Home » Language IDEs » Java Development Tools (JDT) » Including file into build
Including file into build [message #676281] Fri, 03 June 2011 10:00 Go to next message
I want to include a file which is located in a source folder of the project (1) into the binary folder (2).
(1) src/org/eclipse/bpmn2/impl/bpmn2.ecore
(2) bin/org/eclipse/bpmn2/impl/bpmn2.ecore
where 'src' is a source folder, 'bin' a binary folder
I figured out that for *.txt and *.properties files this will be done automatically but not with files with file extension *.ecore
So I tried to specify the file as bin.include in build.properties but unfortunately this does not work.
My build.properties looks like this:
bin.includes = .,\
               model/,\
               META-INF/,\
               plugin.xml,\
               plugin.properties,\
jars.compile.order = .
source.. = src/
output.. = bin/
Re: Including file into build [message #676286 is a reply to message #676281] Fri, 03 June 2011 10:24 Go to previous messageGo to next message
Except filtered resources all non java files in the build path gets copied. The filtered resources can be specified through Preferences->Java Compiler->Building->Output Folder.
Re: Including file into build [message #676318 is a reply to message #676286] Fri, 03 June 2011 12:11 Go to previous message
thanks! .. this solves the issue
Previous Topic:Any way to register event to trigger when Unix FD changes?
Next Topic:Getting NoSuchMethodError in runtime.
Current Time: Sat Jul 26 20:38:13 EDT 2025
Powered by FUDForum. Page generated in 0.03268 seconds
