Home » Modeling » M2T (model-to-text transformation) » [Xtext] call generator from the editor
[Xtext] call generator from the editor [message #676255] Fri, 03 June 2011 08:33 Go to next message
Hey
I have a DSL (DSL2) where i import the ecore model of a first DSL (DSL1)
everything works fine, i made some Xtend Templates for the generator project and as long as i start the generator project from the developement workspace it works.
Buf i need to use the generator from within the editor.
so i enabled the project wizzard (for my DSL2).
if i try to start the generator using the editor it fails with the following error message.
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module Generator: Cannot resolve proxy: file:/C:/Dokumente%20und%20Einstellungen/becma/workspace_DSL2_prototype/gt.DSL2.generator/bin/workflow/ExperimentGenerator.mwe2#xtextLink_::0.3.4.0.1.4.1.1::0::/1
java.lang.RuntimeException: Problems instantiating module Generator: Cannot resolve proxy: file:/C:/Dokumente%20und%20Einstellungen/becma/workspace_DSL2_prototype/gt.DSL2.generator/bin/workflow/ExperimentGenerator.mwe2#xtextLink_::0.3.4.0.1.4.1.1::0::/1
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:73)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.lang.IllegalStateException: Cannot resolve proxy: file:/C:/Dokumente%20und%20Einstellungen/becma/workspace_DSL2_prototype/gt.DSL2.generator/bin/workflow/ExperimentGenerator.mwe2#xtextLink_::0.3.4.0.1.4.1.1::0::/1
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:88)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:135)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:92)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:272)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:56)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:126)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:102)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:69)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:89)
at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:71)
... 3 more
I think the dependency to the first DSL is missing somehow, but i'm not shure what to do to setthe dependency.
hope someone can help me
Re: [Xtext] call generator from the editor [message #676344 is a reply to message #676255] Fri, 03 June 2011 15:55 Go to previous messageGo to next message
Hi Matthias,
Am 6/3/11 2:33 PM, schrieb Matthias B.:
> Hey
Are you using Xtend2?
What project wizard did you enable?
You cannot use MWE2 from within your editor. Thee is still an open
issue. But usualyy you don't need it? What is the mwe2 file doing?
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: [Xtext] call generator from the editor [message #676689 is a reply to message #676344] Mon, 06 June 2011 03:23 Go to previous messageGo to next message
hey, sorry for the lait reply!
no, i don't use xtend2 at the moment
i enabled the wizard they already have in the xtext workflow of my langage
// project wizard (optional)
			fragment = projectWizard.SimpleProjectWizardFragment {
				generatorProjectName = "${projectName}.generator"
				modelFileExtension = file.extensions
i read my model (both the first and the second one)
component = org.eclipse.xtext.mwe.Reader {
		// lookup all resources on the classpath
		// useJavaClassPath = true
		// or define search scope explicitly
		path = modelPath
		// this class will be generated by the xtext generator
		register = gt.DSL1.Asap2StandaloneSetup {}
		register = gt.DSL2.ExperimentStandaloneSetup {}
		load = {
			slot = "system"//"devices"
			type = "Experiment"//"System"
and i start the Xpand Templates like this:
component = org.eclipse.xpand2.Generator {
		metaModel = org.eclipse.xtend.type.impl.java.JavaBeansMetaModel {}
		expand = "templates::Template_TestCode::main FOREACH system"
		outlet = {
		path = gendataPath
		fileEncoding = fileEncoding
Re: [Xtext] call generator from the editor [message #676696 is a reply to message #676689] Mon, 06 June 2011 04:18 Go to previous messageGo to next message
Sorry, I don't understand what your problem is.
What has the SimpleProjectWizardFragment to do with the other workflow
you mentioned?
Can you share more details?
Sven
Am 6/6/11 9:23 AM, schrieb Matthias B.:
> // project wizard (optional) fragment =
> path = modelPath
> register = gt.DSL1.Asap2StandaloneSetup {} register =
> load = {
> outlet = {
> path = gendataPath
Re: [Xtext] call generator from the editor [message #676710 is a reply to message #676696] Mon, 06 June 2011 05:16 Go to previous message
sorry, think i explain it a bit confusing
i created a Xtext project, called DSL2. in DSL2 i import a existing xtext project i already had (DSL1).
So this part works fine.
After that i used the generator project, Xtext creates for each new project, to get some generated files out of my models. Here i call my Xpand files.
Those Xpand files import a Xtend File were i link to some java code
Now i run the mwe2 workflow which Xtext already created in the generator project.
I import the two dsl i use and i call the Xpand templates, like this...
module workflow.MyGenerator
import org.eclipse.emf.mwe.utils.*
var gendataPath = "src-gen/Software/Test_Master/_gendata"
var vsProjectPath = "d:/Projekte/Test_Master/trunk/Software/modules"
var fileEncoding = "Cp1252"
var modelPath = "src/model"
Workflow {
/*	Setup the generator																				 */
		path = modelPath
		register = gt.DSL1.DSL1StandaloneSetup {}
		register = gt.DSL2.DSL2StandaloneSetup {}
		load = {
/*	generate all configuration files																 */
		expand = "templates::Template_Test1::main FOREACH system"
		outlet = {
		path = gendataPath
/*then i just call all other templates like the one above*/
if i run the mwe2 workflow everything works fine.
My next step was to create a project wizzard for my DSL2 language. i did this by enabling the SimpleProjectWizardFragment and i merged the xml files. So i got the wizzard in the editor.
My problem now, if i create a DSL2 project in the DSL-Editor it get a file called Generator.mwe2 which i thought starts the generator file from the editor.
The code in the Generator.mwe2 file looks like this.
module Generator
var targetDir = "src-gen"
Workflow {
	component = @workflow.DSL2Generator auto-inject {}
So if i run this workflow from within the editor, i get the error messages shown in the post above.
My assumption is, that i need to include something because the error message says something with a xtext link he can't resolve, but i'm not shure what i need to include because i tried a lot already. Both dsl i use seem to be alright, at least the text highlighting is working for both DSL1 and DSL2.
hope i explained my problem better, if not let me know what details you need
thanks a lot!!!
Previous Topic:[xtend2][ecore] Can I generate from ecore models using Xtend2?
Next Topic:[Acceleo] Class Cast Exception with UML Profiles
Current Time: Wed Jul 23 19:57:05 EDT 2025
Powered by FUDForum. Page generated in 0.02999 seconds
