Home » Archived » M2M (model-to-model transformation) » [QVTo] Multiple output
[QVTo] Multiple output [message #675255] Mon, 30 May 2011 19:00 Go to next message
Is it possible to make a transformation have multiple output files?
For example: I have a model A. For every subelement Item in A, i would like to create a B, and place that in its own file.
Is this possible in QVTo?
modeltype A uses 'http//A';
modeltype B uses 'http//B';
transformation My_A_to_B_Transformation(in a : A, out B);
main() {
  // create a file for every B, made from
mapping A::Item::itemToB() : B {
  name := self.name;
Re: [QVTo] Multiple output [message #675433 is a reply to message #675255] Tue, 31 May 2011 10:00 Go to previous messageGo to next message
> main() {
> // create a file for every B, made from }
> name := self.name;
I may be wrong, but to be this would be a post-processing step rather
than part of the transformation since you don't know beforehand how
many outputs you'll have. If all instances of B are self-contained
(i.e. contain only child objects and attributes) then I would use a
TransformationExecutor to run the transform then, for the output
ModelExtent do:
ResourceSet set = new ResourceSetImpl();
for (EObject obj : extent.getContents()){
if (obj instanceof B){
Resource res = set.createResource(<uri>);
res.getContents().add(obj);
res.save(<options>);
(with some appropriate code to generate the unique URIs you need for
each instance and some options if needed).
Alan
Re: [QVTo] Multiple output [message #675513 is a reply to message #675433] Tue, 31 May 2011 13:54 Go to previous messageGo to next message
I know the best way to do this is to transform a model A to a model C, where C contains multiple B's. I'm just wondering if this is possible in QVT Smile (i'm writing my thesis about the subject)
Edit: Thanks for the reply btw
[Updated on: Tue, 31 May 2011 13:57] by Moderator
Re: [QVTo] Multiple output [message #675671 is a reply to message #675255] Wed, 01 June 2011 02:03 Go to previous messageGo to next message
If I'm not mistaken QVTo transformations can have multiple outputs, as long
as the number of outputs is fixed.
Dennis
> main() {
> name := self.name;
Re: [QVTo] Multiple output [message #675672 is a reply to message #675671] Wed, 01 June 2011 03:09 Go to previous message
I think the QVTo specification is sufficiently vague to justify your
favourite interpretation. I don't see why an output should not be a
Sequence(...).
The current Eclipse QVTo implementation is probably rather more limited.
Ed Willink
> long as the number of outputs is fixed.
> Dennis
>> main() {
>> name := self.name;
Previous Topic:[ATL] http://wiki.eclipse.org/ATL/Concepts broken
Next Topic:[QVTO] Bug or feature: Order of 'out' model parameters affects transformation results
Current Time: Thu Jul 24 20:44:41 EDT 2025
Powered by FUDForum. Page generated in 0.06131 seconds
