Home » Eclipse Projects » Eclipse Scout » Enable validation of keys typed in AbstractStringField(Enable the validation of keys typed in AbstractStringField)
Enable validation of keys typed in AbstractStringField [message #631717] Fri, 08 October 2010 10:21 Go to next message
SwtScoutStringField should propagate every SWT-Event of event type SWT.KeyUp to the setTextFromUI(String) method of P_UIFacade of the AbstractStringField (analogous for KeyEvents in Swing). That would enable a programmer to validate text input on every key typed, for example by overriding the execIsEmpty() method of AbstractValueField. Currently only a validation after a traversal is possible, which is sometimes not so convenient for the user.
Re: Enable validation of keys typed in AbstractStringField [message #631912 is a reply to message #631717] Sun, 10 October 2010 09:49 Go to previous messageGo to next message
Hi Jens
You are right, a validation on every key typed would be helpful in some circumstances. Fortunately it is already possible. Smile
You only have to enable it by setting the property validateOnAnyKey on your string field to true.
protected boolean getConfiguredValidateOnAnyKey(){
  return true;
This will execute execValidate on every key typed.
Claudio
Re: Enable validation of keys typed in AbstractStringField [message #676561 is a reply to message #631912] Sun, 05 June 2011 05:25 Go to previous message
I just mentioned it on the wiki: StringField page
[Updated on: Sun, 05 June 2011 05:26] by Moderator
Previous Topic:Access a Scout Service from another servlet
Next Topic:WebStart with Scout
Current Time: Sun Jul 27 08:19:36 EDT 2025
Powered by FUDForum. Page generated in 0.27131 seconds
