Home » Archived » Test and Performance Tools Platform (TPTP) » Install dialog hangs
Install dialog hangs [message #675141] Mon, 30 May 2011 08:09 Go to next message
Hello everybody
While installing tptp 4.7.2 from [1], the installing software dialog is hanging while fetching download.php from [2]
How can I make the install run ?
I'm using SpringSource Tool Suite:
Version: 2.6.0.RELEASE
Build Id: 201103161000
[1] download.eclipse.org/tptp/updates/
[2] www.eclipse.org/downloads/download.php?file=/tptp/updateformant=xml&countrycode=us?timeZone=1&format=xml
Marco
Re: Install dialog hangs [message #675144 is a reply to message #675141] Mon, 30 May 2011 08:17 Go to previous messageGo to next message
Hi Marco,
this looks like an infrastructure problem on eclipse.org to me. I would recommend to wait and retry at a later date.
Torsten
Re: Install dialog hangs [message #675150 is a reply to message #675144] Mon, 30 May 2011 08:37 Go to previous messageGo to next message
Hi Torsten
Thanks. I also think so. My posing is more like a 'hey guys, something isn't working with the installation procedure'. I'll wait Wink
Marco
Re: Install dialog hangs [message #675154 is a reply to message #675150] Mon, 30 May 2011 08:47 Go to previous messageGo to next message
Hi Marco,
I personally prefer installing plugins from zip files for this very reason.
Torsten
Re: Install dialog hangs [message #675174 is a reply to message #675154] Mon, 30 May 2011 09:52 Go to previous message
Hi Torsten
Yes, you're right. As a workaround for all of those who have the same problem, you can download the complete runtime package (without the required dependencies) from [1] (direct), or [2] (overview) and unpack it where your eclipse is installed. You may also try to install the required dependencies over eclipe's regular installation way.
Marco
[1] www.eclipse.org/downloads/download.php?file=/tptp/4.7.2/TPTP-4.7.2/tptp.runtime-TPTP-4.7.2.zip
[2] www.eclipse.org/tptp/home/downloads/
[Updated on: Mon, 30 May 2011 09:55] by Moderator
Previous Topic:Changes in TPTP PMC and project leadership
Next Topic:Can't profile local application at all
Current Time: Fri Jul 25 09:50:59 EDT 2025
Powered by FUDForum. Page generated in 0.02988 seconds
