[Eugenia] FixGMFGen and nullpointerexception [message #677814] |
Thu, 09 June 2011 07:49  |
Hi all,
I have the following code in FixGMFGen.eol:
var features = GmfGen!FeatureLabelModelFacet.all.select( feat |
feat.metaFeatures.isDefined());
var featureLabel = features.selectOne( x | x.metaFeatures.exists( mf |
mf.ecoreFeature.name == "qcf"));
featureLabel.println();
And it prints the following:
org.eclipse.gmf.codegen.gmfgen.impl.FeatureLabelModelFacetImpl@410e942e
(viewPattern: name={0} qcf={1}, editorPattern: name={0} qcf={1},
editPattern: name={0} qcf={1}, viewMethod: MESSAGE_FORMAT, editMethod:
MESSAGE_FORMAT)
So hopefully the query is correct...?
but somewhere else it crashes, see stacktrace below.
(Removing the code removes the crash..)
Any clues for this?
All the best,
Ivar Refsdal
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:143)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:114)
at
org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:288)
at
org.eclipse.gmf.internal.bridge.transform.ValidationHelper.validate(ValidationHelper.java:320)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.validateGenModel(ExecuteTemplatesOperation.java:263)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesOperation.run(ExecuteTemplatesOperation.java:106)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTemplatesAction.run(ExecuteTemplatesAction.java:47)
at
org.eclipse.epsilon.eugenia.GenerateDiagramCodeDelegate.runImpl(GenerateDiagramCodeDelegate.java:26)
at
org.eclipse.epsilon.eugenia.GenerateAllDelegate$2.run(GenerateAllDelegate.java:131)
at
org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at
org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Re: [Eugenia] FixGMFGen and nullpointerexception [message #677815 is a reply to message #677814] |
Thu, 09 June 2011 07:58   |
PS...
This is also reproduceable on the model from
http://www.eclipse.org/gmt/epsilon/doc/eugenia/
and using the following code:
mf.ecoreFeature.name == "name"));
Best,
Ivar
Ivar Refsdal wrote, on 06/09/2011 01:49 PM:
> Hi all,
> MESSAGE_FORMAT)
> Any clues for this?
> All the best,
> Ivar Refsdal
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
> at
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
FUDForum. Page generated in 0.28870 seconds
