Home » Archived » M2M (model-to-model transformation) » Running an ant file from Java to execute some ATL transformations
Running an ant file from Java to execute some ATL transformations [message #67626] Thu, 29 November 2007 10:38 Go to next message
Hello everybody,
I don't know if this newsgroup is the correct place to post my problem, but
I will try.
I have an ANT script (build.xml) that executes several ATL transformations.
I want to run that build.xml file from java because I would like to create
an Eclipse plug-in which executes some ATL transformations. The problem is
tht I don't know how to do that. I have tried with:
Process proce = Runtime.getRuntime().exec("cmd /c
"+ant_home+"/bin/ant -buildfile
c:/eclipse3.3/runtime-New_configuration/Plugin/src/plugin/po pup/actions/build.xml ");
InputStream is = proce.getInputStream();
BufferedReader br = new BufferedReader (new InputStreamReader (is));
String aux = br.readLine();
while (aux!=null)
}catch(Exception e){
System.out.println("Error: "+e.getMessage());
The problem is that only the first sentence in the ANT file is executed, but
not all the script. Why?
Any idea?
Thank you very much in advance
Bea
Re: Running an ant file from Java to execute some ATL transformations [message #67652 is a reply to message #67626] Thu, 29 November 2007 11:07 Go to previous message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Bea,
Maybe you should take a look to "org.eclipse.ant.core.AntRunner" java
class. I think it will be more adapted to your use case.
HTH
Freddy.
Bea a écrit :
> Hello everybody,
> I will try.
> while (aux!=null)
> Any idea?
> Bea
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Previous Topic:[ATL] Insert elements in reference features
Next Topic:[ATL] Problem with UML-Reference
Current Time: Sun Jul 27 03:47:59 EDT 2025
Powered by FUDForum. Page generated in 0.25225 seconds
