTOKMhgpjRJaLjwpjRL5ruFQYI/Jm 1FQYI7aD6Kkw
RuwMMVJhbPy+Og0VxqYJNTIqjE0TajRUGJsuFMioMDZdJgyIChVnRmoqFNxU KLipUHBToeCm
QmsBKyqMJw1UuJjDnMEKhImSo/MTwy6EEBwJCyaKuw6WBROvRxZMIrcsmDSb 6Jg+cBPTJBoh
CybGr+CTsGBiWkikZUEY4LYcmJiWFlFxYILObnXmwASR0ho8Byb4ZBkhByaY JBkNByaIjBYf
ByaI3NZwOTBF5MioOTBFbADRc2CK6nzBxoGp8SvqNByYonpdUHBgapo8o+HA 1HSRQMaBqekS
YUAcqNh/UHOg5OZAyc2BkpsDJTcHWgtYcaBajQyt0JZfZtV9vamnPlYcVBPe fmrYi3AnRhIq
VO8uLBXu7NO4p8K0dEuFabOLjvHj1zR9RkiFmfGb+CRUmJmWEGmpcGec28Jh ZlpbRAWHGTrJ
1RkOM0Rma/BwmOFzZoRwmGFyZTRwmCESW3xwmCFSXMOFwwyRKqOGwwyxK0QP hxmqCQYbHGbG
r67TwGGGantBAYeZaQ6NBg4z07UCGRwK05XCgOBQ8WekhsOcGw5zbjjMueEw 54ZDawErOBRK
p/i6JdrNbUWBi+rZzQyHQsnT+ZlpR8LHGEngUChWO1g4FEGPcCgSt3Aomt11 jB+/pvk0QjgU
xi/nk8ChMK0k0sLhzji3hUNhWmJEBYcCnfnqDIcCke4aPBwKfCKNEA4FJoFG A4cSke3ig0OJ
yHsNFw4lIn9GDYcS1TeeGg4lqhUGGxxKVBf57nAoUc0vKOBQmibWaOBQmq4V yOBQmq4UBgSH
ij8INRwW3HBYcMNhwQ2HBTccWgtYwaFUqpKrhelmWk1qm9VsxoyGUknWBWMz NHyMkAQMpXJn
YcFQ5j2CYT52C4ay2WDH9NGbm6bUCMEwN34znwQMc9PSIi0Y1qP8pBrltliY m1YcUWFhjs55
dcbCHJHoGjwW5vgUGiEW5pjUGQ0W5og8Fx8W5oiM13CxMEdkzqixMEc1j6fG whzVEoMHC5Nk
z7qOHQtBD2Vv0xkLQdF0GiXAQpAznUZpsBAUTWfMAWGh4txIjYUlNxaW3FhY cmNhyY2F1gJ4
LITbQOkOAVjITISgq9jcBJ4hEdLAIMSgFNOiYBDO0NzD3QEMgrh0CIOg11wv a/zANa2zoYJB
0DSutekOgyBnWmijh0FbDoQITGtvSDiwEsT4/1FwIEgiUjvD5kC4GESGh5gD QR2R46HgQJBE
JHaYOBCiQGxfDJQD4SoQOyKkHAjaqKYQpBwI6ih7GzYOjFAtIrpzYIQytKHg wMi03oSGAyPT
RQIZBxp73w2IAxUzEGoOnHBz4ISbAyfcHDjh5kBrASsOjJS9hfP1+ni9+XPB TYKRMpoD34AE
q/BO78IjYcFYqZ3FsmDc3LrdDQvuOgW6YMG4uTzW9KGrdxnkYUG9pyA5C+rN /7Qs+HDnHVV/
sxM3rbKhwkCM4R8RBurN/V4YBuqdA7kxUO8iyIKBeidBVxiodxd8KRgYI4p8 qTEwQfV/oMbA
BOVuw4aBCaobRHcMTFB+NhQYmJhmy55ioN10kpiuD8gw0Nj2bjgYmCnejMQY WN/bnBhYC3Bi
YC3AiYH1op8TAwNrASsMTJQGEJAO/FqthqpZ7JqZBBMlHxcEhjnBhwhJYDBR amWxMJg0t3B3
A4O7doEuYDBpLok1fvSaZs0IYVBvLEgOg3oHQOPE4P0ot80O6s0AGbAQ4/9H hIV6r78XhoV6
I0FuLNSbCrJgod5Y0BUW6s0GXwoWpogcGTUWpqgGENRYmKJ8bdiwMEW1g+iO hSnKyYYCC1PT
