Home » Modeling » M2T (model-to-text transformation) » not able to work with JET
not able to work with JET [message #675991] Thu, 02 June 2011 05:42 Go to next message
I am a new user of JET.
I copied this content in my sample.xml file.
<class name="HelloClass">
<phrase>Hello,World!</phrase>
</class>
also I copied the following content in main.jet which is supposed to be my template.
public class <c:get select="/class/@name" /> {
System.out.println("<c:get select="/class/phrase" />");
Now when I am running this, I am just getting "successful Execution" in the console...but I am not able to trace the output file.I am using Eclipse Helios.
Can someone plz help me with my problem.
Thanks.
Karishma
Re: not able to work with JET [message #676021 is a reply to message #675991] Thu, 02 June 2011 10:19 Go to previous messageGo to next message
Karishma,
You consulted with your best friend, the debugger?
karishma wrote:
> </class>
> be my template.
> public static void main(String[] args) {
> Eclipse Helios.
> Thanks.
> Karishma
Re: not able to work with JET [message #676288 is a reply to message #676021] Fri, 03 June 2011 10:30 Go to previous messageGo to next message
Thanx for replying...and I am not able to trace any problem even if I am debugging it..Is there anything else which I should have done???I guess the output of this file should be generated in the console..isnt it??
Re: not able to work with JET [message #676321 is a reply to message #676288] Fri, 03 June 2011 12:34 Go to previous message
Comments below.
> am debugging it..
Why not?
It's not so clear what you've all done.
> console..isnt it??
I guess so, but as I said, it's not clear what you've all done.
Unless Paul Elder guesses better than me, and reads your question,
you'll need to figure out what's wrong yourself.
Previous Topic:org.eclipse.emf.mwe.core.ConfigurationException: Couldn't find an interface ...
Next Topic:Ecore Model & Xpand: Uppercase Attributes lead to errors
Current Time: Sun May 11 12:12:34 EDT 2025
Powered by FUDForum. Page generated in 0.03048 seconds
