HREFDanglingException not expected... [message #676283] |
Fri, 03 June 2011 10:02  |
Hello, I am getting an HREFDanglingException that I would not expect to find...
I wrote a method that should get every dangling EObject and add it to the resource so that no dangling objects remain and the exception does not appear. This is the code... it doesn't work for some reason, can you spot it?
for (EObject eo : resource.getContents()){
inspect(eo,r);
resource.save(new HashMap<Object,Object>()); // -> DanglingHREFException!
private static void inspect(EObject eo, Resource r) {
if (eo==null) return;
if (eo.eResource()==null){
throw new IllegalArgumentException();
EClass ec = eo.eClass();
for (EReference er : ec.getEReferences()) {
if (er.isContainment()) {
if (er.isMany()) {
for (EObject sub : (List<EObject>) eo.eGet(er)) {
inspect(sub,r);
} else {
inspect((EObject) eo.eGet(er),r);
} else {
if (er.isMany()) {
if (sub.eResource() == null) {
r.getContents().add(sub);
inspect(sub, r);
} else {
EObject sub = (EObject) eo.eGet(er);
if (sub != null) {
inspect(sub, r);
I tried to catch the DanglingHREFException (which is inside an IOWrappedException). Unfortunately the exception does not contain a reference to the dangling eobject so I can not inspect it...
Federico
Re: HREFDanglingException not expected... [message #687141 is a reply to message #676283] |
Fri, 03 June 2011 13:34   |
Federico,
Comments below.
> to find...
> you spot it?
> inspect(eo,r);
Should this be getEAllReferences()?
> if (er.isMany()) {
> inspect(sub,r);
Do you know that Resource.getAllContents() will walk the whole
containment tree without all this logic?
> } else {
> } else {
EObject.eCrossReferences is useful for easily visiting all referenced
objects.
> if (er.isMany()) {
> inspect(sub, r);
> } else {
> if (sub != null) {
> inspect(sub, r);
What's stopping you from setting an exception breakpoint, or a
breakpoint on the constructor for the exception?
> Federico
Re: HREFDanglingException not expected... [message #687380 is a reply to message #676283] |
Federico,
Comments below.
> to find...
> you spot it?
> inspect(eo,r);
> if (er.isMany()) {
> inspect(sub,r);
> } else {
> } else {
objects.
> if (er.isMany()) {
> inspect(sub, r);
> } else {
> if (sub != null) {
> inspect(sub, r);
> Federico
FUDForum. Page generated in 0.03983 seconds
