Home » Eclipse Projects » Eclipse Platform » Help w/ Accessing Java Browsing Elements(Plug-in development)
Help w/ Accessing Java Browsing Elements [message #675563] Tue, 31 May 2011 16:55 Go to next message
For a plug-in, I need to access the views "package, types and members" of the java browsing editor. However, using the import statements such as: "import org.eclipse.jdt.internal.ui.browsing.MembersView;" cause a "discouraged access" warning. I do not know if the functionality is subsequently limited. I have searched all over the internet for a way to access these views correctly but I was not able to locate the right way of doing this. Is anybody aware of this information?
Thank you for your help.
P.S.: Additionally could anyone help me locate the code for the functionality of: Java Browsing Editor > Members View > [Down Arrow] > Visible Categories?
What I would like to do is similar to this functionality and I am not able to locate the plugin that performs this action.
[Updated on: Tue, 31 May 2011 16:59] by Moderator
Re: Help w/ Accessing Java Browsing Elements [message #675679 is a reply to message #675563] Wed, 01 June 2011 03:41 Go to previous messageGo to next message
On 31.05.2011 22:55, NecArn wrote:
> Hello,
What do you mean by "access"? What exactly do you want to do with them?
Dani
Re: Help w/ Accessing Java Browsing Elements [message #675786 is a reply to message #675679] Wed, 01 June 2011 09:52 Go to previous messageGo to next message
Thanks for your reply. I need to filter the elements shown in them according to a selection performed on my particular view. That is why I need the information stored in those views and be able to sort according to selections.
Additionally, is it possible to obtain the information regarding the code of the "visible categories" functionality I described above? If I can take a look at the code for this functionality I might be able to infer which direction I should take.
Thanks again..
Re: Help w/ Accessing Java Browsing Elements [message #675826 is a reply to message #675786] Wed, 01 June 2011 10:37 Go to previous messageGo to next message
Do you only need to filter or rather set the input? If you only want to
filter you could provide a filter via extension point. The JDT views
don't offer much API beyond the general view API. What's special with
the browsing views is that they use the current selection to set the input.
Dani
> Thanks again..
Re: Help w/ Accessing Java Browsing Elements [message #675897 is a reply to message #675826] Wed, 01 June 2011 16:40 Go to previous messageGo to next message
I would like to display certain elements in the views according to the selections performed on my own view. For example in the members view I would like to display only 1 method out of a total of 3. Yet, I am not able to figure out what API I should use.. The problem is that the members view input is reset to null when I perform a selection on my own view. How am I supposed to obtain the information of the members within a class for example? I was thinking of using filters to determine which elements should be displayed but that is not working.
Re: Help w/ Accessing Java Browsing Elements [message #675959 is a reply to message #675897] Thu, 02 June 2011 02:54 Go to previous messageGo to next message
There is no way to set the input. The view decides what to set as input
depending on the selection. For example, if your view provides an
ICompilationUnit or IType as selection, then the Members view will
itself based on that.
Dani
Re: Help w/ Accessing Java Browsing Elements [message #676258 is a reply to message #675959] Fri, 03 June 2011 08:44 Go to previous message
Thanks a lot for your help, Dani.
Previous Topic:How do you access Eclipse Documentation outside the c:\eclipse\plugins directory
Next Topic:Creating an executable icon
Current Time: Sat Jul 26 23:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.28335 seconds
