Home » Modeling » M2T (model-to-text transformation) » [Xpand2]Loading multiple model files
[Xpand2]Loading multiple model files [message #675932] Wed, 01 June 2011 21:39 Go to next message
Howdy!
I'm currently loading both Xtext models and XMI models using the org.eclipse.xtext.mwe.Reader and org.eclipse.emf.mwe.utils.Reader components respectively:
component = Reader {
	uri = "platform:/resource/org.xtext.example.generator/src/model/default.graph"
	modelSlot = "qgraph"
component = org.eclipse.xtext.mwe.Reader {
	// lookup all resources on the classpath
	// useJavaClassPath = true
	// or define search scope explicitly
	path = modelPath
	// this class will be generated by the xtext generator
	register = org.xtext.RpgdslStandaloneSetup {}
	load = {
		slot = "model"
		type = "Model"
Is there a way to load every XMI file in a folder? Or better yet, every file with a given extension? As opposed to defining what exactly is the file we want to load that is. I know the Xtext reader can do that, it would be useful if the other one did as well!
Thank you for your time,
Sérgio Silva
Re: [Xpand2]Loading multiple model files [message #676028 is a reply to message #675932] Thu, 02 June 2011 10:54 Go to previous messageGo to next message
you could of course come with such a workflow component yourself. or you provide a own ResourceServiceProvider for the non xtext files then the org.eclipse.xtext.mwe.Reader will read these files too. Xtext comes with a ResourceServiceProvider for .ecore files. see plugins org.eclipse.xtext.ecore and org.eclipse.xtext.ui.ecore. therefore it woulkd be helpful if the xmi files have a metamodel specific file extension.
~Christian
[Updated on: Thu, 02 June 2011 10:58] by Moderator
Re: [Xpand2]Loading multiple model files [message #676036 is a reply to message #676028] Thu, 02 June 2011 11:07 Go to previous messageGo to next message
Hello Christian,
Thank you for replying!
I've been trying to implement my own component, but unfortunately I'm not yet familiarized with the API.
My current solution does what I want but the slot containing all the resources has type List[org::eclipse::emf::ecore::xmi::impl::XMIResourceImpl]. Is there a way to specify the type of the resource?
public void invoke(IWorkflowContext ctx) {
	File f = new File(xmiLocation);
	String files[] = f.list(new FilenameFilter(){
		public boolean accept(File arg0, String arg1) {
			return arg1.endsWith(extension);
	ResourceSet set = new ResourceSetImpl();
	for(String file : files){
		String nuri = uri + file;
		set.createResource(URI.createURI(nuri));
	ctx.put(getModelSlot(), set.getResources());
xmiLocation is the relative path to the folder containing the files, extension is the file extension we want to process and uri is the uri to the folder containing the files. I know it's a bit redundant having both relative path and URI, but it was the only way I was able to find to obtain all the files with a given extension.
What am I doing wrong?
Thanks again,
Sérgio
Re: [Xpand2]Loading multiple model files [message #676041 is a reply to message #676036] Thu, 02 June 2011 11:15 Go to previous messageGo to next message
what about asking the resources for their contents. and add all the contents to the slot. see the org.eclipse.emf.mwe.utils.Reader component.
final Resource res;
		try {
			res = resourceSet.getResource(URI.createURI(uri), true);
			if (res == null)
				throw new WorkflowInterruptedException("Couldn't find resource under " + uri);
			if (!res.isLoaded()) {
				res.load(Collections.EMPTY_MAP);
		catch (final WrappedException e) {
			if (ignoreMissingModel) {
				return null;
			throw new WorkflowInterruptedException("Couldn't load resource under " + uri + " : " + e.getMessage());
		catch (final IOException e) {
				return null;
		final EList<EObject> result = res.getContents();
		if (firstElementOnly) {
			if (result.isEmpty())
				return null;
			return result.iterator().next();
		else
			return result;
~Christian
Re: [Xpand2]Loading multiple model files [message #676125 is a reply to message #676041] Thu, 02 June 2011 17:57 Go to previous messageGo to next message
It worked! Thank you very much!
