[teneo] Is Inheritance variant TABLE_PER_CLASS still unsupported [message #67788] |
Wed, 10 January 2007 19:00  |
Originally posted by: user.domain.com
I saw in the elver.org doc that Inheritance variant TABLE_PER_CLASS was
not supporter but in the
" http://www.elver.org/xsd/teneo/persistence-mapping-hibernate .xsd"
the TABLE_PER_CLASS is a valid enymeration
<xsd:simpleType name="InheritanceType">
<xsd:restriction base="xsd:token">
<xsd:enumeration value="SINGLE_TABLE"/>
<xsd:enumeration value="TABLE_PER_CLASS"/>
<xsd:enumeration value="JOINED"/>
</xsd:restriction>
</xsd:simpleType>
So I have a question; is the Inheritance variant TABLE_PER_CLASS
unsupported?
Anyone got a clue?
regards and thanks for any hints
/anders
Re: [teneo] Is Inheritance variant TABLE_PER_CLASS still unsupported [message #67977 is a reply to message #67894] |
Thu, 11 January 2007 09:38  |
Hi Martin
Its seems to to work altough I havent really tested it.
As requested I added a buzilla entry: 170221 for adding test cases
thanks
/anders
Martin Taal wrote:
> We have no test case for this inheritance strategy. You can try to set
> it using an annotation. The source code handles the annotation but I
> have not yet tried it.
> The global inheritance option parameter does not allow table-per-class.
> Please enter a bugzilla if you want (explicitly-tested) support for this.
> gr. Martin
> user@domain.com wrote:
>> Hi
>> was not supporter but in the
>> </xsd:restriction>
>> </xsd:simpleType>
>> unsupported?
>> Anyone got a clue?
>> /anders
Re: [teneo] Is Inheritance variant TABLE_PER_CLASS still unsupported [message #601129 is a reply to message #67788] |
Thu, 11 January 2007 08:03  |
We have no test case for this inheritance strategy. You can try to set it using an annotation. The
source code handles the annotation but I have not yet tried it.
gr. Martin
> Hi
> </xsd:restriction>
> </xsd:simpleType>
> unsupported?
> Anyone got a clue?
> /anders
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] Is Inheritance variant TABLE_PER_CLASS still unsupported [message #601167 is a reply to message #67894] |
Hi Martin
thanks
/anders
Martin Taal wrote:
> gr. Martin
>> Hi
>> </xsd:restriction>
>> </xsd:simpleType>
>> unsupported?
>> Anyone got a clue?
>> /anders
FUDForum. Page generated in 0.05392 seconds