5BlNdjA1XSmQYaGx792AsFDJZFBjoceNhR43FnrcWOhxY6G1gBUWqlsNkKOo RvAtMxKqgzkI
DZODdXQkOLjrj2iHg1lz73Y3OLhrEOgCB3fsEG0euXpzQR4c1FsJkuOg3vOv NTcII9s6Naj3
/GNgQIzNHxED6i39XhgD6v0CuRlQ7x3IwoB6/0BXDKj3FHwpDCgQCTJqBhSo 5g/UDChQ9jVs
DChQrSC6M6BAGdZQMKAwzZzRMKAwXR6QMaCxvd2AGFCxYqRmQJ+bAX1uBvS5 GdDnZkBrASsG
FErvB1iL3qzmvF0nQFlJxwWRIQTehUdCgUJx7MVSoGju0u6GAnedAF1Q4I7v oc1DV+8iyEOB
es9AcgrUm/u1UmA9tK0xUO/ux4CBGEM/IgzUm/e9MAzUOwNyY6DeJZAFA/VO ga4wUO8e+FIw
UCISYtQYKFFtHqgxUKLsatgwUKKaPnTHQGmaKSPDQGmaKaOpEM1N1wdkGGhs ZjcgDFQSF9QY
GHBjYMCNgQE3BgbcGGgtYIWBubK1ML8CIjierlbLr8wkmCsDOogNSPAuwtO7 CElgMFdsc7Aw
mDe3aXcDg7v+fy5gMG/2yTF+9JrmywhhUO8USA6Deks/LQxu7z/ICh5vlsvF dqAfXc4/2oVi
WkZEhYYYUz8iNMwRaa3Bo2GOT5gRomGBSZTRoGGByGrxoWGByG8NFw0LRJ6M Gg0LVJMHajQs
ENtDjGhYoFo+dEfDwjSBRoaGhWkCjQYNC9PVAhkaFqZrhQGhodIhjRoNQ240 DLnRMORGw5Ab
Da0FrNCwULo8bJemi+XlkpkMCyU7FyTmZFgHSAKGheKjgwXDorlTuxswLD23 YFg2m+aYPnhL
0xQaIRiWxi/fk4BhaVpApAdDGOHWRFiaFhVREWGJTnZ1JsISkeEaPBGW+NwZ IRGWmJwZDRGW
iAQXHxGWiFTXcImwRKTMqImwRPV3oCbCErErxEiEpfHL6TREOEF1s6Agwolp Lo2mZnRiukwg
I8KJ6SJhQESopDT0sFD+iiXCCEeECIEtEUY4ItQJNBNhhCNChMCWCCMcsCEE tkRoLWBFhBPF
TuZsMb3+YwSio7/+8MPfmKlwojrKpAZUWAf5Hh521f9ouHDS2VJm0qelzMSx pcykm6XMpAdL
mYlTSxk5treUqYf30ef1jZ2wYxMZObY3kakJ+LjC3r+P7v767fDb2XxzNb25 /4fPN7PL+7/f
3P1gSZBy/IqcZ+S4T+cZOXbuPCPHQ3CekePX4Dwjx/05z8hxn84z8OcACFKO rZ1nIju9Ds4z
lpOCrfOMpZxr5xk5foHOM0pPNz1cfDgRv58gGTLGMSRKYkuRMY4i9RLNHBnj OBIlUZFkMvFD
pG8oSmLLkrG9hA1NSk9xodlmOD7NprUoJ0vCoHvKkpl5hnEbIgVLSq+rH430 evSjqR4WTllS
ep38aKTn3o9Gek79aKRn70ezm2O8G+Onn5ar+b9Pz5Yb23yj9Bx71EjPuUeN 9F6RR001qfVJ
i55zjxrpDcGjRvqvwaNG+v151Ei/T48a6Q/Co0b61h41drTou/aokb5Tjxrp u/aokf4L9KhR
ckPUFagJdwVqwl2BmnBWoAIlsvuUJi4rUKWveNQ4q0CVvpLhC8e4ClSPBg/9 rkY10u/RqEb6
bo1qpN/JqEYG7o1qZODUqEYG9kY129vvuhoQl/W3cHx2O1/AMvh8BqPjtEtd qgwcm9jIwLmJ
jQxekYmNDPo0sZGBcxMbGQzBxEYGr8HERgb9mdjIoE8TGxkMwsRGBtYmNnac GLg2sZGBrYmN
nVzo2sRGhi/QxEap4aPmxJSbE1NuTky5OZHdyzR1yonhcyY2TjKJoZK/Cz1s JpGIFcOuPjYy
