Home » Language IDEs » Java Development Tools (JDT) » How to disable JDT's RunAs launch shortcut?
How to disable JDT's RunAs launch shortcut? [message #676758] Mon, 06 June 2011 08:39 Go to next message
I'm developing an eclipse plugin for LeJOS (Java for the Lego NXT brick). Currently, a leJOS project has both a leJOS nature and a JDT nature, where the leJOS nature is the first (primary) nature. I also implemented my own launch shortcut. However, when clicking the green play button, Eclipse makes me chose between "Run as Java Application" and "Run as LeJOS NXT Program" (the latter is my own launch shortcut). This is quite annoying for a user.
So is there any way to disable the JDT launch shortcut?
Note, that it doesn't make any sense to run Java code written for the Lego NXT with let's say Sun's JVM. Actually, there nothing comparable to a full fledged JVM. That's why we have our own launch shortcut, launch configuration delegate, etc. and it would make sense to disable JDT's launch shortcut.
(no subject) [message #676775 is a reply to message #676758] Mon, 06 June 2011 09:41 Go to previous messageGo to next message
Did you try to specify your launcher on the Run/Debug > Launching >
Default Launchers preference page?
Dani
Re: (no subject) [message #676785 is a reply to message #676775] Mon, 06 June 2011 10:20 Go to previous messageGo to next message
Dani Megert wrote on Mon, 06 June 2011 09:41
On the preferences page, Eclipse shows neither the JDT Java Application launcher nor my own leJOS launcher. It shows a bunch of JUnit launchers, which enabled me to chose between the Android JUnit launchers and Eclipse JUnit launchers. So it seems to be possible
Looking at the plugin.xml of the Android plugin leaves me clueless. I also took a look at the list of available extension points. Still clueless Sad
Can you give me hint, on how to make my launcher appear in that list (along with the ones by the JDT)?
(I can't expect you to look at it, but just in case you want to look at my current plugin.xml, click here)
[Updated on: Mon, 06 June 2011 10:25] by Moderator
Re: (no subject) [message #676805 is a reply to message #676785] Mon, 06 June 2011 11:13 Go to previous messageGo to next message
Update: meanwhile, I created a org.eclipse.debug.core.launchDelegates extension points with type org.eclipse.jdt.launching.localJavaApplication. Then, my launcher shows up, and Eclipse let me set the default launcher.
However, suddenly I can start normal Java application with the leJOS launcher, new launch configurations that are created appear under the "Java Application" launch configuration type, and are not using my own configuration type anymore. I don't see any possibility, to override the launch configuration type in the launch configuration delegate. The shortcut does create launch configuration with the correct type. I'm not sure, what is going on.
Re: (no subject) [message #676811 is a reply to message #676805] Mon, 06 June 2011 11:31 Go to previous message
Update 2: my original complaint, that the green play buttons shows the menu every time has gone. Eclipse let's me chose once, and then reuses the created launch configurations. That's a good thing. I'm not sure anymore, what caused the trouble in the first place.
But I'm still trying to find out, how to make "Run as LeJOS Program" the default choice over "Run as Java Application".
Previous Topic:Debug doesn't hit breakpoint
Next Topic:Exporting java runnable jar file problem
Current Time: Sun Jul 20 23:27:21 EDT 2025
Powered by FUDForum. Page generated in 0.27427 seconds
