Home » Archived » XML Schema Definition (XSD) » Inheritance Problem
Inheritance Problem [message #67893] |
Mon, 24 April 2006 22:09  |
Hi!
I'm trying to define a simple inheritance model from a web tutorial. I
failed using the XSD sample editor (2.2 RC1), i.e. it didn't let me
define the base type for the extension (it was set to anyType).
Thus, I took the snippet and copied it into a sample schema. But I think
there is something wrong because I get an error annotation that the base
element could not be found.
<xsd:schema xmlns:this="http:///test/myschema"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http:///test/myschema">
<xsd:complexType name="Address">
<!-- stuff -->
</xsd:complexType>
<xsd:complexType name="USAddress">
<xsd:complexContent>
<xsd:extension base="Address">
<!-- stuff -->
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:schema>
As this is my first step in this stuff I probably doing something wrong
here. Any ideas what?
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Inheritance Problem [message #67957 is a reply to message #67936] |
Tue, 25 April 2006 08:48  |
--------------030706070209040200060502
Gunnar,
You can use xmlns="...." to bind the null prefix to a namespace.
I don't install WTP for my development work so I don't have direct
personal experience. If the problem is as you describe, you should open
a bugzilla (but I find it hard to believe that there's no way to set the
base type of a complex type).
Gunnar Wagenknecht wrote:
> Hi Ed,
> Ed Merks wrote:
>> You have no xmlns declaration that binds the null prefix to the target
>> namespace of this schema, so the base="Address" reference won't resolve
>> to the "Address" complex type in this schema. Using base="this:Address"
>> will work better.
> Damn, it's the second time I stumble across an incorrect sample snippet.
> :( But all tutorials I read don't mention anything about the null
> prefix. How do I set it? xmlns:null?
> BTW, I created the schema using the EMF wizard. Maybe the wizard should
> add the null prefix by default?
>> The XSD Sample editor is quite a crummy editor so if
>> you will do any significant amount of editing, the WTP XML Schema editor
>> is much better.
> Have you used the WTP editor? I wasn't able to create this there. Again,
> the base type was fixed to "anyType" and I couldn't change it in the UI.
> Cu, Gunnar
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Gunnar,<br>
<br>
You can use xmlns="...." to bind the null prefix to a namespace.<br>
<br>
open a bugzilla (but I find it hard to believe that there's no way to
set the base type of a complex type).<br>
<br>
<br>
<blockquote cite="mide2l3hn$qus$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">You have no xmlns declaration that binds the null prefix to the target
will work better.
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">The XSD Sample editor is quite a crummy editor so if
is much better.
</pre>
</blockquote>
Cu, Gunnar
</pre>
</blockquote>
<br>
</body>
</html>
--------------030706070209040200060502--
Re: Inheritance Problem [message #598021 is a reply to message #67893] |
Tue, 25 April 2006 07:51  |
Gunnar,
will work better. The XSD Sample editor is quite a crummy editor so if
is much better.
> Hi!
> <!-- stuff -->
> </xsd:complexType>
> <!-- stuff -->
> </xsd:extension>
> </xsd:complexType>
> </xsd:schema>
> Cu, Gunnar
Re: Inheritance Problem [message #598025 is a reply to message #67915] |
Tue, 25 April 2006 08:09  |
Hi Ed,
> will work better.
> is much better.
Cu, Gunnar
Gunnar Wagenknecht
Re: Inheritance Problem [message #598033 is a reply to message #67936] |
Gunnar,
> Hi Ed,
>> will work better.
>> is much better.
> Cu, Gunnar
<html>
<head>
</head>
Gunnar,<br>
<br>
<br>
<br>
<br>
<pre wrap="">Hi Ed,
Ed Merks wrote:
</pre>
will work better.
</pre>
</blockquote>
</pre>
is much better.
</pre>
</blockquote>
Cu, Gunnar
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Sat Jul 26 20:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.05299 seconds
