Home » Archived » Buckminster » ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #676182 is a reply to message #676114] |
Fri, 03 June 2011 02:22   |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=ISO-8859-15"
http-equiv="Content-Type">
</head>
I can see it in
<a class="moz-txt-link-freetext" href="https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1511/console">https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1511/console</a>
:<br>
<pre><b class="ant-target">provision<a name="ant-target-19"></a></b>:
[echo] Importing projects into workspace /opt/users/hudsonbuild/workspace/emf-cdo-integration/result/workspace and binaries into target platform /opt/users/hudsonbuild/workspace/emf-cdo-integration/result/tp
[mkdir] Created dir: /opt/users/hudsonbuild/workspace/emf-cdo-integration/result/tp
[java] INFO: System property http.proxyHost has been set to proxy.eclipse.org by an external source. This value will be overwritten using the values from the preferences
[java] INFO: System property http.proxyPort has been set to 9898 by an external source. This value will be overwritten using the values from the preferences
[java] INFO: System property http.nonProxyHosts has been set to *.eclipse.org|172.30.206.* by an external source. This value will be overwritten using the values from the preferences
[java] INFO: System property https.proxyHost has been set to proxy.eclipse.org by an external source. This value will be overwritten using the values from the preferences
[java] INFO: System property https.proxyPort has been set to 9898 by an external source. This value will be overwritten using the values from the preferences
[java] INFO: System property https.nonProxyHosts has been set to *.eclipse.org by an external source. This value will be overwritten using the values from the preferences
[java] WARNING [0015] : Component request org.junit:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705] is inconflict with request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100]
[java] WARNING [0025] : Component request org.junit.source:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is inconflict with request org.junit.source:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705]
[java] WARNING [0004] : Component request org.apache.log4j:osgi.bundle/[1.2.15.v201012070815,1.2.15.v201012070815] is inconflict with request org.apache.log4j:osgi.bundle/[1.2.13.v200903072027,1.2.13.v200903072027]
<font color="#ff0000"><b>[java] ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1</b></font>
[java] WARNING [0106] : Component request org.apache.commons.logging:osgi.bundle/[1.0.4.v201101211617,1.0.4.v201101211617] is inconflict with request org.apache.commons.logging:osgi.bundle/[1.1.0,2.0.0)
[java] INFO: TAG-ID 0004 = Query for org.eclipse.emf.cdo.releng:buckminster, path: org.eclipse.emf.cdo.releng:buckminster$4.0.0.qualifier -> org.eclipse.emf.mwe2.runtime.sdk:eclipse.feature$2.0.0.v201106010351
[java] TAG-ID 0015 = Query for org.eclipse.emf.cdo.releng:buckminster, path: org.eclipse.emf.cdo.releng:buckminster$4.0.0.qualifier -> org.eclipse.jdt:eclipse.feature$3.7.0.v20110520-0800-7z8gFchFMTdFYKuJsMLpUla9B15B
[java] TAG-ID 0016 = Query for org.eclipse.emf.cdo.releng:buckminster, path: org.eclipse.emf.cdo.releng:buckminster$4.0.0.qualifier -> com.mysql.jdbc:eclipse.feature$5.1.11
[java] TAG-ID 0025 = Query for org.eclipse.emf.cdo.releng:buckminster, path: org.eclipse.emf.cdo.releng:buckminster$4.0.0.qualifier -> org.eclipse.jdt.source:eclipse.feature$3.7.0.v20110520-0800-7z8gFchFMTdFYKuJsMLpUla9B15B
[java] TAG-ID 0106 = Query for org.eclipse.emf.cdo.releng:buckminster, path: org.eclipse.emf.cdo.releng:buckminster$4.0.0.qualifier -> org.eclipse.platform:eclipse.feature$3.7.0.v20110520-0800-9gF7UHNFFt4cwE-pibLJ7m-mS0OWjdqewtz0110 -> org.eclipse.help:eclipse.feature$1.3.0.v20110327-7i7uFFiFFt6ZqnbNsPXLa3
[java]
<span class="ant-outcome-failure">BUILD FAILED
</span>/opt/users/hudsonbuild/workspace/emf-cdo-integration/org.eclipse.emf.cdo/releng/org.eclipse.emf.cdo.releng/build.xml:319: The following error occurred while executing this line:
/opt/users/hudsonbuild/workspace/emf-cdo-integration/org.eclipse.emf.cdo/releng/org.eclipse.emf.cdo.releng/build.xml:95: The following error occurred while executing this line:
/opt/users/hudsonbuild/workspace/emf-cdo-integration/org.eclipse.emf.cdo/releng/org.eclipse.emf.cdo.releng/build.xml:79: Java returned: 1
(I'll be off until Tuesday)
Cheers
/Eike
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a>
</pre>
<br>
<br>
Am 02.06.2011 23:21, schrieb Thomas Hallgren:
<blockquote cite="mid:is8ud2$61s$1@news.eclipse.org" type="cite">Hi
Eike,
<br>
<br>
How do you know that it's an AIOOB exception? I can't derive that
from the logs. Do you have some other info that I can't see?
