Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Multiple Generation errors with 1.0RC
[EEF] Multiple Generation errors with 1.0RC [message #675859] Wed, 01 June 2011 14:05 Go to next message
We are trying to bring our 0.9 project to 1.0RC3 (latest as of today)
and have been getting multiple errors during the generation process
(which we didn't have before) and tens of thousands of compile errors.
I essentially stripped the project all the way down to almost only have
the initial model and while the issues are much less, there are still a
number of issues.
1. The EEFGEN was generated in the .edit projects and I kept getting:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
'/com.castortech.iris.models.ecore.smm.1.0/model/SMM.eefgen' does not exist.
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$WorkbenchHelper.createPlatformResourceInputStream(PlatformResourceURIHandlerImpl.java:222)
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createInputStream(PlatformResourceURIHandlerImpl.java:452)
at
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:350)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1262)
at
org.eclipse.emf.eef.codegen.ui.generators.actions.GenerateEEFAction.initEEFGenModel(GenerateEEFAction.java:63)
at
org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGenerateEEFAction.run(AbstractGenerateEEFAction.java:90)
Caused by: org.eclipse.core.internal.resources.ResourceException:
Resource '/com.castortech.iris.models.ecore.smm.1.0/model/SMM.eefgen'
does not exist.
at
org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:320)
at
org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:194)
As I said the eefgen is in the .edit project under a model folder. In
order to get around this, I had to move the eefgen and component model
to the base model folder.
2. Bunch of logged errors:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Undefined "Let"
expression at line 51 in Module EEFLauncher for block let eObjects :
Sequence(EObject) =
peContext.model.ecorePackage.eAllContents()->select(temp1 : OclAny |
temp1.oclIsKindOf(ecore::EPackage))->including(peContext.model.ecorePackage).
Last recorded value of self was
org.eclipse.emf.eef.EEFGen.impl.GenEditionContextImpl@9e552d0
(basePackage: com.castortech, descriptorsContributorID: null,
descriptorsGenericPropertiesViews: true, gmfPropertiesViews: false,
generateJunitTestCases: false, leafComponentsSuperClass: null,
propertiesEditingProvidersSuperClass: null).
at EEFLauncher.EEFLauncher(EEFGenModel)(EEFLauncher.mtl:51)
at EEFLauncher.EEFLauncher(EEFGenModel)(EEFLauncher.mtl:36)
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid result
for expression s.first(1).isAlpha().not() at line 398 in Module common
for query startsWithADigit(String). Last recorded value of self was null.
at common.toJavaIdentifierDelegate(String)(common.mtl:0)
at common.toJavaIdentifierDelegate(String)(common.mtl:416)
at common.toJavaIdentifierDelegate(String)(common.mtl:415)
at common.toJavaIdentifier(String)(common.mtl:0)
org.eclipse.acceleo.engine.AcceleoEvaluationException: Couldn't evaluate
URL of the file at line 19 in Module plugin_xml for block
file(editionContext.model.ecorePackage.name.concat('_properties.plugin.xml'),
false). Last recorded value of self was
org.eclipse.emf.eef.components.impl.PropertiesEditionContextImpl@6baccc1e (eProxyURI:
platform:/resource/com.castortech.iris.models.ecore.smm.1.0/model/SMM.components#_dT8rgYxjEeCDZt1FA67FAQ).
at plugin_xml.plugin_xml(PropertiesEditionContext,String)(plugin_xml.mtl:19)
at plugin_xml.plugin_xml(PropertiesEditionContext,String)(plugin_xml.mtl:18)
at EEFLauncher.EEFLauncher(EEFGenModel)(EEFLauncher.mtl:0)
at EEFLauncher.EEFLauncher(EEFGenModel)(EEFLauncher.mtl:44)
3. Finally an error where the code seems to be using a toString() of
some sort to generate a file name:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Could not create
directory
C:\eclipse\IrisWorkspace\com.castortech.iris.models.ecore.smm.1.0.edit\src-gen\parts\Org\eclipse\emf\ecore\impl\DynamicEObjectImpl@2ce64498(eClass:Org\eclipse\emf\ecore\impl.
at
org.eclipse.acceleo.engine.generation.strategy.DefaultStrategy.createWriterFor(DefaultStrategy.java:113)
at
org.eclipse.acceleo.engine.generation.strategy.DefaultStrategy.createWriterFor(DefaultStrategy.java:97)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationContext.openNested(AcceleoEvaluationContext.java:591)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.createFileWriter(AcceleoEvaluationVisitor.java:268)
4. About 50 occurrences of this error:
5. About 50 occurrences of this error as well:
for expression p.eInverse(genmodel::GenPackage)->first() at line 78 in
Module common for query associatedGenPackage(EPackage). Last recorded
value of self was org.eclipse.emf.ecore.impl.EcorePackageImpl@1b81464b
(name: ecore) (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix:
ecore).
at common.completePackage(EPackage)(common.mtl:0)
at common.completePackage(EPackage)(common.mtl:446)
at common.completePackage(EPackage)(common.mtl:445)
at common.qualifiedMetamodelFactory(EPackage)(common.mtl:0)
at common.qualifiedMetamodelFactory(EPackage)(common.mtl:505)
6. Then the organize import completes with a dialog complaining about
some "Problem with Organize Imports".
see: http://dl.dropbox.com/u/24514519/OrgImports2.PNG
7. Missing imports for EcoreFactory
In a large number of the generated component files in the
updateSemanticModel method, there is a line like this:
EObject eObject = EcoreFactory.eINSTANCE.createEObject();
and the EcoreFactory was not imported. The number where those errors
were seems to match the list of errors reported by Organize Imports.
