Home » Modeling » M2T (model-to-text transformation) » EvaluationException : Couldn't find operation(EvaluationException : Couldn't find operation 'packagedElements()' for org::eclipse::uml2::uml::internal::impl::PackageImpl)
EvaluationException : Couldn't find operation [message #676769] Mon, 06 June 2011 09:14 Go to next message
I have trouble with loading the UML metamodel. I have an XPT file with the following import declaration:
«IMPORT org::eclipse::uml2::uml»
«DEFINE main (Package package) FOR Package-»
«LET this.packagedElements().typeSelect(Class) AS classList-»
«ENDLET-»
«ENDDEFINE»
When running the work flow I get the following error:
EvaluationException : Couldn't find operation 'packagedElements()' for org::eclipse::uml2::uml::internal::impl::PackageImpl.
The method packagedElements is declared in org::eclipse::uml2::uml::Package and is offered by the code completion.
The UML package is on the classpath.
Require-Bundle: org.eclipse.uml2.uml;bundle-version="3.1.2",
What did I wrong?
Re: EvaluationException : Couldn't find operation [message #676816 is a reply to message #676769] Mon, 06 June 2011 11:56 Go to previous messageGo to next message
please verify that you are using JavaBeansMetamodel in both Workflow and UI as your template suggests.
~Christian
Re: EvaluationException : Couldn't find operation [message #676817 is a reply to message #676769] Mon, 06 June 2011 11:59 Go to previous message
Try this.packagedElement since there is a packagedElement Attribute.
Ed Willink
On 06/06/2011 14:14, Olaf Bigalk wrote:
> «ENDLET-»
> «ENDDEFINE»
> What did I wrong?
Previous Topic:[Acceleo] Class Cast Exception with UML Profiles
Next Topic:[Acceleo] creating something similar to a JET custom tag with acceleo
Current Time: Wed Jul 23 20:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.76482 seconds
