Home » Language IDEs » ServerTools (WTP) » @XmlSchema for a metro webservice
@XmlSchema for a metro webservice [message #675979] Thu, 02 June 2011 05:07 Go to next message
i'm having problems to set qualified as elementFormDefault.
i'm using glassfish metro web service stack, with eclipse helios.
i've my own webservice class
WebService(name = "MyWebService" , targetNamespace = "myURL")
@BindingType(value="http:__java.sun.com/xml/ns/jaxws/2003/05/soap/bindings/HTTP/")
@SOAPBinding
style = SOAPBinding.Style.DOCUMENT,
use = SOAPBinding.Use.LITERAL,
parameterStyle = SOAPBinding.ParameterStyle.WRAPPED
public class MyWebService
To setup proper schema i added package-info.java to my package where my webservice is
@XmlSchema ( elementFormDefault=javax.xml.bind.annotation.XmlNsForm.QUALIFIED,
attributeFormDefault=javax.xml.bind.annotation.XmlNsForm.QUALIFIED,
namespace="myURL",
xmlns = {
@javax.xml.bind.annotation.XmlNs(prefix = "services", namespaceURI="myURL"),
package com.viewshape.webservices;
import javax.xml.bind.annotation.XmlSchema;
the package-info.class is deployed to glassfish but when i request the wsdl qualified is not set there.
thank you in advance.
Re: @XmlSchema for a metro webservice [message #676026 is a reply to message #675979] Thu, 02 June 2011 10:24 Go to previous messageGo to next message
So how does the problem manifest itself?
The value "myURL" isn't a very good URL and
"http:__java.sun.com/xml/ns/jaxws/2003/05/soap/bindings/HTTP/" doesn't
look like a very good namespace either.
> @SOAPBinding
> ) public class MyWebService
Re: @XmlSchema for a metro webservice [message #676332 is a reply to message #676026] Fri, 03 June 2011 14:41 Go to previous message
since i just joined the forum, i can't post a message with url inside the message itself, so i had to replace the actual urls with other values.
in the source code the urls are valid http urls
Previous Topic:how to override addBreakpoint and deleteBreakpoint listener of javascript
Next Topic:New Editor?
Current Time: Wed Jul 23 06:42:43 EDT 2025
Powered by FUDForum. Page generated in 0.06544 seconds
