Home » Eclipse Projects » Rich Client Platform (RCP) » Update View after command has changed model
Update View after command has changed model [message #676475] Sat, 04 June 2011 14:40 Go to next message
i have a TreeView with a list of Projects and Persons in this Projects (leaf).
Now i want to make a new Project. I have a Command for that. This command opens a dialog to insert the details of the new Project. But how do i update the treeView now?
I do it like this currently:
		NewProjectDialog dialog = new NewProjectDialog(window.getShell());
		if (dialog.open() == Window.OK) {
			Project project = dialog.getProject();
                        // Saving the new project in databank
			dbModel = new DatabankModel();
			dbModel.persistEntity(project);
			dbModel.save();
                        // Update treeViewer
			projects = new ProjectsModel();
			view.getViewer().setInput(projects.getProjects());
but it seems a little ugly to me to update the view from the command?
Re: Update View after command has changed model [message #676697 is a reply to message #676475] Mon, 06 June 2011 03:52 Go to previous messageGo to next message
Originally posted by:
On 2011-06-04 20:40, AmFreak wrote:
> (leaf).
> dbModel.save();
I agree. IMO your model should be able to send model-change events and
the content provider of your viewer should listen to these events,
eventually ensuring the refresh.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Update View after command has changed model [message #677304 is a reply to message #676697] Wed, 08 June 2011 02:09 Go to previous message
Thanks for the reply!
The problem is the model is in the view class. Sure i could implement a getMethod for the model so that my command class can get it, but than i would again change the view class from the command class :-/
With a button i would just create a listener in the view and when the dialog to add a new project is closed i would get the new project from the dialog and add it to the model in the view, but with a command that isn't possible Sad
Previous Topic:auto saving preferences
Next Topic:Problem with the RCP Texteditor example
Current Time: Wed Jul 23 17:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.04189 seconds