7NHHRoZufWxk2MnHRobufWxk6NTHRoY0PjZ7qcTN8sYaEUPHZjYydG5mI8NX ZGYjwz7NbGTk
3MxGRkMws5HRazCzkVF/ZjYy6tPMRkaDMLORkbWZjR0iRq7NbGRka2ZjKefa zEZGL9DMRkn7
UCNixo2IGTciZtyIyO5zmjlFxOg5M5uz6fkfl6vlLZAJKyZGSh4v9M0xcSdM ElKMuhrbyKhH
YxsZuzW2kXEnYxsZuze2kbFTYxsZ0xjbwB87g90aFGPHHjcydu5xI+NX5HEj 4z49bmTs3ONG
xkPwuJHxa/C4kXF/Hjcy7tPjRsaD8LiRsbXHjR0oJq49bmTi1ONGJq49bmTy Aj1ulBo9alAU
3KAouEFRcIMiu+upcAqKieKk6xoUEyWJFwY2oEiUU0yUwm4sKSZxj6SYCLek mDT7+hg/hU0T
boSkmBi/7k9Ciolp3ZFJ/enjXymoMTEtUaKixgSdHutMjSkiJzZ4akzx2TZC akwxWTYaakwR
KTE+akwRybHhUmOKSLJRU2OK2C6ip8YUsXPESI2p8XvxNNSYmmbfyKgxNc2+ 0VBjarp6IKPG
1HTtMCBqVFJB1NQoualRclOj5KZGpHEpnhqlU2pMi2eocbVx0EhRpko2LwzN kfE+RhJczBRX
HywuppMecXG3x6oLXMyarXtMH7+ZadaNEBcz4/f9SXAxM61BehYX59Xk+nAn WrNhZlqbRMWG
GToj1pkNM0QabPBsmOETbIRsmGESazRsmCGyYHxsmCHyYcNlwwyRV6Nmwwyx KUTPhgKxP8TI
hsL4pXgaNhSmCTcyNhSmCTcaNhSmSwUyNhSmC4UBsaFSpEfNhjk3G+bcbJhz syHSiBTPhrlT
NhSKj+69i021IKpWpE5eUhRKFi+MEHY2e5GScKJQiryxnCjSHjlR5G45UTR7 +Bg/ik1zboSc
KIzf9yfhRGFagvQsJ55d1gP99+XXn+qBbo2K0rQ6iQoVJToN1hkVJSL3NXhU lPisGiEqSkw2
jQYVJSL1xYeKEpEEGy4qSkQyjRoVJWKPiB4VJao5BxsqSuN34mlQUaLacVCg ojTNstGgojRd
LZChojRdKwwIFZWUDzUqFtyoWHCjYsGNitZ+pKaoWDhFRTl5BhWvlqvZ6OyS GRJzJXcXxuaQ
CDHKSxo6zBVHHywd5l6PdJhHbukwb3btMXr6Vn8aG5dR0SFoOjQ9BbnOpqf1 64mb6dnpYvZx
A/0wPtnxIQTj1OgUBB0bnYLkqzE6hYvpz+gU1B0bnYJk/0anEMXLNzqFq+jL 6BS0+zM6BfUB
GJ1CGC6NTkHPrdEpKDo0Oq3+1NtqkfMhKL5Ao1OlJs+++XszH5Y4PkQIbPmw xPEhon39lg9L
HB8iBLZ8iPQhRQhs+bC0Fdjnw++Pt+BxUv1jdUd8nC9mb07eT+DHD7fzzaw6 5r8BUEsHCJzl
0K26LAAAEdUCAFBLAQIUABQACAAIAOqCmTSc5dCtuiwAABHVAgAQAAAAAAAA AAAAAAAAAAAA
AABSZXNvdXJjZUNvbnRlbnRzUEsFBgAAAAABAAEAPgAAAPgsAAAAAA==
name="junit.error.log"
Content-Disposition: inline;
filename="junit.error.log"
java.lang.Exception: Unexpected TestElement type for testId '1': ListTest:
NOT_RUN (1)
at
org.eclipse.jdt.internal.junit.model.TestRunSession$TestSess ionNotifier.logUnexpectedTest(TestRunSession.java:469)