<br>
<br>
FWIW, nothing has changed at our end since May 29.
<br>
<br>
- thomas
<br>
<br>
<br>
On 2011-06-02 22:05, Eike Stepper wrote:
<br>
<blockquote type="cite">Here a build with loglevel DEBUG:
<a class="moz-txt-link-freetext" href="https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1513/console">https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1513/console</a>
<br>
<br>
Looks different, but still wrong ;-(
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Am 02.06.2011 22:01, schrieb Eike Stepper:
<br>
<blockquote type="cite">Hi,
<br>
<br>
my builds started failing with the above error message. Here
an example:
<br>
<br>
<br>
Any idea how I can avoid that?
<br>
<br>
Cheers
<br>
/Eike
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</body>
</html>
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #676199 is a reply to message #676182] |
Fri, 03 June 2011 03:05   |
Right, but the run with DEBUG output didn't show this error and consequently, I have no stack-trace.
- thomas
On 2011-06-03 08:22, Eike Stepper wrote:
> I can see it in https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1511/console :
> *provision*:
> *[java] ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1*
> [java]
> BUILD FAILED
> Cheers
> /Eike
>> Hi Eike,
>> How do you know that it's an AIOOB exception? I can't derive that from the logs. Do you have some other info that I
>> can't see?
>> - thomas
>>> Here a build with loglevel DEBUG: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1513/console
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> my builds started failing with the above error message. Here an example:
>>>> Cheers
>>>> /Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #676956 is a reply to message #676199] |
Tue, 07 June 2011 01:08   |
Am 03.06.2011 09:05, schrieb Thomas Hallgren:
I don't have it either. Buckminster must have swallowed it ;-(
Cheers
/Eike
> - thomas
>> *provision*:
>> [java]
>> BUILD FAILED
>> Cheers
>> /Eike
>>> Hi Eike,
>>> can't see?
>>> - thomas
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Cheers
>>>>> /Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #682580 is a reply to message #682579] |
Sat, 11 June 2011 10:30   |
Am 11.06.2011 16:22, schrieb Thomas Hallgren:
> Hi Eike,
> Since you're the only one getting this, would it be possible for you to attach a debugger and trap that exception?
I really would like to but I don't have the least bit of a clue how to debug a Buckminster build on Hudson ;-(
If you want to try to reproduce it I can help you with knowledge about my build, though.
Today I experienced another, different exception without a stack trace. It was a StackOverflowException and I could only solve it because I knew exacly what I had done during the preceding 15 minutes. It was caused by some additional properties that my build.xml wrote to the build-info.xml that's "somehow" consumed later by Buckminster. How can it come that there's no stack trace in the log even though I said --displaystacktrace?
Cheers
/Eike
> - thomas
> On 2011-06-11 15:50, Eike Stepper wrote:
>> And again: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1566/console
>> Cheers
>> /Eike
>> Am 10.06.2011 10:48, schrieb Eike Stepper:
>>> It happened again: https://hudson.eclipse.org/hudson/job/emf-cdo-integration/1549/console
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> Cheers
>>>> /Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #805807 is a reply to message #765493] |
Fri, 24 February 2012 01:49   |
Am 14.12.2011 08:32, schrieb Thomas Hallgren:
> HI Eike,
> The problem is that I don't know who logs this either. I consider it unlikely that it's code that we have control over
> (we would log the stack trace) so I must assume that it's some underlying code that simply does:
> catch(Exception e) {
> log(e.getMessage());
I'm still facing this problem very frequently and in contrast to what I said earlier, I don't believe that this is *not*
a Buckminster issue. Please have oine more look at the exact console output:
[java] ...
