Home » Eclipse Projects » Remote Application Platform (RAP) » Unable to create perspective
Unable to create perspective [message #67335] Wed, 26 December 2007 08:30 Go to next message
Hi all
I have exception when I run my RAP application, which is:
org.eclipse.ui.WorkbenchException: Unable to create perspective
'ae.salwa.rap.perspectives'. There is no corresponding perspective
extension.
My senaria is like that:
Am building my RCP and RAP plugin togather. In the build directory, the
plugin folder includes the plugin for both rap and rcp.
Can any one help me to fix my problem
best
Salwa
Re: Unable to create perspective [message #67489 is a reply to message #67335] Fri, 28 December 2007 08:35 Go to previous messageGo to next message
this could be caused by several different cases. One thing which happens
really often to the users is that they forgot the add all the bundles
they need to the launch configuration and thus there is really no plugin
which provides such a perspective.
Just an idea.
Greets
Benny
Salwa wrote:
> Hi all
> extension.
> best Salwa
Re: Unable to create perspective [message #67597 is a reply to message #67489] Sun, 30 December 2007 09:25 Go to previous messageGo to next message
Thankx for your reply,
No, I add all the required plugins. but i found that the problem is that i
have conflict between "org.eclipse.ui" plugin and
"org.eclipse.ui.rap"plugin
when i build both Rap and RCP platform.
Any help to fix this problem.
Salwa
Re: Unable to create perspective [message #67793 is a reply to message #67597] Wed, 02 January 2008 03:16 Go to previous messageGo to next message
there is no solution for my case.
salwa
Re: Unable to create perspective [message #67813 is a reply to message #67597] Wed, 02 January 2008 03:43 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Salwa,
could you provide more specific information about what causes the
conflict? Did you declare plug-in-dependencies on org.eclipse.ui and
org.eclipse.rap.ui? Does your launch-configuration include both plug-ins?
Rüdiger
> i have conflict between "org.eclipse.ui" plugin and
> Regards Salwa
Re: Unable to create perspective [message #67924 is a reply to message #67813] Wed, 02 January 2008 06:11 Go to previous messageGo to next message
org.eclipse.rap.ui?
No, Just org.eclipse.rap.ui
It includes only org.eclipse.rap.ui plugin
Re: Unable to create perspective [message #68045 is a reply to message #67924] Wed, 02 January 2008 10:32 Go to previous message
Salwa,
I don't quite understand where conflict should come from.
Could you maybe provide a small self-contained plug-in that reproduces
the problem?
Rüdiger
> org.eclipse.rap.ui? No, Just org.eclipse.rap.ui
Previous Topic:Asserting component enability
Next Topic:How to use customized JS in RAP?
Current Time: Sun Oct 26 13:41:28 EDT 2025
Powered by FUDForum. Page generated in 0.05946 seconds
