Home » Archived » M2M (model-to-model transformation) » [QVTr] Is it impossible to create a profileApplication in QVT Relation Language?
[QVTr] Is it impossible to create a profileApplication in QVT Relation Language? [message #677173] Tue, 07 June 2011 15:15 Go to next message
by using QVT Relation language (QVT R) I would like to apply a profile in a transformation. Therefore I need to create some code in this way:
<xmi:XMI xmi:version="2.1" xmlns:xmi="  //schema.omg.org/spec/XMI/2.1" xmlns:xsi="  //www.w3.org/2001/XMLSchema-instance" xmlns:MyProfile="  ///schemas/MyProfile/_jIh_MEE2EeCEN_hYm6Ct-Q/99" xmlns:ecore="  //www.eclipse.org/emf/2002/Ecore" xmlns:uml="  //www.eclipse.org/uml2/3.0.0/UML" xsi:schemaLocation="  ///schemas/MyProfile/_jIh_MEE2EeCEN_hYm6Ct-Q/99 ../Model/ProfileModels/MyProfile.uml#_jIj0YEE2EeCEN_hYm6Ct-Q">
  <uml:Model xmi:id="_qb8akM37EdqwVrslYOdUDA">
      <profileApplication xmi:id="_DC760IwsEeCVgu6ZKnAeAA">
        <eAnnotations xmi:id="_DC760YwsEeCVgu6ZKnAeAA" source="h ttp://www.eclipse.org/uml2/2.0.0/UML">
          <references xmi:type="ecore:EPackage" href="../Model/ProfileModels/MyProfile.uml#_jIj0YEE2EeCEN_hYm6Ct-Q"/>
        </eAnnotations>
        <appliedProfile href="../Model/ProfileModels/MyProfile.uml#_XkGiwB07Ed-QQ4mYkrb7Gg"/>
      </profileApplication>
  </uml:Model>
</xmi:XMI>
To me it seem impossible to create this code by using QVT-R. Here is why:
1. I don't have a chance to add the xsi:schemaLocation attribute to element <xmi:XMI>, i.e. xsi:schemaLocation="[...]/schemas/MyProfile/_jIh_MEE2EeCEN_hYm6Ct-Q/99 ../Model/ProfileModels/MyProfile.uml#_jIj0YEE2EeCEN_hYm6Ct-Q"
2. There is no way to access a href-Property for references (i.e. href="../Model/ProfileModels/MyProfile.uml#_jIj0YEE2EeCEN_hYm6Ct-Q") and appliedProfile (i.e. href="../Model/ProfileModels/MyProfile.uml#_XkGiwB07Ed-QQ4mYkrb7Gg").
Maybe no. 1 is only a problem when using Topcased, so even solving no. 2 would be most helpful. The following QVT relation (for EMF 2.5) results in code that is close to a solution in no. 2, but it still lacks the href. Href is not supported in by UML-Metamodel.
  relation profileApplication
    enforce domain target mdl : uml::Model
      profileApplication = pa : uml::ProfileApplication {
        eAnnotations = doc : ecore::EAnnotation {
          source = '  //www.eclipse.org/uml2/2.0.0/UML',
          references = set : ecore::EPackage {
           -- no way to set href-property
        appliedProfile = prof : uml::Profile {
Results in:
   <uml:Model>
    <profileApplication xmi:id="_vDV3UCMZEeCZ7MQ24lstxw" appliedProfile="_vDWeYCMZEeCZ7MQ24lstxw">
      <eAnnotations xmi:id="_vDV3UiMZEeCZ7MQ24lstxw" source="  //www.eclipse.org/uml2/2.0.0/UML" references="_vDV3VCMZEeCZ7MQ24lstxw"/>
  </uml:Model>
  <ecore:EPackage xmi:id="_vDV3VCMZEeCZ7MQ24lstxw" name="MyProfile"/>
  <uml:Profile xmi:id="_vDWeYCMZEeCZ7MQ24lstxw" name="MyProfile"/>
Using EMF 2.6 the relation above fails, because for any reason references are now EObjects. But this does not make it easier.
Has anyone an idea or any suggestion how to apply a profile using QVT Relation Language (QVT R)?
(The same is discussed for QVT Operational Language (QVT O) is solved in this post, but can not be applied in QVT R: www.eclipse.org/forums/index.php/mv/msg/32162/104316/#msg_104316)
Thanks a lot,
Sabine
Re: [QVTr] Is it impossible to create a profileApplication in QVT R? -- Where is http gone? [message #677175 is a reply to message #677173] Tue, 07 June 2011 15:18 Go to previous messageGo to next message
I had to remove all "http" from my message, because I may not post any URLs yet. So please imagine, there would be a http where you find one missing.
Sabine
(no subject) [message #677186 is a reply to message #677175] Tue, 07 June 2011 15:40 Go to previous messageGo to next message
Hi Sabine
QVTr has no UML support yet.
Since I've had to devote my time to MDT/OCL this year, QVTr has made no
progress in the Indigo release.
However the new modeled pivot support for MDT/OCL should make an OMG
compliant (UML with profiles) QVTr much easier so I hope to make
progress on QVTr for Juno.
I'm afraid that doesn't help you now.
Anyone interested in helping me on QVTr?
Ed Willink
On 07/06/2011 20:18, Sabine Mueller wrote:
> missing.
> Sabine
Re: (no subject) [message #753653 is a reply to message #677186] Fri, 28 October 2011 04:19 Go to previous message
Hi Sabine, Ed, folks,
I came to this discussion from the medini forum, where I learned a bit about it from a guy named "Thomas". Generally applying profiles to models within M2M transformations should be possible. I did it for myself with Eclipse QVT-O. My presentation at a last year's GI Workshop ("Informatik2010") covered it in a bit. The presentation and the sample project (GI2010/qvt/OM/MVC.qvto), both in german, are to be fond on my website (http://www.siegfried-nolte.de/GI2010/GI2010.html, see the GI2010.zip). So the Eclipse's UML metamodel representation and the profile operations (applyProfile, applyStereotype) included in there do it.
Pitily the declarative MVC.qvt is missing. I will try to prepare an example with QVT-R as well. Though I learned from Thomas, that he wants to go a step further and create an UML profile dynamically with a M2M transformation. First I thought it to be easy but now I'm convinced, that it isn't.
Yet it must be possible with diving a bit deeper into the metamodel. So we have to continue discussing in a while.
See you,
Siegfried
[Updated on: Fri, 28 October 2011 05:58] by Moderator
Previous Topic:[ATL] Query a model element using XPATH expression
Next Topic:Transforming to and from nested objects
Current Time: Mon Jul 21 00:22:29 EDT 2025
Powered by FUDForum. Page generated in 0.02920 seconds