at
org.eclipse.jdt.internal.junit.model.TestRunSession$TestSess ionNotifier.testStarted(TestRunSession.java:365)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient$ 5.run(RemoteTestRunnerClient.java:498)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient. notifyTestStarted(RemoteTestRunnerClient.java:495)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient. access$6(RemoteTestRunnerClient.java:490)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient$ DefaultProcessingState.readMessage(RemoteTestRunnerClient.ja va:86)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient. receiveMessage(RemoteTestRunnerClient.java:342)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient. access$26(RemoteTestRunnerClient.java:341)
at
org.eclipse.jdt.internal.junit.model.RemoteTestRunnerClient$ ServerConnection.run(RemoteTestRunnerClient.java:267)
name="ListTest.java"
filename="ListTest.java"
package test.lease;
import java.util.Random;
import junit.extensions.RepeatedTest;
import junit.framework.Test;
import org.eclipse.hyades.test.common.junit.DefaultTestArbiter;
import org.eclipse.hyades.test.common.junit.HyadesTestCase;
import org.eclipse.hyades.test.common.junit.HyadesTestSuite;
import org.eclipse.hyades.test.http.runner.HttpCookieCache;
import org.eclipse.hyades.test.http.runner.HttpExecutor;
import org.eclipse.hyades.test.http.runner.HttpHeader;
import org.eclipse.hyades.test.http.runner.HttpRequest;
import org.eclipse.hyades.test.http.runner.HttpResponse;
import org.eclipse.hyades.test.http.runner.internal.util.HttpTestUt il;
* Generated code for the test suite <b>ListTest</b> located at
* <i>/bc-test-trunk/src/test/lease/ListTest.testsuite</i>.
public class ListTest extends HyadesTestCase {
* Constructor for ListTest.
* @param name
public ListTest(String name) {
super(name);
* Returns the JUnit test suite that implements the <b>ListTest</b>
* definition.
