Home » Eclipse Projects » Web Tools incubator » Increase Eclipse heap size
Increase Eclipse heap size [message #675788] Wed, 01 June 2011 09:58 Go to next message
Hi together,
I want to parse big XML-Files (32MB) with Xquery (small files work fine).
I always reveive the error: Exception in thread "main" java.lang.OutOfMemoryError: Java heap space
Then I changed -Xms and -Xmx in the eclipse.ini but nothing happend, I couldn't fix the problem even if I enter enough memory (1024MB). The parsing-process of Eclipse only takes to about 300MB and then it throws the error.
So in my opinion, only Eclipse gets the memory and not the parsing-process. (Nevertheless this amount should be enough for the parsing-process...)
So how can I change this?
Simon
Re: Increase Eclipse heap size [message #677335 is a reply to message #675788] Wed, 08 June 2011 04:15 Go to previous messageGo to next message
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
<br>
<blockquote cite="mid:is5g1h$ucf$1@news.eclipse.org" type="cite">I
fine).
<br>
<br>
(1024MB). <br>
</blockquote>
<br>
I can not keep it straight on how to change VM argument parameters
... I also have had trouble sometimes getting "-Xmx" to "take". You
might try specifying it on the command line, such as "eclipse ...
-vmargs -Xmx1G and see if it makes a difference. <br>
<br>
And, the ultimate irony .... I was going to look for a link to
command line arguments, and found this link with a search service: <br>
<br>
<a class="moz-txt-link-freetext" href="http://help.eclipse.org/helios/topic/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html">http://help.eclipse.org/helios/topic/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html</a>
<br>
<br>
And, what did I get when I tried it? <br>
<br>
<h2>HTTP ERROR 500</h2>
<p>Problem accessing
/help/topic/org.eclipse.platform.doc.isv/reference/misc/runtime-options.html.
Reason:
</p>
<pre> INTERNAL_SERVER_ERROR</pre>
<h3>Caused by:</h3>
<pre>java.lang.OutOfMemoryError
at java.util.zip.InflaterInputStream.&lt;init&gt;(InflaterInputStream.java:96)
at java.util.zip.ZipFile$2.&lt;init&gt;(ZipFile.java:391)
at java.util.zip.ZipFile.getInputStream(ZipFile.java:362)
at java.util.zip.ZipFile.getInputStream(ZipFile.java:327)
at org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleEntry.getInputStream(ZipBundleEntry.java:60)
at org.eclipse.osgi.framework.internal.core.BundleURLConnection.connect(BundleURLConnection.java:53)
at org.eclipse.osgi.framework.internal.core.BundleURLConnection.getInputStream(BundleURLConnection.java:99)
at java.net.URL.openStream(URL.java:1044)
</pre>
<br>
</body>
</html>
Re: Increase Eclipse heap size [message #677339 is a reply to message #677335] Wed, 08 June 2011 04:29 Go to previous messageGo to next message
<html>
<head>
</head>
On 06/08/2011 04:15 AM, David Williams wrote:
<blockquote cite="mid:isnaic$94h$1@news.eclipse.org" type="cite">
<title></title>
<br>
fine). <br>
java.lang.OutOfMemoryError: Java heap space <br>
memory (1024MB). <br>
</blockquote>
<br>
</blockquote>
Oh, and .... thinking now about what you are trying to do ... you
probably need to set the vm arguments in one of the "run" launcher
configurations (that, I'm assuming, is created when you try to "run"
your xquery? <br>
<br>
</body>
</html>
Re: Increase Eclipse heap size [message #693897 is a reply to message #677335] Thu, 07 July 2011 09:09 Go to previous message
No, it doesn't make a difference.
>your xquery?
Meanwhile I think, it is not passible to parse this big files.
(At least I don't know how Wink)
So I decided to split this large files into smaller ones and everything
just works fine.
Previous Topic:Multiple diagrams with JPA Diagram Editor
Next Topic:[JAX-WS] Encoding
Current Time: Sat Jul 26 05:18:35 EDT 2025
Powered by FUDForum. Page generated in 0.08234 seconds
