Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Cross models reference + Java Application
[Acceleo] Cross models reference + Java Application [message #674623] Fri, 27 May 2011 11:30 Go to next message
I have two ecore metamodels. The main one has a simple reference to a class of the second one. My acceleo M2T script imports and uses both metamodels. It works well when executed as an Acceleo plugin but not when executed as a Java application. This is likely due to a problem of dependancy wrt the second model but I don't find how to fix this.
Any help would be appreciated,
Myvatn
Re: [Acceleo] Cross models reference + Java Application [message #675146 is a reply to message #674623] Mon, 30 May 2011 08:27 Go to previous message
When we are running in "Acceleo plugin" mode, we are using the dependencies of the plugin. In "Java application", we are using the classpath. Does your project has a dependency with the project(s) containing the two metamodels ?
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Previous Topic:getValue and 1..*
Next Topic:[Acceleo] Workspace ecore models URI resolution
Current Time: Sat Jul 26 15:25:23 EDT 2025
Powered by FUDForum. Page generated in 0.03033 seconds