public static Test suite() {
HyadesTestSuite listTest = new HyadesTestSuite("ListTest");
listTest.setArbiter(DefaultTestArbiter.INSTANCE).setId(
"ECFBE5DFC4D629EB0A7A8D30D48A11DA");
HyadesTestSuite loop1 = new HyadesTestSuite("Loop 1");
listTest.addTest(new RepeatedTest(loop1, 1));
loop1.setId("ECFBE5DFC4D629EB0ABFAC80D48A11DA");
HyadesTestSuite leaseList_unauthenticated_ = new HyadesTestSuite(
"Lease List (unauthenticated)");
loop1.addTest(new RepeatedTest(leaseList_unauthenticated_, 1));
leaseList_unauthenticated_.setId("ECFBE5DFC4D629EB0ACDDD50D48A11DA ");
leaseList_unauthenticated_.addTest(new ListTest(
"firstAttemptLeaseList_unauthenticated_").setId(
"ECFBE5DFC4D629EB0ACDDD53D48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0ACDDD57D48A11DA"));
leaseList_unauthenticated_.addTest(new ListTest("js_deprecated").setId(
"ECFBE5DFC4D629EB0AD04E62D48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD04E66D48A11DA"));
leaseList_unauthenticated_.addTest(new ListTest("css_central").setId(
"ECFBE5DFC4D629EB0AD04E7BD48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD04E7FD48A11DA"));
leaseList_unauthenticated_.addTest(new ListTest("images_loginLogo")
.setId("ECFBE5DFC4D629EB0AD04E94D48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD2BF53D48A11DA"));
leaseList_unauthenticated_.addTest(new ListTest("images_loginLogo1")
.setId("ECFBE5DFC4D629EB0AD2BF68D48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD2BF6CD48A11DA"));
leaseList_unauthenticated_.addTest(new ListTest("images_bgGradient")
.setId("ECFBE5DFC4D629EB0AD2BF81D48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD2BF85D48A11DA"));
HyadesTestSuite login_fromRedirect_ = new HyadesTestSuite(
"Login (from redirect)");
loop1.addTest(new RepeatedTest(login_fromRedirect_, 1));
login_fromRedirect_.setId("ECFBE5DFC4D629EB0AD2BF9AD48A11DA ");
login_fromRedirect_.addTest(new ListTest("attemptLogin").setId(
"ECFBE5DFC4D629EB0AD2BF9DD48A11DA").setTestInvocationId(
"ECFBE5DFC4D629EB0AD2BFA1D48A11DA"));
return listTest;
* @see junit.framework.TestCase#setUp()
protected void setUp() throws Exception {
* @see junit.framework.TestCase#tearDown()
protected void tearDown() throws Exception {
* First attempt lease list (unauthenticated)
* @throws Exception
public void firstAttemptLeaseList_unauthenticated_() throws Exception {
HttpRequest request = new HttpRequest();
request.setMethod("GET");
request.setVersion("1.1");
request.setHost("bcdevapp1");
request.setPort(8007);
request.setAbsolutePath("/lease/LeaseListLoad.do?rt=1004&ui.new=true ");
request.setPageNumber(1);
request.setPageOrder(HttpRequest.PAGE_START);
request.setSecure(false);
HttpHeader header;
header = new HttpHeader();
header.setName("Accept");
header
.setValue("image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*");
request.addHeader(header);
header.setName("Accept-Language");
header.setValue("en-us");
header.setName("UA-CPU");
header.setValue("x86");
header.setName("Accept-Encoding");
header.setValue("gzip, deflate");
header.setName("User-Agent");
header
.setValue("Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; WOW64; SV1; .NET CLR 2.0.50727)");
header.setName("Host");
header.setValue("bcdevapp1:8007");
header.setName("Connection");
header.setValue("Keep-Alive");
executeRequest(request);
* js/deprecated
* @throws Exception
public void js_deprecated() throws Exception {
request.setAbsolutePath("/js/deprecated.js");
request.setPageOrder(HttpRequest.PAGE_MID);
HttpHeader header;
header.setValue("*/*");
header.setName("Referer");
header
.setValue(" http://bcdevapp1:8007/lease/LeaseListLoad.do?rt=1004&ui. new=true");
header
header.setName("Cookie");
