Home » Archived » BIRT » Table of Contents in WORD
Table of Contents in WORD [message #675332] Tue, 31 May 2011 03:53 Go to next message
is there any support of BIRT to create a table of contents for the output
format WORD?
The table of content should be the first page of the generated report.
I assume that there is no explicit BIRT component for a table of contents.
WORD offers the possibility to insert a table of contents and to fill it
automatically using already existing headers.
May be there is a way to mark some labels in BIRT (as bookmarks or TOC
expressions or ...) and to provide in this way the information for WORD to
create a table of contents (after insertion the WORD TOC component).
The worst possibility would be that I create a list of bookmark links at the
beginning of the report to provide at least the possibility to navigate.
But in fact, I need a table of contents with "WORD style".
(In PDF I use the workaround with bookmarks and I use iText to generate a
hierarchical bookmark overview).
Gerald.
Re: Table of Contents in WORD [message #675488 is a reply to message #675332] Tue, 31 May 2011 12:09 Go to previous message
Gerald,
Not certain if this solution will work but have a look at:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1080-another-report-with-printable-table-of-contents-toc-/
Jason
On 5/31/2011 3:53 AM, Gerald Ploner wrote:
> format WORD?
> Best regards,
> Gerald.
Previous Topic:Check availability of datasets defined in shared library
Next Topic:Passing Dynamic values to OrderBy Clause
Current Time: Sat Jul 26 21:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.08032 seconds