[java] TAG-ID 0016 = Query for org.eclipse.emf.cdo.releng:osgi.bundle, path: org.eclipse.emf.cdo.releng:osgi.bundle$4.0.2.qualifier -> com.mysql.jdbc:eclipse.feature$5.1.11
Both the ERROR and the TAG-ID lines are assembled by Buckminster, perhaps in
org.eclipse.buckminster.core.RMContext.formatStatus(BufferedWriter, int, IStatus). In case of an IStatus with an
exception I can't see how the respective stack trace would be written to the output.
In general I can not imagine how a third party technology such as, e.g., p2, could tell Buckminster directly about an
exception without actually throwing or returning it. In both cases the stack trace should be available.
Please, please, please. Please tell me where this exception is coming from ;-(
Cheers
/Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #806188 is a reply to message #806007] |
Fri, 24 February 2012 12:07   |
Eike,
Do you by chance have a path in one of your RMaps that does not exist? I
experienced this issue in that case together with parallel resolutions (iirc
it was a multithreading issue where one thread would invalidate the provider
list somehow, while the other was iterating over it).
In that case, try either removing that path from the RMap or dialing down
the resolution threads.
Thomas,
WRT stacktrace logging, I found this a few days ago:
diff --git
a/org.eclipse.buckminster.core/src/java/org/eclipse/buckminster/core/RMContext.java
b/org.eclipse.buckminster.core/src/java/org/eclipse/buckminster/c
index 7bd4f0c..c41e64e 100644
b/org.eclipse.buckminster.core/src/java/org/eclipse/buckminster/core/RMContext.java
@@ -269,7 +269,7 @@ public class RMContext extends ExpandingProperties<Object> {
if (!isSilentStatus()) {
switch (st.getSeverity()) {
case IStatus.ERROR:
- logger.error(formatStatus(st));
+ logger.error(st.getException(),
formatStatus(st));
break;
case IStatus.WARNING:
logger.warning(formatStatus(st));
Didn't get around to file a bug + patch yet
On 24.02.2012 13:13, Eike Stepper wrote:
> Am 24.02.2012 12:12, schrieb Thomas Hallgren:
>> I hate to admit this ;-) but it looks like you're right. Please enter a bugzilla for with the above info and I'll have
>> a look at it shortly.
> You're the greatest ;-)
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=372470
> Cheers
> /Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #880075 is a reply to message #806188] |
Fri, 01 June 2012 07:17   |
Hi Carsten,
Sorry, your post has slipped through my fingers ;-(
Comments below...
Am 24.02.2012 18:07, schrieb Carsten Reckord:
> Eike,
What do you mean by "path"? <rm:searchPath> elements? If so, how can one not exist?
> I experienced this issue in that case together with parallel resolutions (iirc
Sounds at least reasonable ;-)
I doubt that we have anything in our rmap that can simply be removed.
> or dialing down the resolution threads.
How have you done this? Did it have a bad impact on the build time?
Cheers
/Eike
> Thomas,
> diff --git
> case IStatus.ERROR:
> formatStatus(st));
> break;
>> Cheers
>> /Eike
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #880334 is a reply to message #880075] |
Fri, 01 June 2012 17:33   |
Hi Eike,
Comments below...
>exist?
>What do you mean by "path"?<rm:searchPath> elements? If so, how can
>one not exist?
No, I meant an uri used in a provider pointing to an invalid location ( in
my case it was for local resolution from the file system, can't remember
right now if it also happens with p2 or other providers)
In the IDE it's in the Buckminster preferences. On the command line you can
do 'buckminster setpref maxParallelResolutions 1'
It did slow down the build a bit, but not significantly. I actually kept the
setting after removing the bad path, because it improved log readability (I
log at debug level by default,.which definitely allows down the build
significantly ;p)
cheers,
Carsten
Re: ERROR [0016] : java.lang.ArrayIndexOutOfBoundsException: -1 [message #880494 is a reply to message #880334] |
Sat, 02 June 2012 01:57  |
Am 01.06.2012 23:33, schrieb Carsten Reckord:
> Hi Eike,
> Comments below...
>> exist?
>> one not exist?
Hmm, I'll have to have a closer look in the future whether the failure of the build is caused by the
ArrayIndexOutOfBoundsException or rather by some wrong URI. But I do remember now that in many cases just kicking a new
build (without fixing anything in the RMap) fixed the problem.
> significantly ;p)
Excellent, I'll try that! Thank you a lot ;-)
Cheers
/Eike
Current Time: Sat Jul 26 11:41:45 EDT 2025
Powered by FUDForum. Page generated in 0.15211 seconds