Sérgio
Re: [Xpand2]Loading multiple model files [message #676563 is a reply to message #676125] Sun, 05 June 2011 05:39 Go to previous messageGo to next message
Hello together,
I have the same or a similar problem. I want to process multiple .xmi (dynamic instances of a ecore model) files with data in one Xpand step.
So the .xmi must be merged at some point.
The purpose is I want to generate one single output file from multiple xmi files.
Each xmi file contains only a part of the complete data.
You can say the model data is distributed over several xmi files, an is not concentrated (merged) in a single xmi file.
I understood from posts above this can be achived by by loading multiple xmi into the same model-slot. But I do not understand how to do this.
Does the code above do the job? I guess it is java code
I have no java in my project. Only a Ecore model, dynamic instances, a workflow and a xpand template.
Re: [Xpand2]Loading multiple model files [message #676608 is a reply to message #676563] Sun, 05 June 2011 13:20 Go to previous messageGo to next message
you have to write (as Serge did) a custom workflow component that does this for you. this component could look like (quick n dirty) or a mix of serges and my post above.
package components;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.mwe.core.WorkflowContext;
import org.eclipse.emf.mwe.core.issues.Issues;
import org.eclipse.emf.mwe.core.lib.WorkflowComponentWithModelSlot;
import org.eclipse.emf.mwe.core.monitor.ProgressMonitor;
public class MultiModelReader extends WorkflowComponentWithModelSlot {
	private List<String> uris = new ArrayList<String>();
	public void addUri(String uri) {
		uris.add(uri);
	protected void invokeInternal(WorkflowContext ctx, ProgressMonitor monitor,
			Issues issues) {
		List<EObject> allContents = new ArrayList<EObject>();
		for(String uri : uris){
			Resource resource = set.getResource(URI.createURI(uri), true);
			allContents.addAll(resource.getContents());
		ctx.set(getModelSlot(), allContents);
<?xml version="1.0"?>
<workflow>
	<property name="src-gen" value="src-gen" />
	<!-- set up EMF for standalone execution -->
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
		<platformUri value=".."/>
		<registerEcoreFile value="src/metamodel/metamodel.ecore" />
	</bean>
	<!-- instantiate metamodel -->
	<bean id="mm_emf" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
	<!-- load model and store it in slot 'model' -->
	<component class="components.MultiModelReader">
		<uri value="platform:/resource/my.generator.project/src/model/Model.xmi" />
		<uri value="platform:/resource/my.generator.project/src/model/Model2.xmi" />
		<modelSlot value="model" />
	</component>
	<!--  generate code -->
	<component class="org.eclipse.xpand2.Generator">
		<metaModel idRef="mm_emf"/>
		<expand
			value="template::Template::main FOREACH model" />
		<outlet path="${src-gen}" >
			<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
		</outlet>
	</component>
</workflow>
if you want to scan a directory you need somthing like serge + but as discussed before you have to add all contents of the resources to a list as i do it in my code.
if you want to call a template for a list simpoly ajust the definition
«DEFINE main FOR List[Model]»
~Christian
[Updated on: Sun, 05 June 2011 13:38] by Moderator
Re: [Xpand2]Loading multiple model files [message #676622 is a reply to message #676608] Sun, 05 June 2011 14:23 Go to previous message
Thank you Christian,
works almost perfectly Smile
(I am wondering why "List" is known, but it works)
Previous Topic:Ecore Model & Xpand: Uppercase Attributes lead to errors
Next Topic:[Acceleo] Ref: Bug 319375 - Using ant task with model referring to UML Primitive types
Current Time: Wed Sep 17 10:47:51 EDT 2025
Powered by FUDForum. Page generated in 0.05231 seconds