8. Another error:
java.lang.UnsupportedOperationException
at
org.eclipse.ocl.ecore.impl.OCLExpressionImpl.accept(OCLExpressionImpl.java:164)
at
org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:248)
at
org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(EvaluationVisitorDecorator.java:156)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1672)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:985)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.java:847)
at
org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1622)
After fixing the import issues, at this point I can successfully compile
the code, but I have not tried it yet, as I had to get rid of all of our
associated model and code changes in order to get to this point.
I'm quite concerned to see issues like this popping up at an RC stage.
We never had so many issues even when 0.9 was in flux. Does this look
like an environment issue or ????
Thanks for any help clarifying the situation here.
Alain
Re: [EEF] Multiple Generation errors with 1.0RC [message #676716 is a reply to message #675859] Mon, 06 June 2011 05:40 Go to previous messageGo to next message
Originally posted by:
Hi Alain,
We had some build server issues for RC3 like almost every project, it
has impacted EEF as well.
looking at the errors you provided, can you check that you are using the
latest version of acceleo ( 3.1.0 ) and OCL ( 3.1.0 ) ?
I tried today with eclipse modeling package RC3 and the latest eef
nightly, and cannot reproduce your generation errors.
BTW, it will be a RC4 for EEF.
Le 01/06/2011 20:05, Alain Picard a écrit :
> number of issues.
> exist.
> at
> at
> at
> at
> at
> at
> does not exist.
> at
> at
> Sequence(EObject) =
> at
> at
> directory
> at
> at
> at
> at
> ecore).
> 8. Another error:
> at
> at
> at
> at
> at
> at
> at
> Cheers,
> Alain
Stéphane Bouchet, OBEO
Re: [EEF] Multiple Generation errors with 1.0RC [message #676820 is a reply to message #675859] Mon, 06 June 2011 11:48 Go to previous messageGo to next message
> 8. Another error:
> at
This occurs when either
a) a new OCLExpression class is evaluated and accept has not been
implemented
b) an old OCLExpression class is evaluated for the first time and accept
has not been implemented
Neither of these seems at all likely for a regression test at RC3.
I strongly suggest you rebuild and maybe re-install.
Ed Willink
Re: [EEF] Multiple Generation errors with 1.0RC [message #676827 is a reply to message #676716] Mon, 06 June 2011 12:24 Go to previous messageGo to next message
Stéphane,
I am running all the latest and greatest as shown below.
Eclipse Modeling Tools
Version: Indigo Release
Build id: 20110526-1053
Acceleo - Text generation from models
Version: 3.1.0.v20110524-0419
Build id: S201105240419
OCL (Object Constraint Language)
Version: 3.1.0.v20110523-1332
Build id: S201105231332
So is there a newer version of EEF that I should use?
Alain
On 6/6/2011 5:40 AM, Stéphane Bouchet wrote:
> Hi Alain,
>> Hi,
>> number of issues.
>> exist.
>> at
>> at
>> at
>> at
>> at
>> at
>> does not exist.
>> at
>> at
>> Sequence(EObject) =
>> (eProxyURI:
>> at
>> at
>> directory
>> at
>> at
>> at
>> at
>> ecore).
>> 8. Another error:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Cheers,
>> Alain
Re: [EEF] Multiple Generation errors with 1.0RC [message #677326 is a reply to message #676827] Wed, 08 June 2011 03:22 Go to previous messageGo to next message
We are promoting a RC4 build that will be our final release for 1.0.0.
Le 06/06/2011 18:24, Alain Picard a écrit :
> Stéphane,
> Alain
>> Hi Alain,
>>> Hi,
>>> number of issues.
>>> exist.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> does not exist.
>>> at
>>> at
>>> Sequence(EObject) =
>>> null.
>>> null.
>>> (eProxyURI:
>>> at
>>> at
>>> directory
>>> at
>>> at
>>> at
>>> at
>>> null.
>>> ecore).
>>> 8. Another error:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Alain
Re: [EEF] Multiple Generation errors with 1.0RC [message #685660 is a reply to message #677326] Fri, 17 June 2011 21:09 Go to previous messageGo to next message
I'm getting a lot of errors just like that as well. Oddly, I don't think they were happening until after I tried a gen with JMerge, but now they won't go away. Should we be using the version from the Indigo staging repos or something else?
Re: [EEF] Multiple Generation errors with 1.0RC [message #686048 is a reply to message #685660] Tue, 21 June 2011 09:57 Go to previous message
hi,
sorry for the delay, but seems the nntp bridge with thie forums is totally broken.
BTW, tomorrow is the official release of indigo and the staging repo will be deleted. EEF 1.0.0 is exactly the same as EEF RC4, so if you have this one installed, could you please be more specific about your generation problems ?
Previous Topic:[TEXO] Adding functions to util.ext
Next Topic:[EEF] Migrate 1.0 Not using EMF ItemProvider
Current Time: Fri Jul 18 15:36:20 EDT 2025
Powered by FUDForum. Page generated in 0.23853 seconds
