Home » Archived » BIRT » Counting on a xml data sources(noob needing a little help)
Counting on a xml data sources [message #675462] Tue, 31 May 2011 11:26 Go to next message
Hi there !
I'm trying to make a report from a Xml data sources.
I've got a xml file full or things like
<answer value="yes" from="client1" uselessdata="xxx" />
<answer value="no" from="client2" uselessdata="xxx" />
I was able to make a Data set, allowing me to make a table with all the answer "yes" and who made it.
But now i would like to count how many "yes", and how many "no" there is, but i don't know how do that, and where i have to do that.
I know a sql request can do that, but Xpath seems to be less powerful.
Can someone help me ?
Thanks !
Re: Counting on a xml data sources [message #675489 is a reply to message #675462] Tue, 31 May 2011 12:12 Go to previous messageGo to next message
Is value a column in your dataset? If so you should be able to add a
computed column to the dataset that does a count and add a filter to the
computed column on value == yes. If you have a test xml file and simple
report post it and I can modify it for you.
Jason
On 5/31/2011 11:26 AM, forums-noreply@eclipse.org wrote:
> Hi there !
> Thanks !
Re: Counting on a xml data sources [message #675668 is a reply to message #675489] Wed, 01 June 2011 03:23 Go to previous message
It's all that i needed, it works, thank you !
Previous Topic:Hyperlinks do not work in PDF format
Next Topic:Report Width Formatting Question
Current Time: Wed Jul 23 09:30:23 EDT 2025
Powered by FUDForum. Page generated in 0.07685 seconds