header.setValue("JSESSIONID=FBEEJBPAOPNJ");
* css/central
* @throws Exception
public void css_central() throws Exception {
request.setAbsolutePath("/css/central.css");
HttpHeader header;
header
header
* images/login logo
* @throws Exception
public void images_loginLogo() throws Exception {
request.setAbsolutePath("/images/BuildingCenter_Login_Logo.gif ");
HttpHeader header;
header
header
* images/login logo
* @throws Exception
public void images_loginLogo1() throws Exception {
request.setAbsolutePath("/images/Bricsnet_Login_Logo.gif");
HttpHeader header;
header
header
* images/bg gradient
* @throws Exception
public void images_bgGradient() throws Exception {
request.setAbsolutePath("/images/bg_gradient.gif");
request.setPageOrder(HttpRequest.PAGE_END);
HttpHeader header;
header
header
* attempt login
* @throws Exception
public void attemptLogin() throws Exception {
request.setMethod("POST");
request.setAbsolutePath("/login.do;jsessionid=FBEEJBPAOPNJ");
request
.setBody(" user=bcadmin&pass=please&redirect=%2Flease%2FLeaseLi stLoad.do%3Frt%3D1004%26ui.new%3DtrueHTTP/1.1 100 Continue");
request.setPageNumber(2);
request.setPageOrder(HttpRequest.PAGE_ONLY);
HttpHeader header;
header
header
header.setName("Content-Type");
header.setValue("application/x-www-form-urlencoded");
header
header.setName("Content-Length");
header.setValue("89");
header.setName("Cache-Control");
header.setValue("no-cache");
header.setName("Server");
header.setValue("Orion/2.0.5");
header.setName("Date");
header.setValue("Tue, 25 Apr 2006 18:31:55 GMT");
* Lease list (authenticated)
* @throws Exception
public void leaseList_authenticated_() throws Exception {
request
.setAbsolutePath(" /lease/LeaseListLoad.do;jsessionid=FBEEJBPAOPNJ?rt=1004& ui.new=true ");
request.setPageNumber(3);
HttpHeader header;
header
header
header
* js/prototype
* @throws Exception
public void js_prototype() throws Exception {
request.setAbsolutePath("/js/util/prototype.js");
HttpHeader header;
header
.setValue("http://bcdevapp1:8007/lease/LeaseListLoad.do;jsessionid=FBEEJBPAOPNJ?rt=1004&ui.new=true");
header
* js/cookie
* @throws Exception
public void js_cookie() throws Exception {
request.setAbsolutePath("/js/util/cookie.js");
HttpHeader header;
header
header
* js/date
* @throws Exception
public void js_date() throws Exception {
request.setAbsolutePath("/js/util/date.js");
HttpHeader header;
header
header
* js/dom
* @throws Exception
public void js_dom() throws Exception {
request.setAbsolutePath("/js/util/dom.js");
HttpHeader header;
header
header
* js/etc
* @throws Exception
public void js_etc() throws Exception {
request.setAbsolutePath("/js/util/etc.js");
HttpHeader header;
header
header
* js/event
* @throws Exception
public void js_event() throws Exception {
request.setAbsolutePath("/js/util/event.js");
HttpHeader header;
header
header
* js/form
* @throws Exception
public void js_form() throws Exception {
request.setAbsolutePath("/js/util/form.js");
HttpHeader header;
header
header
* js/table
* @throws Exception
public void js_table() throws Exception {
request.setAbsolutePath("/js/util/table.js");
HttpHeader header;
header
header
Re: TPTP 4.1 URL Test Execution hangs at 93%, CPU is tapped [message #68776 is a reply to message #68083] |
Thu, 27 April 2006 02:28  |
Originally posted by: ankit.parikh.c-sam.co.in
Hello Mr.David,
We are facing similar problem as you have posted. We are evaluating TPTP
tool with build 4.1.0.1 .
Our url test run is being hanged up at 93%.
Any kind of help and forwards would be very appriciable.
Thanks in Advance.
Ankit Parikh
C-SAM
Current Time: Wed Jul 23 02:41:06 EDT 2025
Powered by FUDForum. Page generated in 0.30500 seconds
