Home » Archived » BIRT » Newby to BIRT
Newby to BIRT [message #489913] Tue, 06 October 2009 09:28 Go to next message
Hi all,
I started to try out Birt in favor of Itext.
I made a report and connected it to my running hsqldb
Connection test was: OK
Now i made a test report, just printing some lines from a table in my db.
Te result was wat I expected and was the same as in the preview !
But i still get some sever exception when i run my code :
6-okt-2009 15:16:02 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadExtraDriver
SEVERE: DriverClassLoader failed to load class: org.hsqldb.jdbcDriver
java.lang.ClassNotFoundException: org.hsqldb.jdbcDriver
at org.eclipse.birt.core.framework.URLClassLoader.findClass1(UR LClassLoader.java:185)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:154)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:1)
at org.eclipse.birt.core.framework.URLClassLoader.findClass(URL ClassLoader.java:149)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load ExtraDriver(JDBCDriverManager.java:919)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.find Driver(JDBCDriverManager.java:738)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.regi sterDriver(JDBCDriverManager.java:879)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load AndRegisterDriver(JDBCDriverManager.java:862)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:246)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:212)
at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:234)
at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:160)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:238)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:180)
at org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:193)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:181)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:209)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:396)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:315)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:144)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:511)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:139)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:254)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1818)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.ListItemExecutor.exe cute(ListItemExecutor.java:66)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:170)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
at birt.ExecuteReport.executeReport(ExecuteReport.java:40)
at birt.BirtTestUsage.main(BirtTestUsage.java:7)
SEVERE: refreshUrlsWhenFail: true
SEVERE: driverClassPath: null
SEVERE: Registered URLs:
code that i ran:
public void executeReport() throws EngineException {
IReportEngine engine = null;
EngineConfig config = null;
try {
config = new EngineConfig();
config
.setBIRTHome(" C:\\Users\\javadev\\Desktop\\birt-runtime-2_5_1\\ReportEngin e ");
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_E NGINE_FACTORY);
engine = factory.createReportEngine(config);
IReportRunnable design = null;
design = engine
.openReportDesign("src/test/java/birt/reports/secondTry.rptdesign ");
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
PDFRenderOption options = new PDFRenderOption();
options
.setOutputFileName("c:/Users/javadev/Desktop/tempbirt/test2.pdf ");
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
} catch (Exception ex) {
System.out.println("Error in executeReport : ");
ex.printStackTrace();
} finally {
Platform.shutdown();
You might notice it's the example code from the wiki.
So i don't know what i'm doing wrong, since there were no errors making the preview and the result is fine, because i get a pdf file with the data :s
Could someone please help.
Re: Newby to BIRT [message #490047 is a reply to message #489913] Wed, 07 October 2009 01:13 Go to previous messageGo to next message
This error:
indicates that the driver jar is not in the
birt-runtime-2_5_1\ReportEngine\plugins\org.eclipse.birt.rep ort.data.oda.jdbc_2.5.1.v20090821\drivers
directory. Can you copy it there? You can also alter your code to pass in the path like:
config.getAppContext().put("OdaJDBCDriverClassPath", "c:/birt/mysql/mysql-connector-java-5.0.4-bin.jar");
Jason
Re: Newby to BIRT [message #490059 is a reply to message #489913] Wed, 07 October 2009 02:48 Go to previous messageGo to next message
Thx a lot, the errors are gone Smile
Re: Newby to BIRT [message #657736 is a reply to message #490047] Thu, 03 March 2011 13:34 Go to previous messageGo to next message
Thank you Jason. I also encountered the same problem but using Oracle 10g XE (for learning). I had added the following to my classpath when running my stand alone Java app:
C:\software\birtruntime\birt-runtime-2_6_2\ReportEngine\lib\ *.jar
C:\software\oracle10gExpressEdition\app\oracle\product\10.2. 0\server\jdbc\lib\ojdbc14.jar
My stand alone app did generate the pdf file but got the same error:
DriverClassLoader failed to load class: oracle.jdbc.OracleDriver
I then proceeded to add the following to the java code, as you suggested in your post:
config.getAppContext().put("OdaJDBCDriverClassPath", " C:\\software\\oracle10gExpressEdition\\app\\oracle\\product\ \10.2.0\\server\\jdbc\\lib\\ojdbc14.jar ");
The errors are gone too!
Thanks again!
--Anna
Re: Newby to BIRT [message #677006 is a reply to message #657736] Tue, 07 June 2011 06:00 Go to previous messageGo to next message
hi,
can you please say where i have to paste the code i.e which program
Please help
Re: Newby to BIRT [message #677014 is a reply to message #657736] Tue, 07 June 2011 06:28 Go to previous messageGo to next message
in which program or where i have to add
"config.getAppContext().put("OdaJDBCDriverClassPath", " C:\\software\\oracle10gExpressEdition\\app\\oracle\\product\ \10.2.0\\server\\jdbc\\lib\\ojdbc14.jar ");"
Plz explain
Re: Newby to BIRT [message #677188 is a reply to message #677014] Tue, 07 June 2011 12:43 Go to previous message
If you are using the RE API add it when you create the engine config.
eg
EngineConfig config = new EngineConfig();
config.getAppContext()......
If you are using the viewer you can add it to either the beforeFactory
script or the beforeOpen of the datasource. Just put it in like:
reportContext.getAppContext().put("OdaJDBCDriverClassPath",
"C:\\software\\oracle10gExpressEdition\\app\\oracle\\product\
\10.2.0\\server\\jdbc\\lib\\ojdbc14.jar");
Jason
> Plz explain
Previous Topic:Choosing the OS
Next Topic:How to dynamically set the grouping range value for a table?
Current Time: Sun Jul 27 04:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.18503 seconds
